PMMLlib.hxx
1// Copyright (C) 2013-2026 CEA
3// This program is free software: you can redistribute it and/or modify
4// it under the terms of the GNU Lesser General Public License as published
5// by the Free Software Foundation, either version 3 of the License, or any
6// later version.
8// This program is distributed in the hope that it will be useful,
10// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
11// GNU Lesser General Public License for more details.
13// You should have received a copy of the GNU Lesser General Public License
14// along with this program. If not, see <http://www.gnu.org/licenses/>.
15
25#ifndef __PMMLLIB_H__
26#define __PMMLLIB_H__
27
28#include "PMMLwin.hxx"
30#include <libxml/xpathInternals.h>
31#include <string>
32#include <vector>
33#include <sstream>
34
35namespace PMMLlib
36{
37
38template <typename T>
39std::string NumberToString ( T Number )
40{
41 std::ostringstream ss;
42 ss << Number;
43 return ss.str();
44}
45
55
56
61
62
67
68
73{
74
75private:
76 bool _log;
77 std::string _pmmlFile;
78 xmlDocPtr _doc;
79 xmlNodePtr _rootNode;
80 xmlNodePtr _currentNode;
82 std::string _currentModelName;
84 xmlNodePtr _currentModelNode;
85
90public:
91 PMMLLIB_EXPORT PMMLlib(std::string file,
92 bool log=false) ;
93 PMMLLIB_EXPORT PMMLlib(bool log=false);
95 PMMLLIB_EXPORT void SetCurrentModel(std::string modelName,
96 PMMLType type);
97 PMMLLIB_EXPORT void SetCurrentModel(std::string modelName);
98 PMMLLIB_EXPORT void SetCurrentModel();
99 PMMLLIB_EXPORT std::string makeLog() const;
100 PMMLLIB_EXPORT void printLog() const;
101
102 PMMLLIB_EXPORT void AddDataField(std::string name,
103 std::string displayName,
104 std::string optype,
105 std::string dataType,
106 std::string closure,
107 double leftMargin,
108 double rightMargin,
109 bool interval=false);
110 PMMLLIB_EXPORT void AddMiningSchema(std::string name,
111 std::string usageType);
112 PMMLLIB_EXPORT void SetHeader(std::string copyright,
113 std::string description,
114 std::string appName,
115 std::string appVersion,
116 std::string annotation);
117 PMMLLIB_EXPORT void UnlinkNode();
118 PMMLLIB_EXPORT void BackupNode();
119 PMMLLIB_EXPORT int GetModelsNb();
120 PMMLLIB_EXPORT void Write();
121 PMMLLIB_EXPORT void Write(std::string file);
122 PMMLLIB_EXPORT PMMLType GetCurrentModelType();
123 PMMLLIB_EXPORT std::string GetCurrentModelName();
124private:
125 xmlNodePtr GetChildByName(xmlNodePtr node,
126 std::string nodename);
127 xmlNodePtr GetPtr(int ann_index,
128 std::string name);
129 xmlNodePtr GetPtr(std::string ann_name,
130 std::string name);
131 void CountModels();
132 int CountNeuralNetModels();
133 int CountRegressionModels();
134 void SetRootNode();
135 std::string GetModelName(xmlNodePtr node);
136 std::string GetTypeString();
137 // end of group general
139
140
145public:
146 PMMLLIB_EXPORT void AddNeuralNetwork(std::string modelName,
147 PMMLMiningFunction functionName);
148 PMMLLIB_EXPORT void AddNeuralInput(int id,
149 std::string inputName,
150 std::string optype,
151 std::string dataType,
152 double orig1, double norm1,
153 double orig2, double norm2);
154 PMMLLIB_EXPORT void AddNeuralLayer(PMMLActivationFunction activationFunction);
155 PMMLLIB_EXPORT void AddNeuron(int id,
156 double bias,
157 int conNb,
158 int firstFrom,
159 std::vector<double> weights);
160 PMMLLIB_EXPORT void AddNeuralOutput(int outputNeuron,
161 std::string outputName,
162 std::string optype,
163 std::string dataType,
164 double orig1, double norm1,
165 double orig2, double norm2);
166 PMMLLIB_EXPORT int GetNbInputs();
167 PMMLLIB_EXPORT int GetNbOutputs();
168 PMMLLIB_EXPORT std::string GetNameInput(int input_index);
169 PMMLLIB_EXPORT std::string GetNameOutput(int output_index);
170 PMMLLIB_EXPORT int GetNormalizationType();
171 PMMLLIB_EXPORT void GetNormalisationInput(int input_index,
172 double *dnorm);
173 PMMLLIB_EXPORT void GetNormalisationOutput(int output_index,
174 double *dnorm);
175 PMMLLIB_EXPORT int GetNbHiddenLayers();
176 PMMLLIB_EXPORT int GetNbLayers();
177 PMMLLIB_EXPORT int GetNbNeuronsAtLayer(int layer_index);
178 PMMLLIB_EXPORT double GetNeuronBias(int layer_index,
179 int neu_index);
180 PMMLLIB_EXPORT double GetPrecNeuronSynapse(int layer_index,
181 int neu_index,
182 int prec_index);
183 PMMLLIB_EXPORT void SetNeuralNetName(int ann_index,
184 std::string ann_name);
185 PMMLLIB_EXPORT std::string ReadNetworkStructure();
186private:
187 xmlNodePtr GetNeuralNetPtr(std::string ann_name);
188 xmlNodePtr GetNeuralNetPtr(int ann_index);
189 void CheckNeuralNetwork(); // end of group ann
191
192
197public:
198 PMMLLIB_EXPORT void AddRegressionModel(std::string modelName,
199 PMMLMiningFunction functionName,
200 std::string targetFieldName);
201 PMMLLIB_EXPORT void AddRegressionTable();
202 PMMLLIB_EXPORT void AddRegressionTable(double intercept);
203 PMMLLIB_EXPORT void AddNumericPredictor(std::string neuronName,
204 int exponent,
205 double coefficient);
206 PMMLLIB_EXPORT void AddPredictorTerm(double coefficient,
207 std::vector<std::string> fieldRef);
208 PMMLLIB_EXPORT bool HasIntercept();
209 PMMLLIB_EXPORT double GetRegressionTableIntercept();
210 PMMLLIB_EXPORT int GetNumericPredictorNb();
211 PMMLLIB_EXPORT int GetPredictorTermNb();
212 PMMLLIB_EXPORT std::string GetNumericPredictorName(int num_pred_index);
213 PMMLLIB_EXPORT std::string GetPredictorTermName(int num_pred_index);
214 PMMLLIB_EXPORT double GetNumericPredictorCoefficient(int num_pred_index);
215 PMMLLIB_EXPORT double GetPredictorTermCoefficient(int pred_term_index);
216 PMMLLIB_EXPORT int GetPredictorTermFieldRefNb(int pred_term_index);
217 PMMLLIB_EXPORT std::string GetPredictorTermFieldRefName(int pred_term_index,
218 int field_index);
219 PMMLLIB_EXPORT std::string ReadRegressionStructure();
220private:
221 xmlNodePtr GetRegressionPtr(int reg_index);
222 xmlNodePtr GetRegressionPtr(std::string reg_name);
223 void CheckRegression();
224 // end of group ln
226
227
232private:
233 void fillVectorsForExport(int nInput, int nOutput, int nHidden, int normType,
234 std::vector<double> &minInput, std::vector<double> &maxInput,
235 std::vector<double> &minOutput, std::vector<double> &maxOutput,
236 std::vector<double> &valW );
237public:
238 PMMLLIB_EXPORT void ExportCpp(std::string file,
239 std::string functionName,
240 std::string header);
241 PMMLLIB_EXPORT void ExportFortran(std::string file,
242 std::string functionName,
243 std::string header);
244 PMMLLIB_EXPORT void ExportPython(std::string file,
245 std::string functionName,
246 std::string header);
247 PMMLLIB_EXPORT std::string ExportPyStr(std::string functionName,
248 std::string header);
249private:
250 void ExportNeuralNetworkCpp(std::string file,
251 std::string functionName,
252 std::string header);
253 void ExportNeuralNetworkFortran(std::string file,
254 std::string functionName,
255 std::string header);
256 void ExportNeuralNetworkPython(std::string file,
257 std::string functionName,
258 std::string header);
259 std::string ExportNeuralNetworkPyStr(std::string functionName,
260 std::string header);
261
262 void ExportLinearRegressionCpp(std::string,
263 std::string,
264 std::string);
265 void ExportLinearRegressionFortran(std::string,
266 std::string,
267 std::string);
268 void ExportLinearRegressionPython(std::string,
269 std::string,
270 std::string);
271 std::string ExportLinearRegressionPyStr(std::string functionName,
272 std::string header); // end of group export
274
275 private:
281 std::string _xmlCharToString(const xmlChar *xs) const;
291 xmlChar * _stringToXmlChar(const std::string &s) const;
292
293 std::string _getProp(const xmlNodePtr node,
294 std::string const & prop ) const;
295
296};
297
298}
299
300#endif //__PMMLLIB_H__
#define PMMLLIB_EXPORT
Definition: PMMLwin.hxx:42
Name of the associated PMML file.
Definition: PMMLlib.hxx:77
Pointer to the current model node
Definition: PMMLlib.hxx:84
bool _log
Log Printing.
Definition: PMMLlib.hxx:76
int _nbModels
Number of models (all kinds)
Definition: PMMLlib.hxx:81
Name of the current model
Definition: PMMLlib.hxx:82
xmlDocPtr _doc
Associated DOM documents.
Definition: PMMLlib.hxx:78
PMMLType _currentModelType
Type of the current model.
Definition: PMMLlib.hxx:83
Root node of the document.
Definition: PMMLlib.hxx:79
Pointer to the current node
Definition: PMMLlib.hxx:80
@ kANN
Definition: PMMLlib.hxx:54
@ kUNDEFINED
PMMLMiningFunction
Definition: PMMLlib.hxx:66
@ kREGRESSION
Definition: PMMLlib.hxx:60
@ kIDENTITY
@ kTANH
@ kLOGISTIC
std::string NumberToString(T Number)
Definition: PMMLlib.hxx:39
string log
Definition: logview.py:23
