StdMeshers::StdMeshers_QuadranglePreference Interface Reference
StdMeshers_QuadranglePreference: interface of "QuadranglePreference" hypothesis. More...
Inheritance diagram for StdMeshers::StdMeshers_QuadranglePreference:
string GetName ()
string GetLibName ()
short GetId ()
 Get the internal Id. More...
boolean HasParameters ()
This hypothesis is used by StdMeshers_Quadrangle_2D algorithm. Presence of this hypothesis forces construction of quadrangles if the number of nodes on opposite edges is not the same in the case where the global number of nodes on edges is even
◆ GetId()
◆ GetLibName()
◆ GetName()
◆ GetVarParameter()
◆ HasParameters()
◆ IsDimSupported()
◆ SetHolderHypothesis()
◆ SetVarParameter()
in string  method
