Tetrahedron 1D-2D-3D algorithm. More...
| def | __init__ (self, mesh, geom=0) |
| Private constructor. More... | |
| def | SetSecondOrder (self, theVal) |
Sets SecondOrder flag. More... | |
| def | SetNbSegPerEdge (self, theVal) |
Sets NbSegPerEdge parameter. More... | |
| def | SetNbSegPerRadius (self, theVal) |
Sets NbSegPerRadius parameter. More... | |
| def | SetChordalError (self, theVal) |
Sets ChordalError parameter. More... | |
| def | SetRidgeAngle (self, theVal) |
Sets RidgeAngle parameter. More... | |
| def | SetQuadAllowed (self, toAllow=True) |
Sets QuadAllowed flag. More... | |
| def | SetUseSurfaceCurvature (self, toUse=True) |
Sets UseSurfaceCurvature flag. More... | |
| def | SetFuseEdges (self, toFuse=False) |
Sets FuseEdges flag. More... | |
| def | SetNumberOfSegments (self, theVal) |
| Sets number of segments overriding the value set by SetLocalLength() More... | |
| def | SetLocalLength (self, theVal) |
| Sets number of segments overriding the value set by SetNumberOfSegments() More... | |
| def | MaxElementArea (self, area) |
Defines MaxElementArea parameter of NETGEN_SimpleParameters_3D hypothesis. More... | |
| def | LengthFromEdges (self) |
Defines LengthFromEdges parameter of NETGEN_SimpleParameters_3D hypothesis. More... | |
| def | LengthFromFaces (self) |
Defines LengthFromFaces parameter of NETGEN_SimpleParameters_3D hypothesis. More... | |
| def | MaxElementVolume (self, vol) |
Defines MaxElementVolume parameter of NETGEN_SimpleParameters_3D hypothesis. More... | |
Static Public Attributes | |
| string | meshMethod = "Tetrahedron" |
| name of the dynamic method in smeshBuilder.Mesh class More... | |
| algoType = NETGEN_1D2D3D | |
| type of algorithm used with helper function in smeshBuilder.Mesh class More... | |
| string | docHelper = "Creates tetrahedron 3D algorithm for solids" |
| doc string of the method More... | |
It can be created by calling smeshBuilder.Mesh.Tetrahedron( smeshBuilder.NETGEN_1D2D3D, geom=0 ). This algorithm generates all 1D (edges), 2D (faces) and 3D (volumes) elements for given geometrical shape.
| def __init__ | ( | self, | |
| mesh, | |||
geom = 0 |
| mesh | parent mesh object algorithm is assigned to |
| geom | geometry (shape/sub-shape) algorithm is assigned to; if it is 0 (default), the algorithm is assigned to the main shape |
Reimplemented from NETGEN_Algorithm.
Reimplemented in NETGEN_1D2D_Algorithm, NETGEN_1D2D_Algorithm_2, and NETGEN_1D2D3D_Algorithm_2.
| def SetSecondOrder | ( | self, | |
| theVal | |||
| theVal | new value of the SecondOrder parameter |
References NETGEN_Algorithm.Parameters(), NETGEN_Algorithm.params, and NETGEN_1D2D3D_Algorithm.SetSecondOrder().
| def SetNbSegPerEdge | ( | self, | |
| theVal | |||
| theVal | new value of the NbSegPerEdge parameter |
References NETGEN_Algorithm.Parameters(), NETGEN_Algorithm.params, and NETGEN_1D2D3D_Algorithm.SetNbSegPerEdge().
| def SetNbSegPerRadius | ( | self, | |
| theVal | |||
| theVal | new value of the NbSegPerRadius parameter |
References NETGEN_Algorithm.Parameters(), NETGEN_Algorithm.params, and NETGEN_1D2D3D_Algorithm.SetNbSegPerRadius().
| def SetChordalError | ( | self, | |
| theVal | |||
| theVal | new value of the ChordalError parameter |
References NETGEN_Algorithm.Parameters(), NETGEN_Algorithm.params, and NETGEN_1D2D3D_Algorithm.SetChordalError().
| def SetRidgeAngle | ( | self, | |
| theVal | |||
| theVal | new value of the RidgeAngle parameter |
References NETGEN_Algorithm.Parameters(), NETGEN_Algorithm.params, and NETGEN_1D2D3D_Algorithm.SetRidgeAngle().
| def SetQuadAllowed | ( | self, | |
toAllow = True |
| toAllow | new value of the QuadAllowed parameter (True by default) |
References NETGEN_Algorithm.Parameters(), NETGEN_Algorithm.params, and NETGEN_1D2D3D_Algorithm.SetQuadAllowed().
| def SetUseSurfaceCurvature | ( | self, | |
toUse = True |
| toUse | new value of the UseSurfaceCurvature parameter (True by default) |
References NETGEN_Algorithm.Parameters(), NETGEN_Algorithm.params, and NETGEN_1D2D3D_Algorithm.SetUseSurfaceCurvature().
| def SetFuseEdges | ( | self, | |
toFuse = False |
| toFuse | new value of the FuseEdges parameter (False by default) |
References NETGEN_Algorithm.Parameters(), NETGEN_Algorithm.params, and NETGEN_1D2D3D_Algorithm.SetFuseEdges().
| def SetNumberOfSegments | ( | self, | |
| theVal | |||
| theVal | new value of number of segments parameter |
References NETGEN_Algorithm.Parameters(), and NETGEN_1D2D3D_Algorithm.SetNumberOfSegments().
| def SetLocalLength | ( | self, | |
| theVal | |||
| theVal | new value of local length parameter |
References NETGEN_Algorithm.Parameters(), and NETGEN_1D2D3D_Algorithm.SetLocalLength().
| def MaxElementArea | ( | self, | |
| area | |||
Overrides value set by LengthFromEdges()
| area | new value of MaxElementArea parameter |
References NETGEN_Algorithm.Parameters().
| def LengthFromEdges | ( | self | ) |
Overrides value set by MaxElementArea()
References NETGEN_1D2D3D_Algorithm.LengthFromEdges(), and NETGEN_Algorithm.Parameters().
| def LengthFromFaces | ( | self | ) |
Overrides value set by MaxElementVolume()
References NETGEN_1D2D3D_Algorithm.LengthFromFaces(), and NETGEN_Algorithm.Parameters().
| def MaxElementVolume | ( | self, | |
| vol | |||
Overrides value set by LengthFromFaces()
| vol | new value of MaxElementVolume parameter |
static |
static |
static |
