StdMeshers::StdMeshers_NotConformAllowed Interface Reference
StdMeshers_NotConformAllowed: interface of "Not Conform Mesh Allowed" hypothesis. More...
Inheritance diagram for StdMeshers::StdMeshers_NotConformAllowed:
string GetName ()
string GetLibName ()
short GetId ()
 Get the internal Id. More...
boolean HasParameters ()
Presence of this hypothesis permits to algorithm generation of not conform mesh.
◆ GetId()
◆ GetLibName()
◆ GetName()
◆ GetVarParameter()
◆ HasParameters()
◆ IsDimSupported()
◆ SetHolderHypothesis()
◆ SetVarParameter()
in string  method
