StdMeshers_Propagation: interface of "Propagation of 1D Hyp. More...
| string | GetName () |
| Get the Hypothesis typeName. More... | |
| string | GetLibName () |
| Get the Hypothesis plugin library Name. More... | |
| short | GetId () |
| Get the internal Id. More... | |
| void | SetVarParameter (in string parameter, in string method) |
| Set the variable parameter. More... | |
| string | GetVarParameter (in string methodName) |
| Return the variable parameter used for Hypothesis creation by name of method setting this parameter. More... | |
| void | SetHolderHypothesis (in SMESH::SMESH_Hypothesis hyp) |
| Store a hypothesis wrapping this not published one. More... | |
| boolean | IsDimSupported (in Dimension type) |
| Verify whether hypothesis supports given entity type. More... | |
| boolean | HasParameters () |
| Return true if a hypothesis has parameters. More... | |
on Opposite Edges" hypothesis. Presence of this hypothesis on any edge propagates any other 1D hypothesis from this edge on all edges, opposite to it. It concerns only edges of quadrangle faces.
