Functions | |
| PMMLLIB_EXPORT | PMMLlib::PMMLlib::PMMLlib (std::string file, bool log=false) |
| PMMLLIB_EXPORT | PMMLlib::PMMLlib::PMMLlib (bool log=false) |
| This constructor is mandatory for Swig because it can be used with no parameters. More... | |
| PMMLLIB_EXPORT | PMMLlib::PMMLlib::~PMMLlib () |
| PMMLLIB_EXPORT void | PMMLlib::PMMLlib::SetCurrentModel (std::string modelName, PMMLType type) |
| PMMLLIB_EXPORT void | PMMLlib::PMMLlib::SetCurrentModel (std::string modelName) |
| Throw an exception if there is no model or more than one model with name "modelName" in the PMML file. More... | |
| PMMLLIB_EXPORT void | PMMLlib::PMMLlib::SetCurrentModel () |
| Throw an exception if no model is found or if there are more than one model in the PMLL file. More... | |
| PMMLLIB_EXPORT std::string | PMMLlib::PMMLlib::makeLog () const |
| PMMLLIB_EXPORT void | PMMLlib::PMMLlib::printLog () const |
| PMMLLIB_EXPORT void | PMMLlib::PMMLlib::AddDataField (std::string name, std::string displayName, std::string optype, std::string dataType, std::string closure, double leftMargin, double rightMargin, bool interval=false) |
| PMMLLIB_EXPORT void | PMMLlib::PMMLlib::AddMiningSchema (std::string name, std::string usageType) |
| Common to all models. More... | |
| PMMLLIB_EXPORT void | PMMLlib::PMMLlib::SetHeader (std::string copyright, std::string description, std::string appName, std::string appVersion, std::string annotation) |
| PMMLLIB_EXPORT void | PMMLlib::PMMLlib::UnlinkNode () |
| PMMLLIB_EXPORT void | PMMLlib::PMMLlib::BackupNode () |
| PMMLLIB_EXPORT int | PMMLlib::PMMLlib::GetModelsNb () |
| PMMLLIB_EXPORT void | PMMLlib::PMMLlib::Write () |
| PMMLLIB_EXPORT void | PMMLlib::PMMLlib::Write (std::string file) |
| PMMLLIB_EXPORT PMMLType | PMMLlib::PMMLlib::GetCurrentModelType () |
| type is kUNDEFINED if no model is set or if model type is not handled More... | |
| PMMLLIB_EXPORT std::string | PMMLlib::PMMLlib::GetCurrentModelName () |
| name is "" if no model is set More... | |
| xmlNodePtr | PMMLlib::PMMLlib::GetChildByName (xmlNodePtr node, std::string nodename) |
| xmlNodePtr | PMMLlib::PMMLlib::GetPtr (int ann_index, std::string name) |
| xmlNodePtr | PMMLlib::PMMLlib::GetPtr (std::string ann_name, std::string name) |
| void | PMMLlib::PMMLlib::CountModels () |
| int | PMMLlib::PMMLlib::CountNeuralNetModels () |
| int | PMMLlib::PMMLlib::CountRegressionModels () |
| void | PMMLlib::PMMLlib::SetRootNode () |
| std::string | PMMLlib::PMMLlib::GetModelName (xmlNodePtr node) |
| std::string | PMMLlib::PMMLlib::GetTypeString () |
Common methods to all kinds of PMML files and models
| void PMMLlib::PMMLlib::AddDataField | ( | std::string | fieldName, |
| std::string | displayName, | ||
| std::string | optype, | ||
| std::string | dataType, | ||
| std::string | closure, | ||
| double | leftMargin, | ||
| double | rightMargin, | ||
| bool | interval = false |
Add a DataField node to the DataDictionnary node
| fieldName | Value of property "name" |
| displayName | Value of property "displayName" |
| optype | Value of property "optype" |
| dataType | Value of property "dataType" |
| closure | Value of property "closure" in node Interval |
| leftMargin | Value of property "leftMargin" in node Interval |
| rightMargin | Value of property "rightMargin" in node Interval |
| interval | Flag to add a node Interval (if true) |
Definition at line 1317 of file PMMLlib.cxx.
| void PMMLlib::PMMLlib::AddMiningSchema | ( | std::string | name, |
| std::string | usageType | ||
Add the MiningSchema node.
| name | Value of property "name". |
| usageType | Value of property "usageType". |
Definition at line 286 of file PMMLlib.cxx.
| void PMMLlib::PMMLlib::BackupNode | ( | ) |
Make a backup of the current model node.
Definition at line 535 of file PMMLlib.cxx.
private |
Count the tags of all types of models (NeuralNetwork and RegressionModel).
Definition at line 341 of file PMMLlib.cxx.
private |
Count NeuralNetwork models tags in the PMML file.
Definition at line 354 of file PMMLlib.cxx.
private |
Count RegressionModel models tags in the PMML file.
Definition at line 375 of file PMMLlib.cxx.
private |
Get the child of a node from the name of this node
| node | Start node for the research |
| nodeName | Name of the node to find |
Definition at line 310 of file PMMLlib.cxx.
| std::string PMMLlib::PMMLlib::GetCurrentModelName | ( | ) |
Get the current model name.
Definition at line 514 of file PMMLlib.cxx.
| PMMLType PMMLlib::PMMLlib::GetCurrentModelType | ( | ) |
Get the current model type.
Definition at line 496 of file PMMLlib.cxx.
References PMMLlib::kANN, PMMLlib::kLR, and PMMLlib::kUNDEFINED.
private |
Get the name of the XML node of a given model
| node | Model node |
Definition at line 406 of file PMMLlib.cxx.
| int PMMLlib::PMMLlib::GetModelsNb | ( | ) |
private |
Get a pointer to the index-th node named name
| index | Index of the node to search |
| name | Name of the node |
Definition at line 419 of file PMMLlib.cxx.
References yacsorb.CORBAEngineTest::i.
private |
Get a pointer to the node named name whose 'modelName' attribute is ann_name
| modelName | Model name of the node to search |
| nodeName | Name of the node |
Definition at line 445 of file PMMLlib.cxx.
private |
Get the tag of the current model.
Definition at line 473 of file PMMLlib.cxx.
References PMMLlib::kANN, and PMMLlib::kLR.
| std::string PMMLlib::PMMLlib::makeLog | ( | ) | const |
Make the string used by PMMLlib::printLog.
Definition at line 213 of file PMMLlib.cxx.
| PMMLlib::PMMLlib::PMMLlib | ( | bool | log = false | ) |
Constructor to create a PMML file.
| log | Flag to print logs or not |
Definition at line 94 of file PMMLlib.cxx.
| PMMLlib::PMMLlib::PMMLlib | ( | std::string | file, |
Constructor to read a PMML file.
| file | Name of the PMML file to read |
Definition at line 57 of file PMMLlib.cxx.
| void PMMLlib::PMMLlib::printLog | ( | ) | const |
Print some information about the current PMML object.
Definition at line 226 of file PMMLlib.cxx.
References gui.logview::log.
| void PMMLlib::PMMLlib::SetCurrentModel | ( | ) |
Set the current model and its type.
Definition at line 183 of file PMMLlib.cxx.
| void PMMLlib::PMMLlib::SetCurrentModel | ( | std::string | modelName | ) |
| modelName | Name of the model to load (ie content of 'modelName' attribute) |
Definition at line 150 of file PMMLlib.cxx.
| void PMMLlib::PMMLlib::SetCurrentModel | ( | std::string | modelName, |
| PMMLType | type | ||
| type | Type of PMML to read: one of kANN or kLR |
Definition at line 124 of file PMMLlib.cxx.
| void PMMLlib::PMMLlib::SetHeader | ( | std::string | copyright, |
| std::string | description, | ||
| std::string | appName, | ||
| std::string | appVersion, | ||
| std::string | annotation | ||
Set the header node in the tree.
| copyright | Copyright of the PMML file |
| description | Description of the model |
| appName | Name of the application that produced the file |
| appVersion | Version of the application that produced the file |
| annotation | Some annotation |
Definition at line 263 of file PMMLlib.cxx.
private |
Set the root node in the tree:
Definition at line 238 of file PMMLlib.cxx.
| void PMMLlib::PMMLlib::UnlinkNode | ( | ) |
Unlink the current model node.
Definition at line 525 of file PMMLlib.cxx.
| void PMMLlib::PMMLlib::Write | ( | ) |
Save the XML tree in the PMML file
Definition at line 564 of file PMMLlib.cxx.
| void PMMLlib::PMMLlib::Write | ( | std::string | file | ) |
Save the XML tree in a given file
| Name | of the file |
Definition at line 576 of file PMMLlib.cxx.
| PMMLlib::PMMLlib::~PMMLlib | ( | ) |
Destructor of the class.
Definition at line 110 of file PMMLlib.cxx.
