StdMeshers::StdMeshers_LengthFromEdges Interface Reference
StdMeshers_LengthFromEdges: interface of "Length From Edges (2D Hyp. for Triangulator)" hypothesis. More...
Inheritance diagram for StdMeshers::StdMeshers_LengthFromEdges:
void SetMode (in long mode) raises (SALOME::SALOME_Exception)
 Sets <mode> parameter value. More...
long GetMode ()
 Returns <mode> parameter value. More...
string GetName ()
string GetLibName ()
short GetId ()
 Get the internal Id. More...
boolean HasParameters ()
◆ GetId()
◆ GetLibName()
◆ GetMode()
long StdMeshers::StdMeshers_LengthFromEdges::GetMode ( )
◆ GetName()
◆ GetVarParameter()
◆ HasParameters()
◆ IsDimSupported()
◆ SetHolderHypothesis()
◆ SetMode()
void StdMeshers::StdMeshers_LengthFromEdges::SetMode ( in long  mode)
◆ SetVarParameter()
in string  method
