StdMeshers::StdMeshers_Regular_1D Interface Reference
StdMeshers_Regular_1D: interface of "Wire discretisation" algorithm. More...
Inheritance diagram for StdMeshers::StdMeshers_Regular_1D:
ListOfHypothesisName GetCompatibleHypothesis ()
 Get list of hypothesis that can be used with this algorithm. More...
string GetName ()
string GetLibName ()
short GetId ()
 Get the internal Id. More...
boolean HasParameters ()
◆ GetCompatibleHypothesis()
ListOfHypothesisName SMESH::SMESH_Algo::GetCompatibleHypothesis ( )
◆ GetId()
◆ GetLibName()
◆ GetName()
◆ GetVarParameter()
◆ HasParameters()
◆ IsDimSupported()
◆ SetHolderHypothesis()
◆ SetVarParameter()
in string  method
