StdMeshers_LayerDistribution2D: interface of "Distribution of Layers" hypothesis.
More...
This hypothesis is used by "Radial quadrangle" algorithm. It specifies 1D hypothesis defining distribution of segments between the internal and the external surfaces.
◆ GetId()
| short SMESH::SMESH_Hypothesis::GetId |
◆ GetLayerDistribution()
Returns 1D hypothesis specifying distribution of layers.
◆ GetLibName()
| string SMESH::SMESH_Hypothesis::GetLibName |
◆ GetName()
| string SMESH::SMESH_Hypothesis::GetName |
◆ GetVarParameter()
| string SMESH::SMESH_Hypothesis::GetVarParameter |
in string |
methodName | ) |
◆ HasParameters()
| boolean SMESH::SMESH_Hypothesis::HasParameters |
◆ IsDimSupported()
| boolean SMESH::SMESH_Hypothesis::IsDimSupported |
in Dimension |
type | ) |
◆ SetHolderHypothesis()
◆ SetLayerDistribution()
| void StdMeshers::StdMeshers_LayerDistribution::SetLayerDistribution |
in SMESH::SMESH_Hypothesis |
distributionHyp | ) |
| raises | ( | SALOME::SALOME_Exception |
Sets 1D hypothesis specifying distribution of layers.
◆ SetVarParameter()
| void SMESH::SMESH_Hypothesis::SetVarParameter |
in string |
parameter, |
in string |
method |
Set the variable parameter.
- Parameters
