MEDCoupling::MEDFileFloatField1TS Class Reference
#include <MEDFileField1TS.hxx>
Inheritance diagram for MEDCoupling::MEDFileFloatField1TS:
Collaboration diagram for MEDCoupling::MEDFileFloatField1TS:
Friends
class MEDFileTemplateField1TS< float >
- Public Member Functions inherited from MEDCoupling::MEDFileNDTemplateField1TS< float >
MEDFileField1TS * convertToDouble (bool isDeepCpyGlobs=true) const
MEDFileField1TS * convertToInt (bool isDeepCpyGlobs=true) const
MEDFileField1TS * convertToInt64 (bool isDeepCpyGlobs=true) const
- Public Member Functions inherited from MEDCoupling::MEDFileTemplateField1TS< float >
void copyTimeInfoFrom (const typename Traits< float >::FieldType *mcf)
MEDFileAnyTypeField1TS * extractPart (const std::map< int, MCAuto< DataArrayIdType > > &extractDef, MEDFileMesh *mm) const
MLFieldTraits< float >::F1TSType * extractPartImpl (const std::map< int, MCAuto< DataArrayIdType > > &extractDef, MEDFileMesh *mm) const
Traits< float >::FieldType * field (const MEDFileMesh *mesh) const
Traits< float >::FieldType * getFieldAtLevel (TypeOfField type, int meshDimRelToMax, int renumPol=0) const
Traits< float >::FieldType * getFieldAtLevelOld (TypeOfField type, const std::string &mname, int meshDimRelToMax, int renumPol=0) const
Traits< float >::FieldType * getFieldAtTopLevel (TypeOfField type, int renumPol=0) const
Traits< float >::FieldType * getFieldOnMeshAtLevel (TypeOfField type, const MEDCouplingMesh *mesh, int renumPol=0) const
Traits< float >::FieldType * getFieldOnMeshAtLevel (TypeOfField type, int meshDimRelToMax, const MEDFileMesh *mesh, int renumPol=0) const
Traits< float >::ArrayType * getFieldWithProfile (TypeOfField type, int meshDimRelToMax, const MEDFileMesh *mesh, DataArrayIdType *&pfl) const
Traits< float >::ArrayType * getUndergroundDataArray () const
Traits< float >::ArrayType * getUndergroundDataArrayExt (std::vector< std::pair< std::pair< INTERP_KERNEL::NormalizedCellType, int >, std::pair< mcIdType, mcIdType > > > &entries) const
void setArray (DataArray *arr)
void setFieldNoProfileSBT (const typename Traits< float >::FieldType *field)
void setFieldProfile (const typename Traits< float >::FieldType *field, const MEDFileMesh *mesh, int meshDimRelToMax, const DataArrayIdType *profile)
void setFieldProfileFlatly (const typename Traits< float >::FieldType *field, const MEDFileMesh *mesh, int meshDimRelToMax, const DataArrayIdType *profile)
- Public Member Functions inherited from MEDCoupling::MEDFileAnyTypeField1TS
virtual MCAuto< MEDFileAnyTypeField1TS > buildNewEmpty () const =0
void changeLocsRefsNamesGen (const std::vector< std::pair< std::vector< std::string >, std::string > > &mapOfModif)
bool changeMeshNames (const std::vector< std::pair< std::string, std::string > > &modifTab)
void changePflsRefsNamesGen (const std::vector< std::pair< std::vector< std::string >, std::string > > &mapOfModif)
MEDFileAnyTypeField1TSWithoutSDA * contentNotNullBase ()
const MEDFileAnyTypeField1TSWithoutSDA * contentNotNullBase () const
void convertMedBallIntoClassic ()
mcIdType copyTinyInfoFrom (const MEDCouplingFieldDouble *field, const DataArray *arr)
mcIdType copyTinyInfoFrom (const TimeHolder *th, const MEDCouplingFieldTemplate *field, const DataArray *arr)
MEDFileAnyTypeField1TS * deepCopy () const
virtual MEDFileAnyTypeField1TS * extractPart (const std::map< int, MCAuto< DataArrayIdType > > &extractDef, MEDFileMesh *mm) const =0
void fillIteration (std::pair< int, int > &p) const
void fillTypesOfFieldAvailable (std::vector< TypeOfField > &types) const
std::string getDescription () const
int getDimension () const
std::pair< int, int > getDtIt () const
std::string getDtUnit () const
std::vector< std::vector< std::pair< mcIdType, mcIdType > > > getFieldSplitedByType (const std::string &mname, std::vector< INTERP_KERNEL::NormalizedCellType > &types, std::vector< std::vector< TypeOfField > > &typesF, std::vector< std::vector< std::string > > &pfls, std::vector< std::vector< std::string > > &locs) const
std::vector< std::string > & getInfo ()
const std::vector< std::string > & getInfo () const
int getIteration () const
MEDFileFieldPerMeshPerTypePerDisc * getLeafGivenMeshAndTypeAndLocId (const std::string &mName, INTERP_KERNEL::NormalizedCellType typ, int locId)
const MEDFileFieldPerMeshPerTypePerDisc * getLeafGivenMeshAndTypeAndLocId (const std::string &mName, INTERP_KERNEL::NormalizedCellType typ, int locId) const
std::vector< std::string > getLocsReallyUsed () const
std::vector< std::string > getLocsReallyUsedMulti () const
virtual med_field_type getMEDFileFieldType () const =0
int getMeshIteration () const
std::string getMeshName () const
int getMeshOrder () const
std::string getName () const
int getNonEmptyLevels (const std::string &mname, std::vector< int > &levs) const
std::size_t getNumberOfComponents () const
int getOrder () const
std::vector< std::string > getPflsReallyUsed () const
std::vector< std::string > getPflsReallyUsedMulti () const
double getTime (int &iteration, int &order) const
std::vector< TypeOfField > getTypesOfFieldAvailable () const
bool isDealingTS (int iteration, int order) const
void loadArrays ()
void loadArraysIfNecessary ()
void makeReduction (INTERP_KERNEL::NormalizedCellType ct, TypeOfField tof, const DataArrayIdType *pfl)
bool presenceOfMultiDiscPerGeoType () const
void setDescription (const std::string &description)
void setDtUnit (const std::string &dtUnit)
void setInfo (const std::vector< std::string > &infos)
void setLocNameOnLeaf (const std::string &mName, INTERP_KERNEL::NormalizedCellType typ, int locId, const std::string &newLocName, bool forceRenameOnGlob=false)
void setMeshName (const std::string &newMeshName)
void setProfileNameOnLeaf (const std::string &mName, INTERP_KERNEL::NormalizedCellType typ, int locId, const std::string &newPflName, bool forceRenameOnGlob=false)
void setTime (int iteration, int order, double val)
virtual MEDFileAnyTypeField1TS * shallowCpy () const =0
std::string simpleRepr () const
void simpleRepr (int bkOffset, std::ostream &oss, int f1tsId) const
std::vector< MCAuto< MEDFileAnyTypeField1TS > > splitComponents () const
std::vector< MCAuto< MEDFileAnyTypeField1TS > > splitDiscretizations () const
std::vector< MCAuto< MEDFileAnyTypeField1TS > > splitMultiDiscrPerGeoTypes () const
void unloadArrays ()
void unloadArraysWithoutDataLoss ()
bool decrRef () const
int getRCValue () const
void incrRef () const
virtual ~BigMemoryObject ()
- Public Member Functions inherited from MEDCoupling::MEDFileFieldGlobsReal
void appendGlobs (const MEDFileFieldGlobsReal &other, double eps)
void appendLoc (const std::string &locName, INTERP_KERNEL::NormalizedCellType geoType, const std::vector< double > &refCoo, const std::vector< double > &gsCoo, const std::vector< double > &w)
void appendProfile (DataArrayIdType *pfl)
void changeLocName (const std::string &oldName, const std::string &newName)
void changeLocsNames (const std::vector< std::pair< std::vector< std::string >, std::string > > &mapOfModif)
void changeLocsNamesInStruct (const std::vector< std::pair< std::vector< std::string >, std::string > > &mapOfModif)
virtual void changeLocsRefsNamesGen (const std::vector< std::pair< std::vector< std::string >, std::string > > &mapOfModif)=0
void changePflName (const std::string &oldName, const std::string &newName)
void changePflsNames (const std::vector< std::pair< std::vector< std::string >, std::string > > &mapOfModif)
void changePflsNamesInStruct (const std::vector< std::pair< std::vector< std::string >, std::string > > &mapOfModif)
virtual void changePflsRefsNamesGen (const std::vector< std::pair< std::vector< std::string >, std::string > > &mapOfModif)=0
void checkGlobsCoherency () const
void checkGlobsLocsPartCoherency () const
void checkGlobsPflsPartCoherency () const
std::string createNewNameOfLoc () const
std::string createNewNameOfPfl () const
void deepCpyGlobs (const MEDFileFieldGlobsReal &other)
void deepCpyOnlyUsedGlobs (const MEDFileFieldGlobsReal &other)
bool existsLoc (const std::string &locName) const
bool existsPfl (const std::string &pflName) const
std::string getFileName () const
MEDFileFieldLoc & getLocalization (const std::string &locName)
const MEDFileFieldLoc & getLocalization (const std::string &locName) const
MEDFileFieldLoc & getLocalizationFromId (int locId)
const MEDFileFieldLoc & getLocalizationFromId (int locId) const
int getLocalizationId (const std::string &loc) const
std::vector< std::string > getLocs () const
virtual std::vector< std::string > getLocsReallyUsed () const =0
virtual std::vector< std::string > getLocsReallyUsedMulti () const =0
int getNbOfGaussPtPerCell (int locId) const
std::vector< std::string > getPfls () const
virtual std::vector< std::string > getPflsReallyUsed () const =0
virtual std::vector< std::string > getPflsReallyUsedMulti () const =0
DataArrayIdType * getProfile (const std::string &pflName)
const DataArrayIdType * getProfile (const std::string &pflName) const
DataArrayIdType * getProfileFromId (int pflId)
const DataArrayIdType * getProfileFromId (int pflId) const
int getProfileId (const std::string &pfl) const
void killLocalizationIds (const std::vector< int > &locIds)
void killProfileIds (const std::vector< int > &pflIds)
void killStructureElementsInGlobs ()
void loadAllGlobals (med_idt fid, const MEDFileEntities *entities=0)
void loadGlobals (med_idt fid)
void loadProfileInFile (med_idt fid, int id)
void loadProfileInFile (med_idt fid, int id, const std::string &pflName)
 MEDFileFieldGlobsReal ()
 MEDFileFieldGlobsReal (med_idt fid)
void resetContent ()
void setFileName (const std::string &fileName)
void shallowCpyGlobs (const MEDFileFieldGlobsReal &other)
void shallowCpyOnlyUsedGlobs (const MEDFileFieldGlobsReal &other)
void simpleReprGlobs (std::ostream &oss) const
std::vector< std::vector< int > > whichAreEqualLocs (double eps) const
std::vector< std::vector< int > > whichAreEqualProfiles () const
void writeGlobals (med_idt fid, const MEDFileWritable &opt) const
std::vector< std::pair< std::vector< std::string >, std::string > > zipLocsNames (double eps)
std::vector< std::pair< std::vector< std::string >, std::string > > zipPflsNames ()
virtual ~MEDFileFieldGlobsReal ()
- Static Public Member Functions inherited from MEDCoupling::MEDFileTemplateField1TS< float >
static MLFieldTraits< float >::F1TSType * New ()
static MLFieldTraits< float >::F1TSType * New (const std::string &fileName, bool loadAll=true)
static MLFieldTraits< float >::F1TSType * New (const std::string &fileName, const std::string &fieldName, bool loadAll=true)
static MLFieldTraits< float >::F1TSType * New (const std::string &fileName, const std::string &fieldName, int iteration, int order, bool loadAll=true)
static MLFieldTraits< float >::F1TSType * New (const typename MLFieldTraits< float >::F1TSWSDAType &other, bool shallowCopyOfContent)
static MLFieldTraits< float >::F1TSType * New (DataArrayByte *db)
static MLFieldTraits< float >::F1TSType * New (med_idt fid, bool loadAll=true)
static MLFieldTraits< float >::F1TSType * New (med_idt fid, const std::string &fieldName, bool loadAll=true)
static MLFieldTraits< float >::F1TSType * New (med_idt fid, const std::string &fieldName, int iteration, int order, bool loadAll=true)
static Traits< float >::ArrayType * ReturnSafelyTypedDataArray (MCAuto< DataArray > &arr)
static MCAuto< typename Traits< float >::FieldType > SetDataArrayInField (MEDCouplingFieldDouble *f, MCAuto< DataArray > &arr)
static MCAuto< MEDCouplingFieldDouble > ToFieldTemplateWithTime (const typename Traits< float >::FieldType *f)
- Static Public Member Functions inherited from MEDCoupling::MEDFileAnyTypeField1TS
static int LocateField (med_idt fid, const std::string &fieldName, int &posCFormat, med_field_type &typcha, std::vector< std::string > &infos, std::string &dtunitOut, std::string &meshName)
static int LocateField2 (med_idt fid, int fieldIdCFormat, bool checkFieldId, std::string &fieldName, med_field_type &typcha, std::vector< std::string > &infos, std::string &dtunitOut, std::string &meshName)
static MEDFileAnyTypeField1TS * New (const std::string &fileName, bool loadAll=true)
static MEDFileAnyTypeField1TS * New (const std::string &fileName, const std::string &fieldName, bool loadAll=true)
static MEDFileAnyTypeField1TS * New (const std::string &fileName, const std::string &fieldName, int iteration, int order, bool loadAll=true)
static MEDFileAnyTypeField1TS * New (med_idt fid, bool loadAll=true)
static MEDFileAnyTypeField1TS * New (med_idt fid, const std::string &fieldName, bool loadAll=true)
static MEDFileAnyTypeField1TS * New (med_idt fid, const std::string &fieldName, int iteration, int order, bool loadAll=true)
static MEDFileAnyTypeField1TS * NewAdv (const std::string &fileName, const std::string &fieldName, int iteration, int order, bool loadAll, const MEDFileEntities *entities)
static MEDFileAnyTypeField1TS * NewAdv (med_idt fid, const std::string &fieldName, int iteration, int order, bool loadAll, const MEDFileEntities *entities)
static MEDFileAnyTypeField1TS * NewAdv (med_idt fid, const std::string &fieldName, int iteration, int order, const MEDFileEntities *entities, const std::vector< mcIdType > &distrib)
- Protected Member Functions inherited from MEDCoupling::MEDFileNDTemplateField1TS< float >
 MEDFileNDTemplateField1TS ()
 MEDFileNDTemplateField1TS (const typename MLFieldTraits< float >::F1TSWSDAType &other, bool shallowCopyOfContent)
 MEDFileNDTemplateField1TS (med_idt fid, bool loadAll, const MEDFileMeshes *ms)
 MEDFileNDTemplateField1TS (med_idt fid, const std::string &fieldName, bool loadAll, const MEDFileMeshes *ms)
 MEDFileNDTemplateField1TS (med_idt fid, const std::string &fieldName, int iteration, int order, bool loadAll, const MEDFileMeshes *ms)
 ~MEDFileNDTemplateField1TS ()
- Protected Member Functions inherited from MEDCoupling::MEDFileTemplateField1TS< float >
MLFieldTraits< float >::F1TSWSDAType * contentNotNull ()
const MLFieldTraits< float >::F1TSWSDAType * contentNotNull () const
 MEDFileTemplateField1TS ()
 MEDFileTemplateField1TS (const typename MLFieldTraits< float >::F1TSWSDAType &other, bool shallowCopyOfContent)
 MEDFileTemplateField1TS (med_idt fid, bool loadAll, const MEDFileMeshes *ms)
 MEDFileTemplateField1TS (med_idt fid, const std::string &fieldName, bool loadAll, const MEDFileMeshes *ms)
 MEDFileTemplateField1TS (med_idt fid, const std::string &fieldName, int iteration, int order, bool loadAll, const MEDFileMeshes *ms)
void setFieldProfileGeneral (const typename Traits< float >::FieldType *field, const MEDFileMesh *mesh, int meshDimRelToMax, const DataArrayIdType *profile, bool smartPflKiller)
 ~MEDFileTemplateField1TS ()
- Protected Member Functions inherited from MEDCoupling::MEDFileAnyTypeField1TS
 MEDFileAnyTypeField1TS ()
 MEDFileAnyTypeField1TS (const MEDFileAnyTypeField1TSWithoutSDA &other, bool shallowCopyOfContent)
 MEDFileAnyTypeField1TS (med_idt fid, bool loadAll, const MEDFileMeshes *ms, const MEDFileEntities *entities=0)
 MEDFileAnyTypeField1TS (med_idt fid, const std::string &fieldName, bool loadAll, const MEDFileMeshes *ms, const MEDFileEntities *entities=0)
 MEDFileAnyTypeField1TS (med_idt fid, const std::string &fieldName, int iteration, int order, bool loadAll, const MEDFileMeshes *ms, const MEDFileEntities *entities=0)
void writeLL (med_idt fid) const
 RefCountObject ()
virtual ~RefCountObject ()
 RefCountObjectOnly ()
- Protected Member Functions inherited from MEDCoupling::MEDFileFieldGlobsReal
MEDFileFieldGlobs * contentNotNull ()
const MEDFileFieldGlobs * contentNotNull () const
- Static Protected Member Functions inherited from MEDCoupling::MEDFileAnyTypeField1TS
static MEDFileAnyTypeField1TSWithoutSDA * AllocateContentFrom (med_idt fid, const std::string &fieldName, int iteration=-1, int order=-1)
static MEDFileAnyTypeField1TSWithoutSDA * BuildContentFrom (med_idt fid, bool loadAll, const MEDFileMeshes *ms, const MEDFileEntities *entities)
static MEDFileAnyTypeField1TSWithoutSDA * BuildContentFrom (med_idt fid, const std::string &fieldName, bool loadAll, const MEDFileMeshes *ms, const MEDFileEntities *entities)
static MEDFileAnyTypeField1TSWithoutSDA * BuildContentFrom (med_idt fid, const std::string &fieldName, int iteration, int order, bool loadAll, const MEDFileMeshes *ms, const MEDFileEntities *entities)
static MEDFileAnyTypeField1TSWithoutSDA * BuildContentFrom (med_idt fid, const std::string &fieldName, int iteration, int order, const PartDefinition *pd, const MEDFileEntities *entities)
static MEDFileAnyTypeField1TS * BuildNewInstanceFromContent (MEDFileAnyTypeField1TSWithoutSDA *c)
static MEDFileAnyTypeField1TS * BuildNewInstanceFromContent (MEDFileAnyTypeField1TSWithoutSDA *c, med_idt fid)
- Protected Attributes inherited from MEDCoupling::MEDFileAnyTypeField1TS
MCAuto< MEDFileAnyTypeField1TSWithoutSDA > _content
- Protected Attributes inherited from MEDCoupling::MEDFileFieldGlobsReal
MCAuto< MEDFileFieldGlobs > _globals
◆ MEDFileTemplateField1TS< float >
friend class MEDFileTemplateField1TS< float >
friend
