Python API for the NETGEN meshing plug-in module. More...
Data Structures | |
| class | NETGEN_1D2D3D_Algorithm |
| Tetrahedron 1D-2D-3D algorithm. More... | |
| class | NETGEN_1D2D3D_Algorithm_2 |
| Tetrahedron (helper) 1D-2D-3D algorithm. More... | |
| class | NETGEN_1D2D_Algorithm |
| Triangle NETGEN 1D-2D algorithm. More... | |
| class | NETGEN_1D2D_Algorithm_2 |
| Triangle (helper) 1D-2D algorithm. More... | |
| class | NETGEN_2D_Only_Algorithm |
| Triangle NETGEN 2D algorithm. More... | |
| class | NETGEN_2D_Remote_Algorithm |
| Tetrahedron 2D algorithm. More... | |
| class | NETGEN_3D_Algorithm |
| Tetrahedron 3D algorithm. More... | |
| class | NETGEN_3D_Remote_Algorithm |
| class | NETGEN_Algorithm |
| Base of all NETGEN algorithms. More... | |
Variables | |
| int | noNETGENPlugin = 0 |
| string | LIBRARY = "libNETGENEngine.so" |
| NETGEN_VERSION_MAJOR = NETGENPlugin.NETGEN_VERSION_MAJOR | |
| string | NETGEN_3D = "NETGEN_3D" |
| Algorithm type: Netgen tetrahedron 3D algorithm, see NETGEN_3D_Algorithm. More... | |
| string | NETGEN_3D_Remote = "NETGEN_3D_Remote" |
| string | NETGEN_1D2D3D = "NETGEN_2D3D" |
| Algorithm type: Netgen tetrahedron 1D-2D-3D algorithm, see NETGEN_1D2D3D_Algorithm. More... | |
| string | NETGEN_1D2D = "NETGEN_2D" |
| Algorithm type: Netgen triangle 1D-2D algorithm, see NETGEN_1D2D_Algorithm. More... | |
| string | NETGEN_2D = "NETGEN_2D_ONLY" |
| Algorithm type: Netgen triangle 2D algorithm, see NETGEN_2D_Only_Algorithm. More... | |
| string | NETGEN_2D_Remote = "NETGEN_2D_Remote" |
| string | NETGEN_FULL = NETGEN_1D2D3D |
| Algorithm type: Synonim of NETGEN_1D2D3D, see NETGEN_1D2D3D_Algorithm. More... | |
| string | NETGEN = NETGEN_3D |
| Algorithm type: Synonim of NETGEN_3D, see NETGEN_3D_Algorithm. More... | |
| string | FULL_NETGEN = NETGEN_FULL |
| int | SOLE = 0 |
| Hypothesis type enumeration: complex hypothesis (full set of parameters can be specified), see NETGEN_Algorithm.Parameters() More... | |
| int | SIMPLE = 1 |
| Hypothesis type enumeration: simple hypothesis (only major parameters are specified), see NETGEN_Algorithm.Parameters() More... | |
| int | VeryCoarse = 0 |
| Fineness enumeration: very coarse quality of mesh, see NETGEN_Algorithm.SetFineness() More... | |
| int | Coarse = 1 |
| Fineness enumeration: coarse quality of mesh, see NETGEN_Algorithm.SetFineness() More... | |
| int | Moderate = 2 |
| Fineness enumeration: moderate quality of mesh, see NETGEN_Algorithm.SetFineness() More... | |
| int | Fine = 3 |
| Fineness enumeration: fine quality of mesh, see NETGEN_Algorithm.SetFineness() More... | |
| int | VeryFine = 4 |
| Fineness enumeration: very fine quality of mesh, see NETGEN_Algorithm.SetFineness() More... | |
| int | Custom = 5 |
| Fineness enumeration: custom quality of mesh specified by other parameters), see NETGEN_Algorithm.SetFineness() More... | |
| int noNETGENPlugin = 0 |
| string LIBRARY = "libNETGENEngine.so" |
| string NETGEN_3D = "NETGEN_3D" |
| string NETGEN_3D_Remote = "NETGEN_3D_Remote" |
| string NETGEN_1D2D3D = "NETGEN_2D3D" |
| string NETGEN_1D2D = "NETGEN_2D" |
| string NETGEN_2D = "NETGEN_2D_ONLY" |
| string NETGEN_2D_Remote = "NETGEN_2D_Remote" |
| string NETGEN_FULL = NETGEN_1D2D3D |
| string NETGEN = NETGEN_3D |
| string FULL_NETGEN = NETGEN_FULL |
| int SOLE = 0 |
| int SIMPLE = 1 |
| int VeryCoarse = 0 |
| int Coarse = 1 |
| int Moderate = 2 |
| int Fine = 3 |
| int VeryFine = 4 |
| int Custom = 5 |
