Tetrahedron 3D algorithm. More...
| def | __init__ (self, mesh, geom=0) |
| Private constructor. More... | |
| def | MaxElementVolume (self, vol, UseExisting=0) |
Defines MaxElementVolume hypothesis to specify the maximum volume value of each tetrahedron. More... | |
Static Public Attributes | |
| string | meshMethod = "Tetrahedron" |
| name of the dynamic method in smeshBuilder.Mesh class More... | |
| algoType = NETGEN | |
| type of algorithm used with helper function in smeshBuilder.Mesh class More... | |
| bool | isDefault = True |
| flag pointing either this algorithm should be used by default in dynamic method of smeshBuilder.Mesh class More... | |
| string | docHelper = "Creates tetrahedron 3D algorithm for solids" |
| doc string of the method More... | |
It can be created by calling smeshBuilder.Mesh.Tetrahedron() or smeshBuilder.Mesh.Tetrahedron( smeshBuilder.NETGEN, geom=0 )
This algorithm generates only 3D (volumes) elements for given geometrical shape and, in contrast to NETGEN_1D2D3D_Algorithm class, should be used in conjunction with other 1D and 2D meshing algorithms.
| def __init__ | ( | self, | |
| mesh, | |||
geom = 0 |
| mesh | parent mesh object algorithm is assigned to |
| geom | geometry (shape/sub-shape) algorithm is assigned to; if it is 0 (default), the algorithm is assigned to the main shape |
Reimplemented from NETGEN_Algorithm.
Reimplemented in NETGEN_3D_Remote_Algorithm.
| def MaxElementVolume | ( | self, | |
| vol, | |||
UseExisting = 0 |
| vol | maximum volume value of each tetrahedron |
| UseExisting | if True - searches for the existing hypothesis created with the same parameters, else (default) - creates a new one |
References Mesh_Algorithm.Hypothesis().
static |
static |
static |
static |
