PMMLlib::PMMLlib Class Reference
#include <PMMLlib.hxx>
Collaboration diagram for PMMLlib::PMMLlib:
PMMLLIB_EXPORT PMMLlib (std::string file, bool log=false)
PMMLLIB_EXPORT PMMLlib (bool log=false)
 This constructor is mandatory for Swig because it can be used with no parameters. More...
PMMLLIB_EXPORT ~PMMLlib ()
PMMLLIB_EXPORT void SetCurrentModel (std::string modelName, PMMLType type)
PMMLLIB_EXPORT void SetCurrentModel (std::string modelName)
 Throw an exception if there is no model or more than one model with name "modelName" in the PMML file. More...
PMMLLIB_EXPORT void SetCurrentModel ()
 Throw an exception if no model is found or if there are more than one model in the PMLL file. More...
PMMLLIB_EXPORT std::string makeLog () const
PMMLLIB_EXPORT void printLog () const
PMMLLIB_EXPORT void AddDataField (std::string name, std::string displayName, std::string optype, std::string dataType, std::string closure, double leftMargin, double rightMargin, bool interval=false)
PMMLLIB_EXPORT void AddMiningSchema (std::string name, std::string usageType)
 Common to all models. More...
PMMLLIB_EXPORT void SetHeader (std::string copyright, std::string description, std::string appName, std::string appVersion, std::string annotation)
PMMLLIB_EXPORT void UnlinkNode ()
PMMLLIB_EXPORT void BackupNode ()
PMMLLIB_EXPORT int GetModelsNb ()
PMMLLIB_EXPORT void Write ()
PMMLLIB_EXPORT void Write (std::string file)
PMMLLIB_EXPORT PMMLType GetCurrentModelType ()
 type is kUNDEFINED if no model is set or if model type is not handled More...
PMMLLIB_EXPORT std::string GetCurrentModelName ()
 name is "" if no model is set More...
PMMLLIB_EXPORT void AddNeuralNetwork (std::string modelName, PMMLMiningFunction functionName)
 Specific to NeuralNetwork. More...
PMMLLIB_EXPORT void AddNeuralInput (int id, std::string inputName, std::string optype, std::string dataType, double orig1, double norm1, double orig2, double norm2)
PMMLLIB_EXPORT void AddNeuralLayer (PMMLActivationFunction activationFunction)
PMMLLIB_EXPORT void AddNeuron (int id, double bias, int conNb, int firstFrom, std::vector< double > weights)
PMMLLIB_EXPORT void AddNeuralOutput (int outputNeuron, std::string outputName, std::string optype, std::string dataType, double orig1, double norm1, double orig2, double norm2)
PMMLLIB_EXPORT int GetNbInputs ()
PMMLLIB_EXPORT int GetNbOutputs ()
PMMLLIB_EXPORT std::string GetNameInput (int input_index)
PMMLLIB_EXPORT std::string GetNameOutput (int output_index)
PMMLLIB_EXPORT int GetNormalizationType ()
PMMLLIB_EXPORT void GetNormalisationInput (int input_index, double *dnorm)
PMMLLIB_EXPORT void GetNormalisationOutput (int output_index, double *dnorm)
PMMLLIB_EXPORT int GetNbHiddenLayers ()
PMMLLIB_EXPORT int GetNbLayers ()
PMMLLIB_EXPORT int GetNbNeuronsAtLayer (int layer_index)
PMMLLIB_EXPORT double GetNeuronBias (int layer_index, int neu_index)
PMMLLIB_EXPORT double GetPrecNeuronSynapse (int layer_index, int neu_index, int prec_index)
PMMLLIB_EXPORT void SetNeuralNetName (int ann_index, std::string ann_name)
 Not tested. More...
PMMLLIB_EXPORT std::string ReadNetworkStructure ()
PMMLLIB_EXPORT void AddRegressionModel (std::string modelName, PMMLMiningFunction functionName, std::string targetFieldName)
 Specific to RegressionModel. More...
PMMLLIB_EXPORT void AddRegressionTable ()
 No property "intercept" will be set. More...
PMMLLIB_EXPORT void AddRegressionTable (double intercept)
PMMLLIB_EXPORT void AddNumericPredictor (std::string neuronName, int exponent, double coefficient)
PMMLLIB_EXPORT void AddPredictorTerm (double coefficient, std::vector< std::string > fieldRef)
More...
PMMLLIB_EXPORT bool HasIntercept ()
More...
PMMLLIB_EXPORT double GetRegressionTableIntercept ()
More...
PMMLLIB_EXPORT int GetNumericPredictorNb ()
More...
PMMLLIB_EXPORT int GetPredictorTermNb ()
More...
PMMLLIB_EXPORT std::string GetNumericPredictorName (int num_pred_index)
More...
PMMLLIB_EXPORT std::string GetPredictorTermName (int num_pred_index)
More...
PMMLLIB_EXPORT double GetNumericPredictorCoefficient (int num_pred_index)
 (The coefficient is the value of property "coefficient") More...
PMMLLIB_EXPORT double GetPredictorTermCoefficient (int pred_term_index)
PMMLLIB_EXPORT int GetPredictorTermFieldRefNb (int pred_term_index)
More...
PMMLLIB_EXPORT std::string GetPredictorTermFieldRefName (int pred_term_index, int field_index)
 (The name is the value of property "field") More...
PMMLLIB_EXPORT std::string ReadRegressionStructure ()
PMMLLIB_EXPORT void ExportCpp (std::string file, std::string functionName, std::string header)
PMMLLIB_EXPORT void ExportFortran (std::string file, std::string functionName, std::string header)
PMMLLIB_EXPORT void ExportPython (std::string file, std::string functionName, std::string header)
PMMLLIB_EXPORT std::string ExportPyStr (std::string functionName, std::string header)
xmlNodePtr GetChildByName (xmlNodePtr node, std::string nodename)
xmlNodePtr GetPtr (int ann_index, std::string name)
xmlNodePtr GetPtr (std::string ann_name, std::string name)
void CountModels ()
int CountNeuralNetModels ()
int CountRegressionModels ()
void SetRootNode ()
std::string GetModelName (xmlNodePtr node)
std::string GetTypeString ()
xmlNodePtr GetNeuralNetPtr (std::string ann_name)
xmlNodePtr GetNeuralNetPtr (int ann_index)
void CheckNeuralNetwork ()
 Called in all methods specific to the NeuralNetwork model. More...
xmlNodePtr GetRegressionPtr (int reg_index)
xmlNodePtr GetRegressionPtr (std::string reg_name)
void CheckRegression ()
 Called in all methods specific to the RegressionModel model. More...
void fillVectorsForExport (int nInput, int nOutput, int nHidden, int normType, std::vector< double > &minInput, std::vector< double > &maxInput, std::vector< double > &minOutput, std::vector< double > &maxOutput, std::vector< double > &valW)
void ExportNeuralNetworkCpp (std::string file, std::string functionName, std::string header)
void ExportNeuralNetworkFortran (std::string file, std::string functionName, std::string header)
void ExportNeuralNetworkPython (std::string file, std::string functionName, std::string header)
std::string ExportNeuralNetworkPyStr (std::string functionName, std::string header)
void ExportLinearRegressionCpp (std::string, std::string, std::string)
More...
void ExportLinearRegressionFortran (std::string, std::string, std::string)
 Specific to Regression. More...
void ExportLinearRegressionPython (std::string, std::string, std::string)
std::string ExportLinearRegressionPyStr (std::string functionName, std::string header)
std::string _xmlCharToString (const xmlChar *xs) const
xmlChar * _stringToXmlChar (const std::string &s) const
std::string _getProp (const xmlNodePtr node, std::string const &prop) const
bool _log
 Log Printing. More...
std::string _pmmlFile
 Name of the associated PMML file. More...
xmlDocPtr _doc
 Associated DOM documents. More...
xmlNodePtr _rootNode
 Root node of the document. More...
xmlNodePtr _currentNode
 Pointer to the current node
More...
int _nbModels
 Number of models (all kinds) More...
std::string _currentModelName
 Name of the current model
More...
PMMLType _currentModelType
 Type of the current model. More...
xmlNodePtr _currentModelNode
 Pointer to the current model node
More...
Class PMMLlib
Definition at line 72 of file PMMLlib.hxx.
◆ _getProp()
std::string PMMLlib::PMMLlib::_getProp ( const xmlNodePtr  node,
std::string const &  prop
Get the value of a node property.
nodeTag
propProperty
Constant libxml string.
Definition at line 694 of file PMMLlib.cxx.
696{
697 std::string name("");
698 if (_doc != NULL)
699 {
700 xmlChar *xp = _stringToXmlChar(prop);
701 xmlChar * attr ;
702 attr = xmlGetProp(node, xp );
703 if ( attr )
704 {
705 name = _xmlCharToString(attr );
706 xmlFree(attr);
707 }
708 xmlFree(xp);
709 }
710 return name;
711}
xmlChar * _stringToXmlChar(const std::string &s) const
Definition: PMMLlib.cxx:683
std::string _xmlCharToString(const xmlChar *xs) const
Definition: PMMLlib.cxx:669
xmlDocPtr _doc
Definition: PMMLlib.hxx:78
◆ _stringToXmlChar()
xmlChar * PMMLlib::PMMLlib::_stringToXmlChar ( const std::string &  s) const
Conversion from a standard C++ string to a libxml2 string (xmlChar *)
sa constant C++ std::string.
a libxml string (contains the same text as s)
The caller of this function must free the result when it's not needed anymore (using xmlFree)
Conversion from a a standard C++ string to a libxml2 string (xmlChar *).
sConstant C++ std::string (contains the same text as xs)
Definition at line 683 of file PMMLlib.cxx.
684{
685 return xmlCharStrdup(s.c_str());
686}
◆ _xmlCharToString()
std::string PMMLlib::PMMLlib::_xmlCharToString ( const xmlChar *  xs) const
  • Conversion from a libxml2 string (xmlChar *) to a standard C++ string.
xsa constant libxml string.
a C++ std::string (contains the same text as xs).
Definition at line 669 of file PMMLlib.cxx.
670{
671 size_t i, L = xmlStrlen(xs);
672 std::string s;
673 s.resize(L);
674 for (i=0; *xs; s[i++] = *xs++);
675 return s;
676}
References yacsorb.CORBAEngineTest::i.
◆ _currentModelName
std::string PMMLlib::PMMLlib::_currentModelName
Definition at line 82 of file PMMLlib.hxx.
◆ _currentModelNode
xmlNodePtr PMMLlib::PMMLlib::_currentModelNode
Definition at line 84 of file PMMLlib.hxx.
◆ _currentModelType
PMMLType PMMLlib::PMMLlib::_currentModelType
Definition at line 83 of file PMMLlib.hxx.
◆ _currentNode
xmlNodePtr PMMLlib::PMMLlib::_currentNode
Definition at line 80 of file PMMLlib.hxx.
◆ _doc
xmlDocPtr PMMLlib::PMMLlib::_doc
Definition at line 78 of file PMMLlib.hxx.
◆ _log
bool PMMLlib::PMMLlib::_log
Log Printing.
Definition at line 76 of file PMMLlib.hxx.
◆ _nbModels
int PMMLlib::PMMLlib::_nbModels
Definition at line 81 of file PMMLlib.hxx.
◆ _pmmlFile
std::string PMMLlib::PMMLlib::_pmmlFile
Definition at line 77 of file PMMLlib.hxx.
◆ _rootNode
xmlNodePtr PMMLlib::PMMLlib::_rootNode
Definition at line 79 of file PMMLlib.hxx.
