Methods dedicated to neural networks
PMMLLIB_EXPORT void PMMLlib::PMMLlib::AddNeuralNetwork (std::string modelName, PMMLMiningFunction functionName)
 Specific to NeuralNetwork. More...
PMMLLIB_EXPORT void PMMLlib::PMMLlib::AddNeuralInput (int id, std::string inputName, std::string optype, std::string dataType, double orig1, double norm1, double orig2, double norm2)
PMMLLIB_EXPORT void PMMLlib::PMMLlib::AddNeuralLayer (PMMLActivationFunction activationFunction)
PMMLLIB_EXPORT void PMMLlib::PMMLlib::AddNeuron (int id, double bias, int conNb, int firstFrom, std::vector< double > weights)
PMMLLIB_EXPORT void PMMLlib::PMMLlib::AddNeuralOutput (int outputNeuron, std::string outputName, std::string optype, std::string dataType, double orig1, double norm1, double orig2, double norm2)
PMMLLIB_EXPORT int PMMLlib::PMMLlib::GetNbInputs ()
PMMLLIB_EXPORT int PMMLlib::PMMLlib::GetNbOutputs ()
PMMLLIB_EXPORT std::string PMMLlib::PMMLlib::GetNameInput (int input_index)
PMMLLIB_EXPORT std::string PMMLlib::PMMLlib::GetNameOutput (int output_index)
PMMLLIB_EXPORT int PMMLlib::PMMLlib::GetNormalizationType ()
PMMLLIB_EXPORT void PMMLlib::PMMLlib::GetNormalisationInput (int input_index, double *dnorm)
PMMLLIB_EXPORT void PMMLlib::PMMLlib::GetNormalisationOutput (int output_index, double *dnorm)
PMMLLIB_EXPORT int PMMLlib::PMMLlib::GetNbHiddenLayers ()
PMMLLIB_EXPORT int PMMLlib::PMMLlib::GetNbLayers ()
PMMLLIB_EXPORT int PMMLlib::PMMLlib::GetNbNeuronsAtLayer (int layer_index)
PMMLLIB_EXPORT double PMMLlib::PMMLlib::GetNeuronBias (int layer_index, int neu_index)
PMMLLIB_EXPORT double PMMLlib::PMMLlib::GetPrecNeuronSynapse (int layer_index, int neu_index, int prec_index)
PMMLLIB_EXPORT void PMMLlib::PMMLlib::SetNeuralNetName (int ann_index, std::string ann_name)
 Not tested. More...
PMMLLIB_EXPORT std::string PMMLlib::PMMLlib::ReadNetworkStructure ()
xmlNodePtr PMMLlib::PMMLlib::GetNeuralNetPtr (std::string ann_name)
xmlNodePtr PMMLlib::PMMLlib::GetNeuralNetPtr (int ann_index)
void PMMLlib::PMMLlib::CheckNeuralNetwork ()
 Called in all methods specific to the NeuralNetwork model. More...
◆ AddNeuralInput()
void PMMLlib::PMMLlib::AddNeuralInput ( int  id,
std::string  optype,
double  orig1,
double  norm1,
double  orig2,
double  norm2
Add a NeuralInput node to the current model.
idId of the input
inputNameName of the input
optypeValue of property "optype"
dataTypeValue of property "dataType"
orig1Value of the first origin
norm1Value of the first norm
orig2Value of the second origin
norm2Value of the second norm
Definition at line 1394 of file PMMLlib.cxx.
1400{
1402
1403 xmlNodePtr netNode = _currentModelNode;
1404 // if 'NeuralInputs' node does not exist, create it
1405 xmlNodePtr neuralInputsNode = GetChildByName(netNode, "NeuralInputs");
1406 if(!neuralInputsNode)
1407 {
1408 neuralInputsNode = xmlNewChild(netNode, 0, (const xmlChar*)"NeuralInputs", 0);
1409 xmlNewProp(neuralInputsNode, (const xmlChar*)"numberOfInputs", (const xmlChar*)"0" );
1410 }
1411 // increment the number of inputs
1412 string numberOfInputsStr = _getProp(neuralInputsNode, string("numberOfInputs"));
1413 int numberOfInputs;
1414 istringstream( numberOfInputsStr ) >> numberOfInputs;
1415 numberOfInputs++;
1416 stringstream ss;
1417 ss << numberOfInputs;
1418 xmlSetProp(neuralInputsNode, (const xmlChar*)"numberOfInputs", (const xmlChar*)(ss.str().c_str()) );
1419 // then append the node and its children
1420 xmlNodePtr neuralInputNode = xmlNewChild(neuralInputsNode, 0, (const xmlChar*)"NeuralInput", 0);
1421 ss.str(""); ss << id;
1422 xmlNewProp(neuralInputNode, (const xmlChar*)"id", (const xmlChar*)(ss.str().c_str()) );
1423
1424 xmlNodePtr derivedFieldNode = xmlNewChild(neuralInputNode, 0, (const xmlChar*)"DerivedField", 0);
1425 xmlNewProp(derivedFieldNode, (const xmlChar*)"optype", (const xmlChar*)(optype.c_str()) );
1426 xmlNewProp(derivedFieldNode, (const xmlChar*)"dataType", (const xmlChar*)(dataType.c_str()) );
1427
1428 xmlNodePtr normcontNode = xmlNewChild(derivedFieldNode, 0, (const xmlChar*)"NormContinuous", 0);
1429 xmlNewProp(normcontNode, (const xmlChar*)"field", (const xmlChar*)(inputName.c_str()) );
1430
1431 xmlNodePtr node_linearnorm1 = xmlNewChild(normcontNode, 0, (const xmlChar*)"LinearNorm", 0);
1432 ss.str(""); ss << scientific << orig1;
1433 xmlNewProp(node_linearnorm1, (const xmlChar*)"orig", (const xmlChar*)(ss.str().c_str()) );
1434 ss.str(""); ss << scientific << norm1;
1435 xmlNewProp(node_linearnorm1, (const xmlChar*)"norm", (const xmlChar*)(ss.str().c_str()) );
1436 xmlNodePtr node_linearnorm2 = xmlNewChild(normcontNode, 0, (const xmlChar*)"LinearNorm", 0);
1437 ss.str(""); ss << scientific << orig2;
1438 xmlNewProp(node_linearnorm2, (const xmlChar*)"orig", (const xmlChar*)(ss.str().c_str()) );
1439 ss.str(""); ss << scientific << norm2;
1440 xmlNewProp(node_linearnorm2, (const xmlChar*)"norm", (const xmlChar*)(ss.str().c_str()) );
1441}
xmlNodePtr _currentModelNode
Pointer to the current model node
Definition: PMMLlib.hxx:84
std::string _getProp(const xmlNodePtr node, std::string const &prop) const
Definition: PMMLlib.cxx:694
void CheckNeuralNetwork()
Definition: PMMLlib.cxx:728
xmlNodePtr GetChildByName(xmlNodePtr node, std::string nodename)
Definition: PMMLlib.cxx:310
◆ AddNeuralLayer()
void PMMLlib::PMMLlib::AddNeuralLayer ( PMMLActivationFunction  activationFunction)
Add a NeuralLayer node to the current model.
activationFunctionActivation function. One of kIDENTITY, kTANH, kLOGISTIC.
Definition at line 1510 of file PMMLlib.cxx.
1511{
1513
1514 string functionName;
1515 switch(activationFunction)
1516 {
1517 case kIDENTITY:
1518 functionName = "identity";
1519 break;
1520 case kTANH:
1521 functionName = "tanh";
1522 break;
1523 case kLOGISTIC:
1524 functionName = "logistic";
1525 break;
1526 }
1527 xmlNodePtr netNode = _currentModelNode;
1528 // Increment the number of layers
1529 string numberOfLayersStr = _getProp(_currentModelNode, string("numberOfLayers"));
1530 int numberOfLayers;
1531 istringstream( numberOfLayersStr ) >> numberOfLayers;
1532 numberOfLayers++;
1533 stringstream ss;
1534 ss << numberOfLayers;
1535 xmlSetProp(netNode, (const xmlChar*)"numberOfLayers", (const xmlChar*)(ss.str().c_str()) );
1536 // Add the neural layer node
1537 xmlNodePtr neuralLayerNode = xmlNewChild(netNode, 0, (const xmlChar*)"NeuralLayer", 0);
1538 xmlNewProp(neuralLayerNode, (const xmlChar*)"activationFunction", (const xmlChar*)(functionName.c_str()) );
1539 xmlNewProp(neuralLayerNode, (const xmlChar*)"numberOfNeurons", (const xmlChar*)"0" );
1540 // Save the current layer in the _currentNode attribute
1541 _currentNode = neuralLayerNode;
1542}
xmlNodePtr _currentNode
Pointer to the current node
Definition: PMMLlib.hxx:80
@ kIDENTITY
Definition: PMMLlib.hxx:60
@ kTANH
@ kLOGISTIC
References PMMLlib::kIDENTITY, PMMLlib::kLOGISTIC, and PMMLlib::kTANH.
◆ AddNeuralNetwork()
void PMMLlib::PMMLlib::AddNeuralNetwork ( std::string  modelName,
Add a NeuralNetwork node to the root node
modelNameModel name
functionNamePMMLMiningFunction. One of : kREGRESSION.
Definition at line 1359 of file PMMLlib.cxx.
1361{
1363 _currentModelName = modelName;
1364
1366
1367 string function;
1368 switch(functionName)
1369 {
1370 case kREGRESSION:
1371 function = "regression";
1372 break;
1373 }
1374
1375 xmlNodePtr netNode = xmlNewChild(_rootNode, 0, (const xmlChar*)"NeuralNetwork", 0);
1376 xmlNewProp(netNode, (const xmlChar*)"modelName", (const xmlChar*)(_currentModelName.c_str()) );
1377 xmlNewProp(netNode, (const xmlChar*)"functionName", (const xmlChar*)(function.c_str()) );
1378 xmlNewProp(netNode, (const xmlChar*)"numberOfLayers", (const xmlChar*)"0" );
1379 _currentModelNode = netNode;
1380}
std::string _currentModelName
Name of the current model
Definition: PMMLlib.hxx:82
PMMLType _currentModelType
Type of the current model.
Definition: PMMLlib.hxx:83
xmlNodePtr _rootNode
Root node of the document.
Definition: PMMLlib.hxx:79
@ kANN
Definition: PMMLlib.hxx:54
@ kREGRESSION
Definition: PMMLlib.hxx:66
References PMMLlib::kANN, and PMMLlib::kREGRESSION.
◆ AddNeuralOutput()
void PMMLlib::PMMLlib::AddNeuralOutput ( int  outputNeuron,
std::string  optype,
double  orig1,
double  norm1,
double  orig2,
double  norm2
Add a NeuralOutput node to the current model.
outputNeuronId of the output
outputNameName of the output
Definition at line 1455 of file PMMLlib.cxx.
1461{
1463
1464 xmlNodePtr netNode = _currentModelNode;
1465 // if 'NeuralOutputs' node does not exist, create it
1466 xmlNodePtr neuralOutputsNode = GetChildByName(netNode, "NeuralOutputs");
1467 if(!neuralOutputsNode)
1468 {
1469 neuralOutputsNode = xmlNewChild(netNode, 0, (const xmlChar*)"NeuralOutputs", 0);
1470 xmlNewProp(neuralOutputsNode, (const xmlChar*)"numberOfOutputs", (const xmlChar*)"0" );
1471 }
1472 // increment the number of inputs
1473 string numberOfOutputsStr = _getProp(neuralOutputsNode, string("numberOfOutputs"));
1474 int numberOfOutputs;
1475 istringstream( numberOfOutputsStr ) >> numberOfOutputs;
1476 numberOfOutputs++;
1477 stringstream ss;
1478 ss << numberOfOutputs;
1479 xmlSetProp(neuralOutputsNode, (const xmlChar*)"numberOfOutputs", (const xmlChar*)(ss.str().c_str()) );
1480
1481 // then append the node and its children
1482 xmlNodePtr neuralOutputNode = xmlNewChild(neuralOutputsNode, 0, (const xmlChar*)"NeuralOutput", 0);
1483 ss.str(""); ss << outputNeuron;
1484 xmlNewProp(neuralOutputNode, (const xmlChar*)"outputNeuron", (const xmlChar*)(ss.str().c_str()) );
1485
1486 xmlNodePtr derivedFieldNode = xmlNewChild(neuralOutputNode, 0, (const xmlChar*)"DerivedField", 0);
1487 xmlNewProp(derivedFieldNode, (const xmlChar*)"optype", (const xmlChar*)(optype.c_str()) );
1488 xmlNewProp(derivedFieldNode, (const xmlChar*)"dataType", (const xmlChar*)(dataType.c_str()) );
1489
1490 xmlNodePtr normcontNode = xmlNewChild(derivedFieldNode, 0, (const xmlChar*)"NormContinuous", 0);
1491 xmlNewProp(normcontNode, (const xmlChar*)"field", (const xmlChar*)(outputName.c_str()) );
1492
1493 xmlNodePtr node_linearnorm1 = xmlNewChild(normcontNode, 0, (const xmlChar*)"LinearNorm", 0);
1494 ss.str(""); ss << scientific << orig1;
1495 xmlNewProp(node_linearnorm1, (const xmlChar*)"orig", (const xmlChar*)(ss.str().c_str()) );
1496 ss.str(""); ss << scientific << norm1;
1497 xmlNewProp(node_linearnorm1, (const xmlChar*)"norm", (const xmlChar*)(ss.str().c_str()) );
1498 xmlNodePtr node_linearnorm2 = xmlNewChild(normcontNode, 0, (const xmlChar*)"LinearNorm", 0);
1499 ss.str(""); ss << scientific << orig2;
1500 xmlNewProp(node_linearnorm2, (const xmlChar*)"orig", (const xmlChar*)(ss.str().c_str()) );
1501 ss.str(""); ss << scientific << norm2;
1502 xmlNewProp(node_linearnorm2, (const xmlChar*)"norm", (const xmlChar*)(ss.str().c_str()) );
1503}
◆ AddNeuron()
void PMMLlib::PMMLlib::AddNeuron ( int  id,
double  bias,
int  conNb,
int  firstFrom,
idId of the layer
biasValue of property "bias"
conNbNumber of Con nodes
firstFromValue of property "from" for the first Con
weightsVector of weights (One per Con node)
Definition at line 1553 of file PMMLlib.cxx.
1558{
1560
1561 stringstream ss;
1562
1563 // increment the number of neurons
1564 string numberOfNeuronsStr = _getProp(_currentNode, string("numberOfNeurons"));
1565 int numberOfNeurons;
1566 istringstream( numberOfNeuronsStr ) >> numberOfNeurons;
1567 numberOfNeurons++;
1568 ss << numberOfNeurons;
1569 xmlSetProp(_currentNode, (const xmlChar*)"numberOfNeurons", (const xmlChar*)(ss.str().c_str()) );
1570
1571 // append a neuron
1572 xmlNodePtr neuronNode = xmlNewChild(_currentNode, 0, (const xmlChar*)"Neuron", 0);
1573 ss.str(""); ss << id;
1574 xmlNewProp(neuronNode, (const xmlChar*)"id", (const xmlChar*)(ss.str().c_str()) );
1575 ss.str(""); ss << scientific << bias;
1576 xmlNewProp(neuronNode, (const xmlChar*)"bias", (const xmlChar*)(ss.str().c_str()) );
1577
1578 // append multiple 'Con' to the neuron
1579 for(int k=0 ; k<conNb ; k++)
1580 {
1581 xmlNodePtr conNode = xmlNewChild(neuronNode, 0, (const xmlChar*)"Con", 0);
1582 ss.str(""); ss << firstFrom+k;
1583 xmlNewProp(conNode, (const xmlChar*)"from", (const xmlChar*)(ss.str().c_str()) ); // !!! ce n'est pas k !!!
1584 ss.str(""); ss << scientific << weights[k];
1585 xmlNewProp(conNode, (const xmlChar*)"weight", (const xmlChar*)(ss.str().c_str()) );
1586 }
1587}
◆ CheckNeuralNetwork()
void PMMLlib::PMMLlib::CheckNeuralNetwork ( )
Check if the current model type is kANN.
Throw an exception if the model type is not kANN.
Definition at line 728 of file PMMLlib.cxx.
729{
730 if ( _currentModelType != kANN )
731 throw string("Use this method with NeuralNetwork models.");
732}
References PMMLlib::kANN.
◆ GetNameInput()
std::string PMMLlib::PMMLlib::GetNameInput ( int  index)
Recovery of the name of an input in the current model.
indexIndex of the input
Name of the input
Definition at line 897 of file PMMLlib.cxx.
898{
900
901 string name("");
902 xmlNodePtr node_inputs = GetChildByName(_currentModelNode,"NeuralInputs");
903 if ( node_inputs == NULL )
904 return name;
905
906 node_inputs = node_inputs->children;
907 if ( node_inputs == NULL )
908 return name;
909
910 for(int i = 0;i<index;i++)
911 {
912 node_inputs = node_inputs->next;
913 if ( node_inputs == NULL )
914 return name;
915 }
916
917 node_inputs = node_inputs->children;
918 if ( node_inputs == NULL )
919 return name;
920
921 node_inputs = node_inputs->children;
922 if ( node_inputs == NULL )
923 return name;
924
925 name = _getProp(node_inputs, string("field"));
926
927 return name;
928}
References yacsorb.CORBAEngineTest::i.
◆ GetNameOutput()
std::string PMMLlib::PMMLlib::GetNameOutput ( int  index)
Get the name of an output in the current model.
indexIndex of the output
Name of the output
Definition at line 936 of file PMMLlib.cxx.
937{
939
940 string name("");
941 xmlNodePtr node_outputs = GetChildByName(_currentModelNode,"NeuralOutputs");
942 if ( node_outputs == NULL )
943 return name;
944 node_outputs = node_outputs->children;
945 if ( node_outputs == NULL )
946 return name;
947 for(int i = 0;i<index;i++)
948 {
949 node_outputs = node_outputs->next;
950 if ( node_outputs == NULL )
951 return name;
952 }
953
954 node_outputs = node_outputs->children;
955 if ( node_outputs == NULL )
956 return name;
957 node_outputs = node_outputs->children;
958 if ( node_outputs == NULL )
959 return name;
960
961 name = _getProp(node_outputs, string("field") );
962
963 return name;
964}
◆ GetNbHiddenLayers()
int PMMLlib::PMMLlib::GetNbHiddenLayers ( )
Get the number of hidden layers
Number of hidden layers
Definition at line 1137 of file PMMLlib.cxx.
1138{
1140
1141 int nb_layers = 0;
1142 xmlNodePtr node_layers = GetChildByName(_currentModelNode,"NeuralLayer");
1143 if ( node_layers == NULL )
1144 return nb_layers;
1145
1146 while (string((const char*)(node_layers->name)) == "NeuralLayer")
1147 {
1148 nb_layers++;
1149 node_layers = node_layers->next;
1150 if ( node_layers == NULL )
1151 return nb_layers;
1152 }
1153 return nb_layers;
1154}
◆ GetNbInputs()
int PMMLlib::PMMLlib::GetNbInputs ( )
Get the number of inputs, ie the number of NeuralInputs nodes.
Number of input nodes
Definition at line 847 of file PMMLlib.cxx.
848{
850
851 int nb=0;
852 xmlNodePtr node_inputs = GetChildByName(_currentModelNode,"NeuralInputs");
853 if ( node_inputs == NULL )
854 return nb;
855
856 node_inputs = node_inputs->children;
857 while (node_inputs != NULL)
858 {
859 nb++;
860 node_inputs = node_inputs->next;
861 }
862
863 return nb;
864}
◆ GetNbLayers()
int PMMLlib::PMMLlib::GetNbLayers ( )
Get the total number of layers
Total number of layers
Definition at line 1160 of file PMMLlib.cxx.
1161{
1162 return (GetNbHiddenLayers() + 2);
1163}
PMMLLIB_EXPORT int GetNbHiddenLayers()
Definition: PMMLlib.cxx:1137
◆ GetNbNeuronsAtLayer()
int PMMLlib::PMMLlib::GetNbNeuronsAtLayer ( int  index)
Get the number of neurons at a given layer
indexIndex of the layer
Number of neurons at given layer
Definition at line 1170 of file PMMLlib.cxx.
1171{
1173
1174 int nb_neurons = 0;
1175 xmlNodePtr node_layers = GetChildByName(_currentModelNode,"NeuralLayer");
1176 if ( node_layers == NULL )
1177 return nb_neurons;
1178
1179 // Positionnement à la bonne couche
1180 for(int i=0;i<index;i++)
1181 {
1182 node_layers = node_layers->next;
1183 if ( node_layers == NULL )
1184 return nb_neurons;
1185 }
1186
1187 xmlNodePtr node_neurons = GetChildByName(node_layers,"Neuron");
1188 while(node_neurons != NULL)
1189 {
1190 nb_neurons++;
1191 node_neurons = node_neurons->next;
1192 }
1193
1194 return nb_neurons;
1195}
◆ GetNbOutputs()
int PMMLlib::PMMLlib::GetNbOutputs ( )
Recover the number of outputs
Number of outputs
Definition at line 871 of file PMMLlib.cxx.
872{
874
875 int nb=0;
876 xmlNodePtr node_outputs = GetChildByName(_currentModelNode,"NeuralOutputs");
877 if ( node_outputs == NULL )
878 return nb;
879
880 node_outputs = node_outputs->children;
881
882 while (node_outputs != NULL)
883 {
884 nb++;
885 node_outputs = node_outputs->next;
886 }
887
888 return nb;
889}
◆ GetNeuralNetPtr() [1/2]
xmlNodePtr PMMLlib::PMMLlib::GetNeuralNetPtr ( int  index)
Get the XML node of a given network from the index
indexIndex of the neural network
Pointer to the XML node
Definition at line 739 of file PMMLlib.cxx.
740{
741 return GetPtr(index, GetTypeString() );
742}
std::string GetTypeString()
Definition: PMMLlib.cxx:473
xmlNodePtr GetPtr(int ann_index, std::string name)
Definition: PMMLlib.cxx:419
◆ GetNeuralNetPtr() [2/2]
xmlNodePtr PMMLlib::PMMLlib::GetNeuralNetPtr ( std::string  name)
Get the XML node of a given network model
nameName of the neural network
Definition at line 749 of file PMMLlib.cxx.
750{
751 return GetPtr(name, GetTypeString() );
752}
◆ GetNeuronBias()
double PMMLlib::PMMLlib::GetNeuronBias ( int  layer_index,
int  neu_index
Get the bias of a neuron
layer_indexIndex of the layer to get bias
neu_indexIndex of the neuron
Bias of the specified neuron
Definition at line 1204 of file PMMLlib.cxx.
1206{
1208
1209 double bias = 0.;
1210 xmlNodePtr node_layers = GetChildByName(_currentModelNode,"NeuralLayer");
1211 if ( node_layers == NULL )
1212 return bias;
1213 // Positionnement a la bonne couche
1214 for(int i=0;i<layer_index;i++)
1215 {
1216 node_layers = node_layers->next;
1217 if ( node_layers == NULL )
1218 return bias;
1219 }
1220 xmlNodePtr node_neurons = GetChildByName(node_layers,"Neuron");
1221 // Positionnement sur le bon neurone
1222 for(int j=0;j<neu_index;j++)
1223 {
1224 node_neurons = node_neurons->next;
1225 if ( node_neurons == NULL )
1226 return bias;
1227 }
1228 string str_tmp = _getProp(node_neurons, string("bias"));
1229 bias = atof(str_tmp.c_str());
1230 return bias;
1231}
◆ GetNormalisationInput()
void PMMLlib::PMMLlib::GetNormalisationInput ( int  index,
double *  dnorm
Get the input parameters on the normalization
node_annNeural network node
[out]dnormArray that contains the mean and the standard deviation
Definition at line 1016 of file PMMLlib.cxx.
1018{
1020 dnorm[0] = 0.0;
1021 dnorm[1] = 0.0;
1022 xmlNodePtr node_inputs = GetChildByName(_currentModelNode,"NeuralInputs");
1023 if ( node_inputs == NULL )
1024 return ;
1025 node_inputs = GetChildByName(node_inputs,"NeuralInput");
1026 if ( node_inputs == NULL )
1027 return ;
1028 // Positionnement sur la bonne entree
1029 for(int i=0;i<index;i++)
1030 {
1031 node_inputs = node_inputs->next;
1032 if ( node_inputs == NULL )
1033 return ;
1034 }
1035 xmlNodePtr tmpNode = GetChildByName(node_inputs,"DerivedField");
1036 if ( tmpNode == NULL )
1037 return ;
1038 xmlNodePtr node_field = GetChildByName(tmpNode,"NormContinuous");
1039 if ( node_field == NULL )
1040 return ;
1041 if (string((const char*)(node_field->name)) == "NormContinuous")
1042 {
1043 //Get mean and standard deviation
1044 string str_tmp;
1045 xmlNodePtr node_linearnorm = node_field->children;
1046 str_tmp = _getProp(node_linearnorm, string("orig"));
1047 double dorig1 = atof(str_tmp.c_str());
1048 str_tmp = _getProp(node_linearnorm, string("norm"));
1049 double dnorm1 = atof(str_tmp.c_str());
1050 node_linearnorm = node_linearnorm->next;
1051 str_tmp = _getProp(node_linearnorm, string("orig"));
1052 double dorig2 = atof(str_tmp.c_str());
1053 str_tmp = _getProp(node_linearnorm, string("norm"));
1054 double dnorm2 = atof(str_tmp.c_str());
1055 if ( dnorm1 * dnorm2 < -0.5 ) // <=> GetNormalizationType == 0
1056 {
1057 // case of kMinusOneOne
1058 dnorm[0] = dorig1;
1059 dnorm[1] = dorig2;
1060 }
1061 else // <=> GetNormalizationType == 1
1062 {
1063 // case of kCR, kZeroOne
1064 dnorm[0] = dorig2;
1065 dnorm[1] = -1.0 * dnorm1 * dorig2; //dorig2 / dnorm1;
1066 }
1067 }
1068}
◆ GetNormalisationOutput()
void PMMLlib::PMMLlib::GetNormalisationOutput ( int  index,
double *  dnorm
Get the parameters on the normalization of an output for the current model.
indexOutput index
Definition at line 1076 of file PMMLlib.cxx.
1078{
1080 dnorm[0] = 0.0;
1081 dnorm[1] = 0.0;
1082
1083 xmlNodePtr node_outputs = GetChildByName(_currentModelNode,"NeuralOutputs");
1084 if ( node_outputs == NULL )
1085 return ;
1086 node_outputs = GetChildByName(node_outputs,"NeuralOutput");
1087 if ( node_outputs == NULL )
1088 return ;
1089 // Positionnement sur la bonne sortie
1090 for(int i=0;i< index;i++)
1091 {
1092 node_outputs = node_outputs->next;
1093 if ( node_outputs == NULL )
1094 return ;
1095 }
1096 xmlNodePtr tmpNode = GetChildByName(node_outputs,"DerivedField");
1097 if ( tmpNode == NULL )
1098 return ;
1099 xmlNodePtr node_field = GetChildByName(tmpNode,"NormContinuous");
1100 if ( node_field == NULL )
1101 return ;
1102
1103 if (string((const char*)(node_field->name)) == "NormContinuous")
1104 {
1105 // Recuperation de la moyenne et de l'ecart type
1106 string str_tmp;
1107 xmlNodePtr node_linearnorm = node_field->children;
1108 str_tmp = _getProp(node_linearnorm, string("orig"));
1109 double dorig1 = atof(str_tmp.c_str());
1110 str_tmp = _getProp(node_linearnorm, string("norm"));
1111 double dnorm1 = atof(str_tmp.c_str());
1112 node_linearnorm = node_linearnorm->next;
1113 str_tmp = _getProp(node_linearnorm,string("orig"));
1114 double dorig2 = atof(str_tmp.c_str());
1115 str_tmp = _getProp(node_linearnorm, string("norm"));
1116 double dnorm2 = atof(str_tmp.c_str());
1117 if ( dnorm1 * dnorm2 < -0.5 )
1118 {
1119 // case of kMinusOneOne
1120 dnorm[0] = dorig1;
1121 dnorm[1] = dorig2;
1122 }
1123 else
1124 {
1125 // case of kCR, kZeroOne
1126 dnorm[0] = dorig2;
1127 dnorm[1] = -1.0 * dorig2 * dnorm1; //-1.0 * dorig2 / dnorm1;
1128 }
1129 }
1130}
◆ GetNormalizationType()
int PMMLlib::PMMLlib::GetNormalizationType ( )
Get the normalization type of the current model
Normalization type of the neural network
Definition at line 971 of file PMMLlib.cxx.
972{
974
975 xmlNodePtr node_inputs = GetChildByName(_currentModelNode,"NeuralInputs");
976 node_inputs = GetChildByName(node_inputs,"NeuralInput");
977 xmlNodePtr nodeTmp = GetChildByName(node_inputs,"DerivedField");
978 xmlNodePtr node_field = nodeTmp->children;
979 xmlNodePtr node_linearnorm;
980 string str_tmp;
981 double dorig1, dnorm1;
982 double dorig2, dnorm2;
983 if (string((const char*)(node_field->name)) == "NormContinuous")
984 {
985 // Get mean and standard deviation
986 node_linearnorm = node_field->children;
987 str_tmp = _getProp(node_linearnorm, string("orig"));
988 dorig1 = atof(str_tmp.c_str());
989 str_tmp = _getProp(node_linearnorm, string("norm"));
990 dnorm1 = atof(str_tmp.c_str());
991 node_linearnorm = node_linearnorm->next;
992 str_tmp = _getProp(node_linearnorm, string("orig"));
993 dorig2 = atof(str_tmp.c_str());
994 str_tmp = _getProp(node_linearnorm, string("norm"));
995 dnorm2 = atof(str_tmp.c_str());
996 if ( dnorm1 * dnorm2 < -0.5 )
997 { // case of kMinusOneOne
998 return 0;
999 }
1000 else
1001 { // case of kCR, kZeroOne
1002 return 1;
1003 }
1004 }
1005 string msg("Unable to retrieve the normalization type.");
1006 throw msg;
1007}
◆ GetPrecNeuronSynapse()
double PMMLlib::PMMLlib::GetPrecNeuronSynapse ( int  layer_index,
int  neu_index,
int  prec_index
Get the synaptic weight
layer_indexIndex of the layer to get synaptic weight
prec_indexIndex of the synapse
Synaptic weight
Definition at line 1241 of file PMMLlib.cxx.
1244{
1246
1247 double weight = 0.;
1248 xmlNodePtr node_layers = GetChildByName(_currentModelNode,"NeuralLayer");
1249 if ( node_layers == NULL )
1250 return weight;
1251 // Positionnement a la bonne couche
1252 for(int i=0;i<layer_index;i++)
1253 {
1254 node_layers = node_layers->next;
1255 if ( node_layers == NULL )
1256 return weight;
1257 }
1258 xmlNodePtr node_neurons = GetChildByName(node_layers,"Neuron");
1259 // Positionnement sur le bon neurone
1260 for(int i=0;i<neu_index;i++)
1261 {
1262 node_neurons = node_neurons->next;
1263 if ( node_neurons == NULL )
1264 return weight;
1265 }
1266 xmlNodePtr node_con = GetChildByName(node_neurons,"Con");
1267 // Positionnement sur la bonne synapse
1268 for(int i=0;i<prec_index;i++)
1269 {
1270 node_con = node_con->next;
1271 if ( node_con == NULL )
1272 return weight;
1273 }
1274 string str_tmp = _getProp(node_con, string("weight"));
1275 weight = atof(str_tmp.c_str());
1276 return weight;
1277}
◆ ReadNetworkStructure()
std::string PMMLlib::PMMLlib::ReadNetworkStructure ( )
Read the structure of the network
Structure read
Definition at line 759 of file PMMLlib.cxx.
760{
762
763 string structure("");
764 // Treatment of the input
765 xmlNodePtr inputNodes = GetChildByName(_currentModelNode,"NeuralInputs");
766 if ( inputNodes != NULL )
767 {
768 xmlNodePtr inputNode = GetChildByName(inputNodes,"NeuralInput");
769 if ( inputNode != NULL )
770 {
771 while (inputNode != NULL)
772 {
773 xmlNodePtr child = GetChildByName(inputNode,"DerivedField");
774 if ( child != NULL )
775 {
776 xmlNodePtr fieldName = child->children; // NormContinuous
777 if ( fieldName != NULL )
778 {
779 string field = _getProp(fieldName, string("field"));
780 structure += field;
781 structure += ":";
782 }
783 }
784 inputNode = inputNode->next;
785 }
786 // Delete the last comma
787 structure.erase(structure.size()-1);
788 }
789 }
790 // Intermediary layers
791 xmlNodePtr node_layer = GetChildByName(_currentModelNode,"NeuralLayer");
792 if ( node_layer != NULL )
793 {
794 string name = string((const char*)(node_layer->name));
795 structure += ",";
796
797 while ( node_layer != NULL &&
798 (string((const char*)(node_layer->name)) == "NeuralLayer") &&
799 node_layer->next != NULL &&
800 (string((const char*)(node_layer->next->name)) != "NeuralOutputs") )
801 {
802 // Get the number of neurons of the current layer
803 string nbneurons = _getProp(node_layer, string("numberOfNeurons"));
804 structure += nbneurons;
805 structure += ",";
806 node_layer = node_layer->next;
807 }
808 }
809 // Output layers
810 xmlNodePtr node_outputs = GetChildByName(_currentModelNode,"NeuralOutputs");
811 if ( node_outputs != NULL )
812 {
813 xmlNodePtr node_output = GetChildByName(node_outputs,"NeuralOutput");
814 if ( node_output != NULL )
815 {
816 while (node_output != NULL)
817 {
818 // Get the input of the current layer
819 xmlNodePtr child = GetChildByName(node_output,"DerivedField");
820 if ( child != NULL )
821 {
822 xmlNodePtr fieldName = child->children; // NormContinuous
823 if ( fieldName != NULL )
824 {
825 if (string((const char*)(fieldName->name)) == "NormContinuous")
826 structure += "@";
827
828 string field = _getProp(fieldName, string("field"));
829 structure += field;
830 structure += ":";
831 }
832 }
833 node_output = node_output->next;
834 }
835 // Delete the last comma
836 structure.erase(structure.size()-1);
837 }
838 }
839 return structure;
840}
◆ SetNeuralNetName()
void PMMLlib::PMMLlib::SetNeuralNetName ( int  index,
std::string  name
Not tested.
Set the name of the neural network
indexNeural network index
nameNeural network name to set
Definition at line 1286 of file PMMLlib.cxx.
1288{
1290
1291 int i=0;
1292 if (_doc != NULL)
1293 {
1294 xmlNodePtr node_ann = GetChildByName(_rootNode,"NeuralNetwork");
1295 while ((i != index) && (node_ann != NULL))
1296 {
1297 node_ann = node_ann->next;
1298 i++;
1299 }
1300 xmlNewProp(node_ann, (const xmlChar*)"modelName", (const xmlChar*)(name.c_str()));
1301 }
1302 xmlSaveFormatFile( string(_pmmlFile+".pmml").c_str(), _doc, 1);
1303}
std::string _pmmlFile
Name of the associated PMML file.
Definition: PMMLlib.hxx:77
xmlDocPtr _doc
Associated DOM documents.
Definition: PMMLlib.hxx:78
