Home
NETGEN_1D2D3D_Algorithm_2 Class Reference
Tetrahedron (helper) 1D-2D-3D algorithm. More...
Inheritance diagram for NETGEN_1D2D3D_Algorithm_2:
def __init__ (self, mesh, geom=0)
 Private constructor. More...
Static Public Attributes
string meshMethod = "Netgen"
 name of the dynamic method in smeshBuilder.Mesh class More...
string docHelper = "Deprecated, used only for compatibility! See Tetrahedron() method."
 doc string of the method More...
This is the helper class that is used just to allow creating of create NETGEN_1D2D3D by calling smeshBuilder.Mesh.Netgen(); this is required for backward compatibility with old Python scripts.
This class (and corresponding smeshBuilder.Mesh function) is obsolete; use smeshBuilder.Mesh.Tetrahedron( smeshBuilder.NETGEN_1D2D3D, geom=0 ) instead.
◆ __init__()
def __init__ (   self,
  mesh,
  geom = 0
meshparent mesh object algorithm is assigned to
geomgeometry (shape/sub-shape) algorithm is assigned to; if it is 0 (default), the algorithm is assigned to the main shape
Reimplemented from NETGEN_1D2D3D_Algorithm.
◆ meshMethod
◆ docHelper
