yacsorb.YACS.YACS Class Reference
Inheritance diagram for yacsorb.YACS.YACS:
Collaboration diagram for yacsorb.YACS.YACS:
def __init__ (self, orb, poa, contID, containerName, instanceName, interfaceName)
def getVersion (self)
def LoadProc (self, xmlFile)
def convertSupervFile (self, xmlFile)
To be a SALOME component, this Python class must have the component name
(YACS) and inherit the YACS_Gen class build from idl compilation
with omniidl and also the class SALOME_ComponentPy_i which defines general
SALOME component behaviour.
Definition at line 232 of file YACS.py.
◆ __init__()
def yacsorb.YACS.YACS.__init__ (   self,
  orb,
  poa,
  contID,
  containerName,
  instanceName,
  interfaceName
Definition at line 241 of file YACS.py.
242 interfaceName ):
243 print("YACS.__init__: ", containerName, ';', instanceName)
244 SALOME_ComponentPy.SALOME_ComponentPy_i.__init__(self, orb, poa, contID,
245 containerName, instanceName,
246 interfaceName, False)
247 SALOME_DriverPy.SALOME_DriverPy_i.__init__(self, interfaceName)
248
249 SALOMERuntime.RuntimeSALOME.setRuntime(1)
250 SALOMERuntime.SALOMEDispatcher_setSALOMEDispatcher()
251 r=pilot.getRuntime()
252
253 try:
254 #try to load SALOME module catalogs
255 modul_catalog = self._naming_service.Resolve("/Kernel/ModulCatalog")
256 ior= orb.object_to_string(modul_catalog)
257 cata=r.loadCatalog("session",ior)
258 r.addCatalog(cata)
259 except :
260 pass
261
◆ convertSupervFile()
def yacsorb.YACS.YACS.convertSupervFile (   self,
  xmlFile
load a SUPERV xml graph, convert it and return the new filename.
Definition at line 302 of file YACS.py.
302 def convertSupervFile(self,xmlFile):
303 """
304 load a SUPERV xml graph, convert it and return the new filename.
305 """
306 try:
307 r = pilot.getRuntime()
308 lo = salomeloader.SalomeLoader()
309 e = pilot.ExecutorSwig()
310 p = lo.load(xmlFile)
311 s = pilot.SchemaSave(p)
312 hnd, convertedFile = tempfile.mkstemp(".xml","yacs_","/tmp")
313 s.save(convertedFile)
314 return convertedFile
315 except (IndexError):
316 return ""
317
◆ getVersion()
def yacsorb.YACS.YACS.getVersion (   self)
Definition at line 265 of file YACS.py.
265 def getVersion( self ):
266 try:
267 rt = SALOMERuntime.getSALOMERuntime()
268 version = rt.getVersion()
269 except:
270 version = ""
271 pass
272 return version
273
◆ LoadProc()
def yacsorb.YACS.YACS.LoadProc (   self,
  xmlFile
load an XML graph in a YACS::ENGINE::proc, create a CORBA servant
associated to the proc, and return a ref on the servant.
Definition at line 274 of file YACS.py.
274 def LoadProc(self,xmlFile):
275 """
276 load an XML graph in a YACS::ENGINE::proc, create a CORBA servant
277 associated to the proc, and return a ref on the servant.
278 """
279 try:
280 procExec_i = proc_i(xmlFile)
281 logger=procExec_i.p.getLogger("parser")
282 if not logger.isEmpty():
283 print("The imported file has errors :")
284 print(logger.getStr())
285 sys.stdout.flush()
286 return None
287 except IOError as ex:
288 print("IO Error: ", ex, file=sys.stderr)
289 return None
290 except ValueError as ex:
291 print("Caught ValueError Exception:",ex, file=sys.stderr)
292 return None
293 except pilot.Exception as ex:
294 print(ex.what(), file=sys.stderr)
295 return None
296 except:
297 traceback.print_exc()
298 return None
299 procExec_o = procExec_i._this()
300 return procExec_o
301
