YACS.py
1# Copyright (C) 2006-2026 CEA, EDF
2#
3# This library is free software; you can redistribute it and/or
4# modify it under the terms of the GNU Lesser General Public
5# License as published by the Free Software Foundation; either
6# version 2.1 of the License, or (at your option) any later version.
7#
8# This library is distributed in the hope that it will be useful,
9# but WITHOUT ANY WARRANTY; without even the implied warranty of
10# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
11# Lesser General Public License for more details.
12#
13# You should have received a copy of the GNU Lesser General Public
14# License along with this library; if not, write to the Free Software
15# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
16#
17# See http://www.salome-platform.org/ or email : webmaster.salome@opencascade.com
18#
20import sys
21import YACS_ORB__POA
22import YACS_ORB
23import SALOME_ComponentPy
24import SALOME_DriverPy
26import threading
27import tempfile
28import os
30import SALOMERuntime
31import loader
32import salomeloader
33import pilot
34import traceback
35
36class proc_i(YACS_ORB__POA.ProcExec):
37 def __init__(self, xmlFile):
38 self.l = loader.YACSLoader()
39 self.e = pilot.ExecutorSwig()
40 self.e.setExecMode(1) # YACS::STEPBYSTEP
41 self.run1 = None
42 self.p = self.l.load(xmlFile)
43 self.xmlFile=xmlFile
44 pass
45
46 def getNodeState(self,numid):
47 return self.p.getNodeState(numid)
48
49 def getNodeProgress(self,numid):
50 return self.p.getNodeProgress(numid)
51
52 def getXMLState(self, numid):
53 return self.p.getXMLState(numid)
54
55 def getInPortValue(self, nodeNumid, portName):
56 try:
57 return self.p.getInPortValue(nodeNumid, portName)
58 except:
59 traceback.print_exc()
60 return ""
61
62 def setInPortValue(self, nodeName, portName, value):
63 try:
64 return self.p.setInPortValue(nodeName, portName, value)
65 except:
66 traceback.print_exc()
67 return ""
68
69 def getOutPortValue(self, nodeNumid, portName):
70 try:
71 return self.p.getOutPortValue(nodeNumid, portName)
72 except:
73 traceback.print_exc()
74 return ""
75
76 def getErrorDetails(self, nodeNumid):
77 return self.p.getNodeErrorDetails(nodeNumid)
78
79 def getErrorReport(self, nodeNumid):
80 return self.p.getNodeErrorReport(nodeNumid)
81
82 def getContainerLog(self, nodeNumid):
83 return self.p.getNodeContainerLog(nodeNumid)
84
85 def shutdownProc(self, level):
86 return self.p.shutdown(level)
87
89 return self.e.getExecutorState()
90
91 def getIds(self):
92 numids = self.p.getNumIds()
93 ids = self.p.getIds()
94 return (numids,ids)
95
96 def getNumIds(self):
97 return self.p.getNumIds()
98
99 def getNames(self):
100 return self.p.getIds()
101
102 def runProc(self,debug, isPyThread, fromscratch):
103 print("**************************Begin schema execution %s**************************" % self.xmlFile)
104 self.e.RunPy(self.p,debug, isPyThread, fromscratch)
105 print("**************************End schema execution %s****************************" % self.xmlFile)
106
107 def Run(self):
108 if self.run1 is not None:
109 execState = self.e.getExecutorState()
110 if execState >= pilot.FINISHED:
111 self.run1.join()
112 self.run1 = None
113
114 if self.run1 is None:
115 self.run1 = threading.Thread(None, self.runProc, "CORBAExec", (0,True,True))
116 self.run1.start()
117
118 def RunFromState(self, xmlFile):
119 """Start an execution from the state given by the file xmlFile
120 If xmlFile == "", start execution from the current state
121 """
122 if self.run1 is not None:
123 execState = self.e.getExecutorState()
124 if execState >= pilot.FINISHED:
125 self.run1.join()
126 self.run1 = None
127
128 if xmlFile:
129 try:
130 self.p.init()
131 self.p.exUpdateState();
132 sp = loader.stateParser()
133 sl = loader.stateLoader(sp,self.p)
134 sl.parse(xmlFile)
135 except IOError as ex:
136 print("IO Error: ", ex)
137 return
138 except ValueError as ex:
139 print("Caught ValueError Exception:",ex)
140 return
141 except pilot.Exception as ex:
142 print(ex.what())
143 return
144 except:
145 print("Unknown exception!")
146 return
147
148 if self.run1 is None:
149 self.run1 = threading.Thread(None, self.runProc, "CORBAExec", (0,True,False))
150 self.run1.start()
151
152 def RestartFromState(self, xmlFile):
153 """Reset the procedure state to ready state for all nodes in error
154 if xmlFile exists first try to load the state from this file.
155 then start execution
156 """
157 if self.run1 is not None:
158 execState = self.e.getExecutorState()
159 if execState >= pilot.FINISHED:
160 self.run1.join()
161 self.run1 = None
162 else:
163 return
164
165 try:
166 if os.path.exists(xmlFile):
167 self.p.init()
168 sp = loader.stateParser()
169 sl = loader.stateLoader(sp,self.p)
170 sl.parse(xmlFile)
171
172 self.p.resetState(1)
173 self.p.exUpdateState();
174 except:
175 pass
176
177 if self.run1 is None:
178 self.run1 = threading.Thread(None, self.runProc, "CORBAExec", (0,True,False))
179 self.run1.start()
180
181 def addObserver(self, obs, numid, event):
182 disp = SALOMERuntime.SALOMEDispatcher_getSALOMEDispatcher()
183 disp.addObserver(obs, numid, event)
184 pass
185
186 def setExecMode(self, mode):
187 if mode == YACS_ORB.CONTINUE:
188 self.e.setExecMode(0)
189 pass
190 if mode == YACS_ORB.STEPBYSTEP:
191 self.e.setExecMode(1)
192 pass
193 if mode == YACS_ORB.STOPBEFORENODES:
194 self.e.setExecMode(2)
195 pass
196 pass
197
198 def setListOfBreakPoints(self, listOfBreakPoints):
199 self.e.setListOfBreakPoints(listOfBreakPoints)
200 pass
201
202 def getTasksToLoad(self):
203 return self.e.getTasksToLoad()
204
205 def setStepsToExecute(self, listToExecute):
206 return self.e.setStepsToExecute(listToExecute)
207
209 return self.e.resumeCurrentBreakPoint()
210
211 def isNotFinished(self):
212 return self.e.isNotFinished()
213
214 def stopExecution(self):
215 self.e.stopExecution()
216 pass
217
218 def saveState(self, xmlFile):
219 return self.e.saveState(xmlFile)
220
221 def setStopOnError(self, dumpRequested, xmlFile):
222 self.e.setStopOnError(dumpRequested, xmlFile)
223 pass
224
226 self.e.unsetStopOnError()
227 pass
228
229 pass
230
231
232class YACS(YACS_ORB__POA.YACS_Gen,
233 SALOME_ComponentPy.SALOME_ComponentPy_i,
234 SALOME_DriverPy.SALOME_DriverPy_i):
235 """
236 To be a SALOME component, this Python class must have the component name
237 (YACS) and inherit the YACS_Gen class build from idl compilation
238 with omniidl and also the class SALOME_ComponentPy_i which defines general
239 SALOME component behaviour.
240 """
241 def __init__ ( self, orb, poa, contID, containerName, instanceName,
242 interfaceName ):
243 print("YACS.__init__: ", containerName, ';', instanceName)
244 SALOME_ComponentPy.SALOME_ComponentPy_i.__init__(self, orb, poa, contID,
245 containerName, instanceName,
246 interfaceName, False)
247 SALOME_DriverPy.SALOME_DriverPy_i.__init__(self, interfaceName)
248
249 SALOMERuntime.RuntimeSALOME.setRuntime(1)
250 SALOMERuntime.SALOMEDispatcher_setSALOMEDispatcher()
251 r=pilot.getRuntime()
252
253 try:
254 #try to load SALOME module catalogs
255 modul_catalog = self._naming_service.Resolve("/Kernel/ModulCatalog")
256 ior= orb.object_to_string(modul_catalog)
257 cata=r.loadCatalog("session",ior)
258 r.addCatalog(cata)
259 except :
260 pass
261
262 """
263 Get version information.
264 """
265 def getVersion( self ):
266 try:
267 rt = SALOMERuntime.getSALOMERuntime()
268 version = rt.getVersion()
269 except:
270 version = ""
271 pass
272 return version
273
274 def LoadProc(self,xmlFile):
275 """
276 load an XML graph in a YACS::ENGINE::proc, create a CORBA servant
277 associated to the proc, and return a ref on the servant.
278 """
279 try:
280 procExec_i = proc_i(xmlFile)
281 logger=procExec_i.p.getLogger("parser")
282 if not logger.isEmpty():
283 print("The imported file has errors :")
284 print(logger.getStr())
285 sys.stdout.flush()
286 return None
287 except IOError as ex:
288 print("IO Error: ", ex, file=sys.stderr)
289 return None
290 except ValueError as ex:
291 print("Caught ValueError Exception:",ex, file=sys.stderr)
292 return None
293 except pilot.Exception as ex:
294 print(ex.what(), file=sys.stderr)
295 return None
296 except:
297 traceback.print_exc()
298 return None
299 procExec_o = procExec_i._this()
300 return procExec_o
301
302 def convertSupervFile(self,xmlFile):
303 """
304 load a SUPERV xml graph, convert it and return the new filename.
305 """
306 try:
307 r = pilot.getRuntime()
308 lo = salomeloader.SalomeLoader()
309 e = pilot.ExecutorSwig()
310 p = lo.load(xmlFile)
311 s = pilot.SchemaSave(p)
312 hnd, convertedFile = tempfile.mkstemp(".xml","yacs_","/tmp")
313 s.save(convertedFile)
314 return convertedFile
315 except (IndexError):
316 return ""
317
318 pass
319
def __init__(self, orb, poa, contID, containerName, instanceName, interfaceName)
Definition: YACS.py:242
def LoadProc(self, xmlFile)
Definition: YACS.py:274
def convertSupervFile(self, xmlFile)
Definition: YACS.py:302
def getVersion(self)
Definition: YACS.py:265
def getNumIds(self)
Definition: YACS.py:96
Definition: YACS.py:82
Definition: YACS.py:202
def getNodeState(self, numid)
Definition: YACS.py:46
Definition: YACS.py:118
def getIds(self)
Definition: YACS.py:91
def getNodeProgress(self, numid)
Definition: YACS.py:49
Definition: YACS.py:62
def runProc(self, debug, isPyThread, fromscratch)
Definition: YACS.py:102
Definition: YACS.py:214
def getNames(self)
Definition: YACS.py:99
Definition: YACS.py:218
Definition: YACS.py:198
Definition: YACS.py:69
def unsetStopOnError(self)
Definition: YACS.py:225
Definition: YACS.py:37
Definition: YACS.py:52
Definition: YACS.py:85
def Run(self)
Definition: YACS.py:107
Definition: YACS.py:79
def resumeCurrentBreakPoint(self)
Definition: YACS.py:208
Definition: YACS.py:181
Definition: YACS.py:221
Definition: YACS.py:211
Definition: YACS.py:186
Definition: YACS.py:55
Definition: YACS.py:205
Definition: YACS.py:152
Definition: YACS.py:76
def getExecutorState(self)
Definition: YACS.py:88
