saemul.cxx
20#include "saemul.hxx"
21
22#include "saconst.h"
23
24#include "math.h"
27{
28 solver = new SalomeTest((Superviseur &) *this);
29}
30
32{
33 delete solver;
34 destroyAll();
35}
36
38{
39 std::pair<long,std::vector<double> *> pa;
40
41 while (! q.empty()) {
42 pa = q.front();
43 q.pop();
44 delete pa.second;
45 }
46}
47
48void Emulator::push(long id, std::vector<double> &cal)
49{
50 std::pair<long, std::vector<double> *> *tmp;
51
52 tmp = new std::pair<long, std::vector<double> *>(id, &cal);
53 q.push(*tmp);
54 delete tmp;
55}
56
58{
59 std::vector<double> *cal;
60 std::pair<long,std::vector<double> *> pa;
61
62 pa = q.front(); q.pop();
63 cal = pa.second;
64 out = eval(*cal);
65 delete cal;
66 return pa.first;
67}
68
69std::vector<double> *Emulator::getCurrentOut(void)
70{
71 return out;
72}
73
74std::vector<double> *Emulator::eval(std::vector<double> &x)
75{
76 std::vector<double> *res;
77 res = new std::vector<double>(1);
78#ifdef TRIPOD
79 //Tripod
80 double x1, x2;
81
82 x1 = x[0]; x2 = x[1];
83
84 if (x2 < 0)
85 (*res)[0] = fabs(x1) + fabs(x2+50);
86 else {
87 (*res)[0] = fabs(x2-50);
88 if (x1 < 0)
89 (*res)[0] += 1 + fabs(x1+50);
90 else
91 (*res)[0] += 2 + fabs(x1-50);
92 }
93#endif
94#ifdef ROSENBROCK
95 // rosenbrock
96 double x1, x2;
97
98 x1 = x[0] ; x2 = x1*x1 - x[1]; x1 -= 1;
99 (*res)[0] = x1*x1 + 100*x2*x2 ;
100#endif
101#ifdef GRIEWANK
102 double x1, x2, y;
103 int i;
104
105 x1 = 0.0; x2 = 1.0;
106 for (i=0; i<NBGENE; i++) {
107 y = 3*x[i] - 100;
108 x1 += y*y;
109 x2 *= cos(y/sqrt(i+1));
110 }
111 (*res)[0] = x1 / 4000 - x2 + 1;
112#endif
113 return res;
114}
115
117{
118 solver->readFromFile("caca");
119 solver->start();
120 while (! q.empty())
121 solver->next();
122 solver->finish();
123}
124
void push(long id, std::vector< double > &cal)
Definition: saemul.cxx:48
void run(void)
Definition: saemul.cxx:116
Emulator(void)
Definition: saemul.cxx:26
std::vector< double > * eval(std::vector< double > &x)
Definition: saemul.cxx:74
void destroyAll(void)
Definition: saemul.cxx:37
std::vector< double > * getCurrentOut(void)
Definition: saemul.cxx:69
~Emulator(void)
Definition: saemul.cxx:31
std::queue< std::pair< long, std::vector< double > * > > q
Definition: saemul.hxx:34
std::vector< double > * out
Definition: saemul.hxx:35
long getCurrentId(void)
Definition: saemul.cxx:57
SalomeTest * solver
Definition: saemul.hxx:33
void readFromFile(std::string)
Definition: saclass.cxx:60
void start(void)
Definition: saclass.cxx:87
void finish(void)
Definition: saclass.cxx:98
void next(void)
Definition: saclass.cxx:92
#define NBGENE
Definition: saconst.h:50
