MED::TGrilleInfo Struct Referenceabstract
Define a base class which represents MED Grille (structured mesh) More...
#include <MED_Structures.hxx>
Inheritance diagram for MED::TGrilleInfo:
const PMeshInfo & GetMeshInfo () const
const TNodeCoord & GetNodeCoord () const
 Gives coordinates for mesh nodes (const version) More...
TNodeCoord GetCoord (TInt theId)
 Gives coordinates for mesh node by its number, array index from 0. More...
TIntVector GetConn (TInt theId, const bool isSub=false)
 Gives ids of nodes for mesh cell or sub-cell by its number, array index from 0. More...
const EGrilleType & GetGrilleType () const
 Gets grille type (const version) More...
EGrilleType GetGrilleType ()
 Gets grille type. More...
void SetGrilleType (EGrilleType theGrilleType)
 Sets grille type. More...
virtual std::string GetCoordName (TInt theId) const =0
 Get name of the coordinate dimension by its order number. More...
virtual void SetCoordName (TInt theId, const std::string &theValue)=0
 Set name of the coordinate dimension by its order number. More...
virtual std::string GetCoordUnit (TInt theId) const =0
 Get name of unit for the coordinate dimension by its order number. More...
virtual void SetCoordUnit (TInt theId, const std::string &theValue)=0
 Set name of unit for the coordinate dimension by its order number. More...
const TIndexes & GetMapOfIndexes () const
 Gets a map of Tables (const version) More...
 Gets a map of Tables. More...
const TFloatVector & GetIndexes (TInt theAxisNumber) const
 Gets a Table of indexes for certain axe(const version) More...
 Gets a Table of indexes for certain axe. More...
TInt GetNbIndexes (TInt theAxisNumber)
 Gets a number of indices per axe. More...
TInt GetNbNodes ()
TInt GetNbCells ()
 Return count of all points. More...
TInt GetNbSubCells ()
 Return count of all cells. More...
EGeometrieElement GetGeom ()
 Return count of all entities of <mesh dimension-1> More...
EGeometrieElement GetSubGeom ()
 Return geometry of cells (calculated from mesh dimension) More...
EEntiteMaillage GetEntity ()
 Return geometry of subcells (calculated from mesh dimension) More...
EEntiteMaillage GetSubEntity ()
 Return entity (eMAILLE) More...
const TIntVector & GetGrilleStructure () const
 Gets grille structure(const version) More...
TIntVector GetGrilleStructure ()
 Gets grille structure. More...
void SetGrilleStructure (TInt theAxis, TInt theNb)
 Sets the grille structure of theAxis axe to theNb. More...
TInt GetFamNum (TInt theId) const
 Get number of a MED FAMILY by order number of the mesh element. More...
void SetFamNum (TInt theId, TInt theVal)
 Set number of a MED FAMILY for the mesh element with the order number. More...
TInt GetFamSubNum (TInt theId) const
 Get number of a MED FAMILY by order number of sub element. More...
void SetFamSubNum (TInt theId, TInt theVal)
 Set number of a MED FAMILY for theId-th sub element. More...
TInt GetFamNumNode (TInt theId) const
 Get number of a MED FAMILY by order number of the mesh node. More...
void SetFamNumNode (TInt theId, TInt theVal)
 Set number of a MED FAMILY for the mesh node with the order number. More...
EModeSwitch GetModeSwitch () const
Data Fields
PMeshInfo myMeshInfo
TNodeCoord myCoord
 Contains all nodal coordinates, now used only for eGRILLE_STANDARD. More...
EGrilleType myGrilleType
 Defines grille type (eGRILLE_CARTESIENNE,eGRILLE_POLAIRE,eGRILLE_STANDARD) More...
TString myCoordNames
 Contains names for the coordinate dimensions. More...
TString myCoordUnits
 Contains units for the coordinate dimensions. More...
TIndexes myIndixes
 Map of index of axes and Table of indexes for certain axe, now used for eGRILLE_CARTESIENNE and eGRILLE_POLAIRE. More...
TIntVector myGrilleStructure
 Return sub entity. More...
TElemNum myFamNum
 Defines sequence MED Family indexes for corresponding mesh entities. More...
TElemNum myFamSubNum
 Defines sequence MED Family indexes for sub entities. More...
TElemNum myFamNumNode
 Defines sequence MED Family indexes for corresponding mesh nodes. More...
EModeSwitch myModeSwitch
 Keeps the interlace mode. More...
◆ GetConn()
TIntVector MED::TGrilleInfo::GetConn ( TInt  theId,
const bool  isSub = false
◆ GetCoord()
TNodeCoord MED::TGrilleInfo::GetCoord ( TInt  theId)
References MED::eGRILLE_CARTESIENNE, MED::eGRILLE_STANDARD, EXCEPTION, and MED::GetNbNodes().
◆ GetCoordName()
virtual std::string MED::TGrilleInfo::GetCoordName ( TInt  theId) const
pure virtual
Implemented in MED::TTGrilleInfo.
◆ GetCoordUnit()
virtual std::string MED::TGrilleInfo::GetCoordUnit ( TInt  theId) const
pure virtual
◆ GetEntity()
EEntiteMaillage MED::TGrilleInfo::GetEntity ( )
References MED::eMAILLE.
Referenced by MED::TWrapper::GetGrilleInfo().
◆ GetFamNum()
TInt MED::TGrilleInfo::GetFamNum ( TInt  theId) const
◆ GetFamNumNode()
TInt MED::TGrilleInfo::GetFamNumNode ( TInt  theId) const
◆ GetFamSubNum()
TInt MED::TGrilleInfo::GetFamSubNum ( TInt  theId) const
◆ GetGeom()
EGeometrieElement MED::TGrilleInfo::GetGeom ( )
References MED::eHEXA8, MED::eNONE, MED::eQUAD4, and MED::eSEG2.
◆ GetGrilleStructure() [1/2]
TIntVector MED::TGrilleInfo::GetGrilleStructure ( )
◆ GetGrilleStructure() [2/2]
const TIntVector & MED::TGrilleInfo::GetGrilleStructure ( ) const
◆ GetGrilleType() [1/2]
EGrilleType MED::TGrilleInfo::GetGrilleType ( )
Gets grille type.
◆ GetGrilleType() [2/2]
const EGrilleType & MED::TGrilleInfo::GetGrilleType ( ) const
◆ GetIndexes() [1/2]
TFloatVector & MED::TGrilleInfo::GetIndexes ( TInt  theAxisNumber)
References EXCEPTION.
◆ GetIndexes() [2/2]
const TFloatVector & MED::TGrilleInfo::GetIndexes ( TInt  theAxisNumber) const
Referenced by MED::TWrapper::GetGrilleInfo(), and MED::TWrapper::SetGrilleInfo().
◆ GetMapOfIndexes() [1/2]
TIndexes & MED::TGrilleInfo::GetMapOfIndexes ( )
◆ GetMapOfIndexes() [2/2]
const TIndexes & MED::TGrilleInfo::GetMapOfIndexes ( ) const
◆ GetMeshInfo()
const PMeshInfo & MED::TGrilleInfo::GetMeshInfo ( ) const
◆ GetModeSwitch()
◆ GetNbCells()
TInt MED::TGrilleInfo::GetNbCells ( )
◆ GetNbIndexes()
TInt MED::TGrilleInfo::GetNbIndexes ( TInt  theAxisNumber)
◆ GetNbNodes()
TInt MED::TGrilleInfo::GetNbNodes ( )
◆ GetNbSubCells()
TInt MED::TGrilleInfo::GetNbSubCells ( )
◆ GetNodeCoord() [1/2]
TNodeCoord & MED::TGrilleInfo::GetNodeCoord ( )
◆ GetNodeCoord() [2/2]
const TNodeCoord & MED::TGrilleInfo::GetNodeCoord ( ) const
◆ GetSubEntity()
EEntiteMaillage MED::TGrilleInfo::GetSubEntity ( )
References MED::eARETE, and MED::eFACE.
◆ GetSubGeom()
EGeometrieElement MED::TGrilleInfo::GetSubGeom ( )
References MED::eNONE, MED::eQUAD4, and MED::eSEG2.
◆ SetCoordName()
virtual void MED::TGrilleInfo::SetCoordName ( TInt  theId,
const std::string &  theValue
pure virtual
◆ SetCoordUnit()
virtual void MED::TGrilleInfo::SetCoordUnit ( TInt  theId,
pure virtual
◆ SetFamNum()
void MED::TGrilleInfo::SetFamNum ( TInt  theId,
TInt  theVal
◆ SetFamNumNode()
void MED::TGrilleInfo::SetFamNumNode ( TInt  theId,
TInt  theVal
◆ SetFamSubNum()
void MED::TGrilleInfo::SetFamSubNum ( TInt  theId,
TInt  theVal
◆ SetGrilleStructure()
void MED::TGrilleInfo::SetGrilleStructure ( TInt  theAxis,
TInt  theNb
◆ SetGrilleType()
void MED::TGrilleInfo::SetGrilleType ( EGrilleType  theGrilleType)
Sets grille type.
◆ myCoord
TNodeCoord MED::TGrilleInfo::myCoord
Referenced by MED::TWrapper::GetGrilleInfo(), MED::TWrapper::SetGrilleInfo(), and MED::TTGrilleInfo::TTGrilleInfo().
◆ myCoordNames
◆ myCoordUnits
◆ myFamNum
TElemNum MED::TGrilleInfo::myFamNum
Referenced by MED::TWrapper::GetGrilleInfo(), and MED::TTGrilleInfo::TTGrilleInfo().
◆ myFamNumNode
TElemNum MED::TGrilleInfo::myFamNumNode
◆ myFamSubNum
TElemNum MED::TGrilleInfo::myFamSubNum
◆ myGrilleStructure
TIntVector MED::TGrilleInfo::myGrilleStructure
Return sub entity.
Vector of grille structure (Example: {3,4,5}, 3 nodes in X axe, 4 nodes in Y axe, ...)
◆ myGrilleType
EGrilleType MED::TGrilleInfo::myGrilleType
◆ myIndixes
TIndexes MED::TGrilleInfo::myIndixes
Referenced by MED::TTGrilleInfo::TTGrilleInfo().
◆ myMeshInfo
◆ myModeSwitch
