StdMeshers::StdMeshers_NumberOfLayers Interface Reference
StdMeshers_NumberOfLayers: interface of "Nb. Layers" hypothesis. More...
Inheritance diagram for StdMeshers::StdMeshers_NumberOfLayers:
void SetNumberOfLayers (in long numberOfLayers) raises (SALOME::SALOME_Exception)
 Sets <number of segments> parameter value. More...
long GetNumberOfLayers ()
 Returns <number of layers> parameter value. More...
string GetName ()
string GetLibName ()
short GetId ()
 Get the internal Id. More...
boolean HasParameters ()
This hypothesis is used by "Radial prism" algorithm. It specifies number of segments between the internal and the external surfaces.
◆ GetId()
◆ GetLibName()
◆ GetName()
◆ GetNumberOfLayers()
long StdMeshers::StdMeshers_NumberOfLayers::GetNumberOfLayers ( )
◆ GetVarParameter()
◆ HasParameters()
◆ IsDimSupported()
◆ SetHolderHypothesis()
◆ SetNumberOfLayers()
void StdMeshers::StdMeshers_NumberOfLayers::SetNumberOfLayers ( in long  numberOfLayers)
◆ SetVarParameter()
in string  method
