YACS::HMI::LinkAStar Class Reference
#include <LinkAStar.hxx>
Collaboration diagram for YACS::HMI::LinkAStar:
 LinkAStar (const LinkMatrix &linkMatrix)
 ~LinkAStar ()
bool computePath (LNode from, LNode to)
LNodePath givePath ()
bool isAlreadyInList (std::pair< int, int > n, const LNodeMap &aList)
void addNeighbours (std::pair< int, int > n)
std::pair< int, int > bestNode (const LNodeMap &aList)
void moveToClosedList (std::pair< int, int > n)
double distance (int i1, int j1, int i2, int j2)
const LinkMatrix & _linkMatrix
LNodeMap _closedList
LNodeMap _openList
LNode _from
LNode _to
std::priority_queue< Cost > _pq
Definition at line 68 of file LinkAStar.hxx.
◆ LinkAStar()
LinkAStar::LinkAStar ( const LinkMatrix &  linkMatrix)
Definition at line 47 of file LinkAStar.cxx.
47 : _linkMatrix(linkMatrix), _from(0,0), _to(0,0)
48{
49 _closedList.clear();
50 _openList.clear();
51 _pq=std::priority_queue<Cost>();
52}
Definition: LinkAStar.hxx:85
Definition: LinkAStar.hxx:90
References _closedList, _openList, and _pq.
◆ ~LinkAStar()
LinkAStar::~LinkAStar ( )
Definition at line 54 of file LinkAStar.cxx.
55{
56}
◆ addNeighbours()
void LinkAStar::addNeighbours ( std::pair< int, int >  n)
Definition at line 118 of file LinkAStar.cxx.
119{
120 LCostNode tmp(currentNode);
121 int x = currentNode.first;
122 int y = currentNode.second;
123 for (int i = x-1; i <= x+1; i++)
124 {
125 if ((i<0) || (i >= _linkMatrix.imax()))
126 continue; // --- skip: outside matrix
127 for (int j = y-1; j <= y+1; j++)
128 {
129 if ((j<0) || (j >= _linkMatrix.jmax()))
130 continue; // --- skip: outside matrix
131
132 if ((i == x) && (j == y))
133 continue; // --- skip: current node
134
135 if ((i != x) && (j != y))
136 continue; // --- skip: diagonals (move only vertical or horizontal)
137
138 int cost = _linkMatrix.cost(i,j);
139 if (! cost)
140 continue; // --- skip: blocked
141
142 pair<int,int> pos(i,j);
144 continue; // --- skip: already in closed list
145
146 tmp.setGCost(_closedList[currentNode].getGCost() + cost*distance(x, y, i, j));
147 tmp.setHCost(distance(i, j, _to.getX(), _to.getY()));
148 tmp.setFCost(tmp.getGCost() + tmp.getHCost());
149 if (isAlreadyInList(pos, _openList))
150 {
151 if (tmp.getFCost() < _openList[pos].getFCost())
152 {
153 _openList[pos] = tmp; // --- new path better, update node
154 _pq.push(Cost(tmp.getFCost(),pos));
155 }
156 }
157 else
158 {
159 _openList[pos] = tmp; // --- add node
160 _pq.push(Cost(tmp.getFCost(),pos));
161 }
162 }
163 }
164}
int getX() const
Definition: LinkMatrix.hxx:52
int getY() const
Definition: LinkMatrix.hxx:53
bool isAlreadyInList(std::pair< int, int > n, const LNodeMap &aList)
Definition: LinkAStar.cxx:109
double distance(int i1, int j1, int i2, int j2)
Definition: LinkAStar.hxx:83
int cost(int i, int j) const
Definition: LinkMatrix.hxx:98
References _closedList, _linkMatrix, _openList, _pq, _to, YACS::HMI::LinkMatrix::cost(), distance(), YACS::HMI::LCostNode::getFCost(), YACS::HMI::LCostNode::getGCost(), YACS::HMI::LCostNode::getHCost(), YACS::HMI::LNode::getX(), YACS::HMI::LNode::getY(), yacsorb.CORBAEngineTest::i, YACS::HMI::LinkMatrix::imax(), isAlreadyInList(), YACS::HMI::LinkMatrix::jmax(), YACS::HMI::LCostNode::setFCost(), YACS::HMI::LCostNode::setGCost(), and YACS::HMI::LCostNode::setHCost().
Referenced by computePath().
◆ bestNode()
std::pair< int, int > LinkAStar::bestNode ( const LNodeMap &  aList)
Definition at line 166 of file LinkAStar.cxx.
167{
168 std::pair<int, int> pos;
169 do
170 {
171 pos=_pq.top().pos;
172 _pq.pop();
173 }
174 while(aList.count(pos)==0);
175 return pos;
176}
References _pq.
◆ computePath()
bool LinkAStar::computePath ( LNode  from,
LNode  to
Definition at line 58 of file LinkAStar.cxx.
59{
60 _closedList.clear();
61 _openList.clear();
62 _pq=std::priority_queue<Cost>();
63 _from = from;
64 _to = to;
65 bool isPath = false;
66
67 //pair<int, int> curPos(0, 0);
68 //LCostNode startCost(curPos);
69
70 pair<int, int> curPos = _from.getPos();
71 LCostNode startCost(curPos);
72 _openList[curPos] = startCost;
73 moveToClosedList(curPos);
74 addNeighbours(curPos);
75
76 while (! ((curPos.first == _to.getX()) && (curPos.second == _to.getY()))
77 && (!_openList.empty()))
78 {
79 curPos = bestNode(_openList);
80 moveToClosedList(curPos);
81 DEBTRACE("curPos(" << curPos.first << "," << curPos.second << ")");
82 addNeighbours(curPos);
83 }
84
85 if ((curPos.first == _to.getX()) && (curPos.second == _to.getY()))
86 isPath = true;
87
88 return isPath;
89}
std::pair< int, int > getPos() const
Definition: LinkMatrix.hxx:54
std::pair< int, int > bestNode(const LNodeMap &aList)
Definition: LinkAStar.cxx:166
void moveToClosedList(std::pair< int, int > n)
Definition: LinkAStar.cxx:178
void addNeighbours(std::pair< int, int > n)
Definition: LinkAStar.cxx:118
References _closedList, _from, _openList, _pq, _to, addNeighbours(), bestNode(), DEBTRACE, YACS::HMI::LNode::getPos(), YACS::HMI::LNode::getX(), YACS::HMI::LNode::getY(), and moveToClosedList().
Referenced by YACS::HMI::SceneComposedNodeItem::rebuildLinks().
◆ distance()
double YACS::HMI::LinkAStar::distance ( int  i1,
int  j1,
int  i2,
int  j2
Definition at line 83 of file LinkAStar.hxx.
83{ return abs(i1-i2)+abs(j1-j2);};
References testCppPluginInvokation::i1.
Referenced by addNeighbours().
◆ givePath()
LNodePath LinkAStar::givePath ( )
Definition at line 91 of file LinkAStar.cxx.
92{
93 LNodePath aPath;
94 aPath.clear();
95 aPath.push_front(_to);
96
97 LNode current = _to;
98 while (! current.isEqual(_from))
99 {
100 current = LNode(_closedList[current.getPos()].getParent());
101 aPath.push_front(current);
102 DEBTRACE("(" << current.getX() << "," << current.getY() << ")");
103 }
104// aPath.push_front(_from);
105// DEBTRACE("(" << _from.getX() << "," << _from.getY() << ")");
106 return aPath;
107}
bool isEqual(const LNode &o) const
Definition: LinkMatrix.hxx:55
std::list< LNode > LNodePath
Definition: LinkMatrix.hxx:62
References _closedList, _from, _to, DEBTRACE, YACS::HMI::LNode::getPos(), YACS::HMI::LNode::getX(), YACS::HMI::LNode::getY(), and YACS::HMI::LNode::isEqual().
◆ isAlreadyInList()
bool LinkAStar::isAlreadyInList ( std::pair< int, int >  n,
Definition at line 109 of file LinkAStar.cxx.
110{
111 LNodeMap::const_iterator it = aList.find(n);
112 if (it == aList.end())
113 return false;
114 else
115 return true;
116}
References gui.Appli::n.
◆ moveToClosedList()
void LinkAStar::moveToClosedList ( std::pair< int, int >  n)
Definition at line 178 of file LinkAStar.cxx.
179{
180 _closedList[pos] = _openList[pos];
181 if (_openList.erase(pos) == 0)
182 DEBTRACE("node not in open list, can't delete");
183}
References _closedList, _openList, and DEBTRACE.
◆ _closedList
LNodeMap YACS::HMI::LinkAStar::_closedList
Definition at line 86 of file LinkAStar.hxx.
Referenced by addNeighbours(), computePath(), givePath(), LinkAStar(), and moveToClosedList().
◆ _from
LNode YACS::HMI::LinkAStar::_from
Definition at line 88 of file LinkAStar.hxx.
Referenced by computePath(), and givePath().
◆ _linkMatrix
const LinkMatrix& YACS::HMI::LinkAStar::_linkMatrix
Definition at line 85 of file LinkAStar.hxx.
◆ _openList
LNodeMap YACS::HMI::LinkAStar::_openList
Definition at line 87 of file LinkAStar.hxx.
Referenced by addNeighbours(), computePath(), LinkAStar(), and moveToClosedList().
◆ _pq
std::priority_queue<Cost> YACS::HMI::LinkAStar::_pq
Definition at line 90 of file LinkAStar.hxx.
Referenced by addNeighbours(), bestNode(), computePath(), and LinkAStar().
◆ _to
LNode YACS::HMI::LinkAStar::_to
Definition at line 89 of file LinkAStar.hxx.
Referenced by addNeighbours(), computePath(), and givePath().
