StdMeshers::StdMeshers_MaxElementVolume Interface Reference
StdMeshers_MaxElementVolume: interface of "Max. Hexahedron or Tetrahedron Volume" hypothesis. More...
Inheritance diagram for StdMeshers::StdMeshers_MaxElementVolume:
void SetMaxElementVolume (in double volume) raises (SALOME::SALOME_Exception)
 Sets <maximum element volume> parameter value. More...
double GetMaxElementVolume ()
 Returns <maximum element volume> parameter value. More...
string GetName ()
string GetLibName ()
short GetId ()
 Get the internal Id. More...
boolean HasParameters ()
◆ GetId()
◆ GetLibName()
◆ GetMaxElementVolume()
double StdMeshers::StdMeshers_MaxElementVolume::GetMaxElementVolume ( )
◆ GetName()
◆ GetVarParameter()
◆ HasParameters()
◆ IsDimSupported()
◆ SetHolderHypothesis()
◆ SetMaxElementVolume()
void StdMeshers::StdMeshers_MaxElementVolume::SetMaxElementVolume ( in double  volume)
◆ SetVarParameter()
in string  method
