MEDCoupling::BlockTopology Class Reference
#include <BlockTopology.hxx>
Inheritance diagram for MEDCoupling::BlockTopology:
Collaboration diagram for MEDCoupling::BlockTopology:
 BlockTopology ()
 BlockTopology (const BlockTopology &geom_topo, const ComponentTopology &comp_topo)
 BlockTopology (const ProcessorGroup &group, mcIdType nb_elem)
 BlockTopology (const ProcessorGroup &group, MEDCouplingCMesh *grid)
int getDimension () const
std::vector< std::pair< int, mcIdType > > getLocalArrayMinMax () const
mcIdType getNbElements () const
mcIdType getNbLocalElements () const
const ProcessorGroup * getProcGroup () const
std::pair< int, mcIdType > globalToLocal (const mcIdType) const
mcIdType localToGlobal (const std::pair< int, mcIdType >) const
void release ()
void serialize (mcIdType *&serializer, mcIdType &size) const
void unserialize (const mcIdType *serializer, const CommInterface &comm_interface)
virtual ~BlockTopology ()
- Public Member Functions inherited from MEDCoupling::Topology
virtual mcIdType getNbElements () const =0
virtual mcIdType getNbLocalElements () const =0
virtual const ProcessorGroup * getProcGroup () const =0
 Topology ()
virtual ~Topology ()
A BlockTopology typically represents the split of a structured mesh among the processors of a common ProcessorGroup. Each processor gets a contiguous part of the cells in the mesh (a block).
A BlockTopology can also be used to split a structured domain among the various components of a field.
See also
ExplicitTopology
◆ BlockTopology() [1/4]
MEDCoupling::BlockTopology::BlockTopology ( )
Default ctor.
◆ BlockTopology() [2/4]
MEDCoupling::BlockTopology::BlockTopology ( const ProcessorGroup &  group,
MEDCouplingCMesh *  grid
Constructor of a block topology from a grid. This preliminary version simply splits along the first axis instead of making the best choice with respect to the values of the different axes.
References MEDCoupling::Block, MEDCoupling::MEDCouplingCMesh::getCoordsAt(), MEDCoupling::DataArrayTemplate< T >::getNbOfElems(), and MEDCoupling::ProcessorGroup::size().
◆ BlockTopology() [3/4]
MEDCoupling::BlockTopology::BlockTopology ( const BlockTopology &  geom_topo,
const ComponentTopology &  comp_topo
Creation of a block topology by composing a geometrical topology and a component topology. This constructor is intended for creating fields for which the parallel distribution is made on the components of the field rather than on the geometrical partitioning of the underlying mesh.
References MEDCoupling::Block, MEDCoupling::ComponentTopology::getBlockIndices(), getDimension(), getNbElements(), getProcGroup(), MEDCoupling::ComponentTopology::getProcGroup(), MEDCoupling::ComponentTopology::nbBlocks(), MEDCoupling::ComponentTopology::nbComponents(), and MEDCoupling::ProcessorGroup::size().
◆ BlockTopology() [4/4]
mcIdType  nb_elem
Constructor for creating a one-dimensional topology from a processor group and a local number of elements on each processor
The function must be called only by the processors belonging to group group. Calling it from a processor not belonging to group will cause an MPI error, while calling from a subset of group will result in a deadlock.
References MEDCoupling::CommInterface::allGather(), MEDCoupling::Block, MEDCoupling::MPIProcessorGroup::getComm(), MEDCoupling::ProcessorGroup::getCommInterface(), and MEDCoupling::ProcessorGroup::size().
◆ ~BlockTopology()
MEDCoupling::BlockTopology::~BlockTopology ( )
References release().
◆ release()
void MEDCoupling::BlockTopology::release ( )
Destructor involves MPI operations: make sure this is accessible from a proper method for Python wrapping.
Referenced by ~BlockTopology().
◆ getNbElements()
mcIdType MEDCoupling::BlockTopology::getNbElements ( ) const
Retrieves the number of elements for a given topology.
Implements MEDCoupling::Topology.
Referenced by BlockTopology().
◆ getNbLocalElements()
◆ getProcGroup()
◆ globalToLocal()
std::pair< int, mcIdType > MEDCoupling::BlockTopology::globalToLocal ( const mcIdType  global) const
◆ localToGlobal()
mcIdType MEDCoupling::BlockTopology::localToGlobal ( const std::pair< int, mcIdType >  ) const
◆ getLocalArrayMinMax()
std::vector< std::pair< int, mcIdType > > MEDCoupling::BlockTopology::getLocalArrayMinMax ( ) const
Retrieves the min and max indices of the domain stored locally for each dimension. The output vector has the topology dimension as a size and each pair <int,int> contains min and max. Indices range from min to max-1.
References MEDCoupling::ProcessorGroup::myRank().
◆ getDimension()
int MEDCoupling::BlockTopology::getDimension ( ) const
◆ serialize()
void MEDCoupling::BlockTopology::serialize ( mcIdType *&  serializer,
mcIdType &  size
Serializes the data contained in the Block Topology for communication purposes
References MEDCoupling::ProcessorGroup::getCommInterface(), MEDCoupling::ProcessorGroup::size(), and MEDCoupling::MPIProcessorGroup::translateRank().
◆ unserialize()
void MEDCoupling::BlockTopology::unserialize ( const mcIdType *  serializer,
const CommInterface &  comm_interface
Unserializes the data contained in the Block Topology after communication. Uses the same structure as the one used for serialize()
