StdMeshers::StdMeshers_Import_1D Interface Reference
StdMeshers_Import_1D: interface of "Use existing 1D elements" algorithm. More...
Inheritance diagram for StdMeshers::StdMeshers_Import_1D:
ListOfHypothesisName GetCompatibleHypothesis ()
 Get list of hypothesis that can be used with this algorithm. More...
string GetName ()
string GetLibName ()
short GetId ()
 Get the internal Id. More...
boolean HasParameters ()
◆ GetCompatibleHypothesis()
ListOfHypothesisName SMESH::SMESH_Algo::GetCompatibleHypothesis ( )
◆ GetId()
◆ GetLibName()
◆ GetName()
◆ GetVarParameter()
◆ HasParameters()
◆ IsDimSupported()
◆ SetHolderHypothesis()
◆ SetVarParameter()
in string  method
