StdMeshers::StdMeshers_UseExisting_1D Interface Reference
StdMeshers_UseExisting_1D: interface of "UseExisting 1D" algorithm doing nothing to allow mesh generation by mesh edition functions in TUI mode. More...
Inheritance diagram for StdMeshers::StdMeshers_UseExisting_1D:
ListOfHypothesisName GetCompatibleHypothesis ()
 Get list of hypothesis that can be used with this algorithm. More...
string GetName ()
string GetLibName ()
short GetId ()
 Get the internal Id. More...
boolean HasParameters ()
◆ GetCompatibleHypothesis()
ListOfHypothesisName SMESH::SMESH_Algo::GetCompatibleHypothesis ( )
◆ GetId()
◆ GetLibName()
◆ GetName()
◆ GetVarParameter()
◆ HasParameters()
◆ IsDimSupported()
◆ SetHolderHypothesis()
◆ SetVarParameter()
in string  method
