StdMeshers::StdMeshers_ImportSource2D Interface Reference
interface of "Source faces" hypothesis. More...
Inheritance diagram for StdMeshers::StdMeshers_ImportSource2D:
void SetSourceFaces (in SMESH::ListOfGroups groups)
 Set faces to import from other mesh. More...
SMESH::string_array GetSourceFaces ()
void SetCopySourceMesh (in boolean toCopyMesh, in boolean toCopyGroups)
 Set to import the whole other mesh or not, and if yes, to copy groups of not. More...
void GetCopySourceMesh (out boolean toCopyMesh, out boolean toCopyGroups)
string GetName ()
string GetLibName ()
short GetId ()
 Get the internal Id. More...
boolean HasParameters ()
This hypothesis specifies groups of faces of other mesh to be imported in this mesh
◆ GetCopySourceMesh()
void StdMeshers::StdMeshers_ImportSource2D::GetCopySourceMesh ( out boolean  toCopyMesh,
◆ GetId()
◆ GetLibName()
◆ GetName()
◆ GetSourceFaces()
SMESH::string_array StdMeshers::StdMeshers_ImportSource2D::GetSourceFaces ( )
◆ GetVarParameter()
◆ HasParameters()
◆ IsDimSupported()
◆ SetCopySourceMesh()
void StdMeshers::StdMeshers_ImportSource2D::SetCopySourceMesh ( in boolean  toCopyMesh,
By default the mesh is not copied.
◆ SetHolderHypothesis()
◆ SetSourceFaces()
void StdMeshers::StdMeshers_ImportSource2D::SetSourceFaces ( in SMESH::ListOfGroups  groups)
◆ SetVarParameter()
in string  method
