◆ GetCorners()
Return IDs of corner vertices.
◆ GetEnforcedNodes()
| void StdMeshers::StdMeshers_QuadrangleParams::GetEnforcedNodes |
out GEOM::ListOfGO |
vertices, |
out SMESH::nodes_array |
points |
Returns positions of enforced nodes.
◆ GetEnfVertices()
Returns entries of shapes defining enforced nodes.
◆ GetId()
| short SMESH::SMESH_Hypothesis::GetId |
◆ GetLibName()
| string SMESH::SMESH_Hypothesis::GetLibName |
◆ GetName()
| string SMESH::SMESH_Hypothesis::GetName |
◆ GetObjectEntry()
| string StdMeshers::StdMeshers_QuadrangleParams::GetObjectEntry |
Get the entry of the main object.
◆ GetQuadType()
| QuadType StdMeshers::StdMeshers_QuadrangleParams::GetQuadType |
Get the type of quadrangulation.
◆ GetTriaVertex()
| long StdMeshers::StdMeshers_QuadrangleParams::GetTriaVertex |
Returns base vertex for triangles.
◆ GetVarParameter()
| string SMESH::SMESH_Hypothesis::GetVarParameter |
in string |
methodName | ) |
◆ HasParameters()
| boolean SMESH::SMESH_Hypothesis::HasParameters |
◆ IsDimSupported()
| boolean SMESH::SMESH_Hypothesis::IsDimSupported |
in Dimension |
type | ) |
◆ SetCorners()
| void StdMeshers::StdMeshers_QuadrangleParams::SetCorners |
in SMESH::long_array |
vertexIDs | ) |
◆ SetEnforcedNodes()
| void StdMeshers::StdMeshers_QuadrangleParams::SetEnforcedNodes |
in GEOM::ListOfGO |
vertices, |
in SMESH::nodes_array |
points |
| raises | ( | SALOME::SALOME_Exception |
Set positions of enforced nodes.
◆ SetHolderHypothesis()
◆ SetObjectEntry()
| void StdMeshers::StdMeshers_QuadrangleParams::SetObjectEntry |
in string |
entry | ) |
Set entry of the main object.
◆ SetQuadType()
| void StdMeshers::StdMeshers_QuadrangleParams::SetQuadType |
in QuadType |
type | ) |
Set the type of quadrangulation.
◆ SetTriaVertex()
| void StdMeshers::StdMeshers_QuadrangleParams::SetTriaVertex |
in long |
vertID | ) |
Set base vertex for triangles.
◆ SetVarParameter()
| void SMESH::SMESH_Hypothesis::SetVarParameter |
in string |
parameter, |
in string |
method |
Set the variable parameter.
- Parameters
