MEDCoupling::MPIProcessorGroup Class Reference
#include <MPIProcessorGroup.hxx>
Inheritance diagram for MEDCoupling::MPIProcessorGroup:
Collaboration diagram for MEDCoupling::MPIProcessorGroup:
bool containsMyRank () const override
ProcessorGroup * createComplementProcGroup () const
ProcessorGroup * createProcGroup () const override
MPIProcessorGroup * deepCopy () const override
ProcessorGroup * fuse (const ProcessorGroup &) const override
const MPI_Comm * getComm () const
MPI_Group getGroup () const
MPI_Comm getWorldComm ()
void intersect (ProcessorGroup &) override
 MPIProcessorGroup (const CommInterface &interface)
 MPIProcessorGroup (const CommInterface &interface, int pstart, int pend, const MPI_Comm &world_comm=MPI_COMM_WORLD)
 MPIProcessorGroup (const CommInterface &interface, std::map< std::string, std::set< int > > proc_ids_by_name, const std::string &simCodeTag, const MPI_Comm &world_comm=MPI_COMM_WORLD)
 MPIProcessorGroup (const CommInterface &interface, std::set< int > proc_ids, const MPI_Comm &world_comm=MPI_COMM_WORLD)
 MPIProcessorGroup (const MPIProcessorGroup &other)
 MPIProcessorGroup (const ProcessorGroup &proc_group, std::set< int > proc_ids)
int myRank () const override
void release ()
int translateRank (const ProcessorGroup *group, int rank) const override
virtual ~MPIProcessorGroup ()
- Public Member Functions inherited from MEDCoupling::ProcessorGroup
bool contains (int rank) const
virtual bool containsMyRank () const =0
virtual ProcessorGroup * createComplementProcGroup () const =0
virtual ProcessorGroup * createProcGroup () const =0
virtual ProcessorGroup * deepCopy () const =0
virtual ProcessorGroup * fuse (const ProcessorGroup &) const =0
const CommInterface & getCommInterface () const
virtual const std::set< int > & getProcIDs () const
virtual const std::set< int > & getProcIDsByName (const std::string &simCodeTag) const
virtual void intersect (ProcessorGroup &)=0
virtual int myRank () const =0
 ProcessorGroup (const CommInterface &interface, int start, int end)
 ProcessorGroup (const CommInterface &interface, std::map< std::string, std::set< int > > proc_ids_by_name, const std::string &simCodeTag)
 ProcessorGroup (const CommInterface &interface, std::set< int > proc_ids)
 ProcessorGroup (const ProcessorGroup &other)
int size () const
virtual int translateRank (const ProcessorGroup *, int) const =0
virtual ~ProcessorGroup ()
- Protected Attributes inherited from MEDCoupling::ProcessorGroup
const CommInterface _comm_interface
std::set< int > _proc_ids
std::map< std::string, std::set< int > > _proc_ids_by_name
The MPIProcessorGroup class represents a set of distinct "processors" (computation nodes) in a MPI code. It is used to define the MPI topology of code couplings.
Groups can be set up in various ways, the most common being the use of the MPIProcessorGroup(Comminterface, int pfirst, int plast) constructor.
The following code excerpt creates two processor groups on respectively 3 and 2 processors.
int main()
MPI_Init(&argc,&argv);
CommInterface comm_interface;
MPIProcessorGroup codeA_group(comm_interface, 0, 2);  // groups processors 0, 1 and 2
MPIProcessorGroup codeB_group(comm_interface, 3, 4);  // groups processors 3 and 4
◆ MPIProcessorGroup() [1/6]
MEDCoupling::MPIProcessorGroup::MPIProcessorGroup ( const CommInterface &  interface)
Creates a processor group that is based on all the processors of MPI_COMM_WORLD .This routine must be called by all processors in MPI_COMM_WORLD.
interfaceCommInterface object giving access to the MPI communication layer
References MEDCoupling::ProcessorGroup::_comm_interface, MEDCoupling::ProcessorGroup::_proc_ids, MEDCoupling::CommInterface::commGroup(), MEDCoupling::CommInterface::commSize(), and MEDCoupling::ProcessorGroup::size().
Referenced by createComplementProcGroup(), createProcGroup(), deepCopy(), and fuse().
◆ MPIProcessorGroup() [2/6]
MEDCoupling::MPIProcessorGroup::MPIProcessorGroup ( const CommInterface &  interface,
const MPI_Comm &  world_comm = MPI_COMM_WORLD
Creates a processor group that is based on the processors included in proc_ids. This routine must be called by all processors in MPI_COMM_WORLD.
proc_idsset of ids that are to be integrated in the group. The ids number are to be understood in terms of MPI_COMM_WORLD ranks.
◆ MPIProcessorGroup() [3/6]
const std::string &  simCodeTag,
Creates a processor group that is based on the processors included in proc_ids_by_name[name]. This routine must be called by all processors in MPI_COMM_WORLD.
proc_ids_by_namea map defining a relation between a name and a set of ids that are to be integrated in the group. The ids number are to be understood in terms of MPI_COMM_WORLD ranks.
simCodeTagidentifier of the group
◆ MPIProcessorGroup() [4/6]
MEDCoupling::MPIProcessorGroup::MPIProcessorGroup ( const ProcessorGroup &  proc_group,
◆ MPIProcessorGroup() [5/6]
MEDCoupling::MPIProcessorGroup::MPIProcessorGroup ( const CommInterface &  comm_interface,
int  pstart,
int  pend,
Creates a processor group that is based on the processors between pstart and pend. This routine must be called by all processors in MPI_COMM_WORLD.
comm_interfaceCommInterface object giving access to the MPI communication layer
pstartid in MPI_COMM_WORLD of the first processor in the group
pendid in MPI_COMM_WORLD of the last processor in the group
References MEDCoupling::ProcessorGroup::_comm_interface, MEDCoupling::CommInterface::commCreate(), MEDCoupling::CommInterface::commGroup(), MEDCoupling::CommInterface::commRank(), MEDCoupling::CommInterface::commSize(), MEDCoupling::CommInterface::groupFree(), and MEDCoupling::CommInterface::groupIncl().
◆ MPIProcessorGroup() [6/6]
MEDCoupling::MPIProcessorGroup::MPIProcessorGroup ( const MPIProcessorGroup &  other)
◆ ~MPIProcessorGroup()
MEDCoupling::MPIProcessorGroup::~MPIProcessorGroup ( )
References release().
◆ release()
void MEDCoupling::MPIProcessorGroup::release ( )
Destructor involves MPI operations: make sure this is accessible from a proper method for Python wrapping.
References MEDCoupling::ProcessorGroup::_comm_interface, MEDCoupling::CommInterface::commFree(), and MEDCoupling::CommInterface::groupFree().
Referenced by ~MPIProcessorGroup().
◆ deepCopy()
MPIProcessorGroup * MEDCoupling::MPIProcessorGroup::deepCopy ( ) const
overridevirtual
◆ fuse()
ProcessorGroup * MEDCoupling::MPIProcessorGroup::fuse ( const ProcessorGroup &  group) const
overridevirtual
Adding processors of group group to local group.
groupgroup that is to be fused with current group
new group formed by the fusion of local group and group.
Implements MEDCoupling::ProcessorGroup.
References MEDCoupling::ProcessorGroup::_comm_interface, MEDCoupling::ProcessorGroup::_proc_ids, MEDCoupling::ProcessorGroup::getProcIDs(), and MPIProcessorGroup().
◆ intersect()
void MEDCoupling::MPIProcessorGroup::intersect ( ProcessorGroup &  )
overridevirtual
◆ myRank()
int MEDCoupling::MPIProcessorGroup::myRank ( ) const
overridevirtual
◆ containsMyRank()
bool MEDCoupling::MPIProcessorGroup::containsMyRank ( ) const
overridevirtual
◆ translateRank()
int MEDCoupling::MPIProcessorGroup::translateRank ( const ProcessorGroup *  group,
int  rank
overridevirtual
Translation of the rank id between two processor groups. This method translates rank rank on the current processor group to the rank on group pointed by group.
groupgroup from which the rank is expected
rankrank on group group of the processor which is to be translated
rank on local group
Referenced by MEDCoupling::StructuredCoincidentDEC::prepareSourceDE(), MEDCoupling::ExplicitCoincidentDEC::prepareTargetDE(), MEDCoupling::StructuredCoincidentDEC::prepareTargetDE(), MEDCoupling::ExplicitCoincidentDEC::recvData(), MEDCoupling::StructuredCoincidentDEC::recvData(), MEDCoupling::BlockTopology::serialize(), and MEDCoupling::ExplicitCoincidentDEC::transferMappingToSource().
◆ getComm()
◆ createComplementProcGroup()
ProcessorGroup * MEDCoupling::MPIProcessorGroup::createComplementProcGroup ( ) const
Creates a processor group that is the complement of the current group inside MPI_COMM_WORLD
pointer to the new ProcessorGroup structure.
References MEDCoupling::ProcessorGroup::_comm_interface, MEDCoupling::ProcessorGroup::_proc_ids, MPIProcessorGroup(), and MEDCoupling::CommInterface::worldSize().
◆ createProcGroup()
ProcessorGroup * MEDCoupling::MPIProcessorGroup::createProcGroup ( ) const
overridevirtual
◆ getWorldComm()
MPI_Comm MEDCoupling::MPIProcessorGroup::getWorldComm ( )
◆ getGroup()
MPI_Group MEDCoupling::MPIProcessorGroup::getGroup ( ) const
