StdMeshers_QuadraticMesh: interface of "QuadraticMesh" hypothesis. More...
| string | GetName () |
| Get the Hypothesis typeName. More... | |
| string | GetLibName () |
| Get the Hypothesis plugin library Name. More... | |
| short | GetId () |
| Get the internal Id. More... | |
| void | SetVarParameter (in string parameter, in string method) |
| Set the variable parameter. More... | |
| string | GetVarParameter (in string methodName) |
| Return the variable parameter used for Hypothesis creation by name of method setting this parameter. More... | |
| void | SetHolderHypothesis (in SMESH::SMESH_Hypothesis hyp) |
| Store a hypothesis wrapping this not published one. More... | |
| boolean | IsDimSupported (in Dimension type) |
| Verify whether hypothesis supports given entity type. More... | |
| boolean | HasParameters () |
| Return true if a hypothesis has parameters. More... | |
This is an auxiliary 1D hypothesis whose presence forces construction of quadratic edges. If the 2D mesher sees that all boundary edges are quadratic ones, it generates quadratic faces, else it generates linear faces using medium nodes as if they were vertex ones. The 3D mesher generates quadratic volumes only if all boundary faces are quadratic ones, else it fails.
