StdMeshers_Projection_2D: interface of "Projection 2D" algorithm.
More...
◆ GetCompatibleHypothesis()
| ListOfHypothesisName SMESH::SMESH_Algo::GetCompatibleHypothesis |
Get list of hypothesis that can be used with this algorithm.
◆ GetId()
| short SMESH::SMESH_Hypothesis::GetId |
◆ GetLibName()
| string SMESH::SMESH_Hypothesis::GetLibName |
◆ GetName()
| string SMESH::SMESH_Hypothesis::GetName |
◆ GetVarParameter()
| string SMESH::SMESH_Hypothesis::GetVarParameter |
in string |
methodName | ) |
◆ HasParameters()
| boolean SMESH::SMESH_Hypothesis::HasParameters |
◆ IsDimSupported()
| boolean SMESH::SMESH_Hypothesis::IsDimSupported |
in Dimension |
type | ) |
◆ SetHolderHypothesis()
◆ SetVarParameter()
| void SMESH::SMESH_Hypothesis::SetVarParameter |
in string |
parameter, |
in string |
method |
Set the variable parameter.
- Parameters
