Home
NETGEN_2D_Remote_Algorithm Class Reference
Tetrahedron 2D algorithm. More...
Inheritance diagram for NETGEN_2D_Remote_Algorithm:
def __init__ (self, mesh, geom=0)
 Private constructor. More...
Static Public Attributes
 algoType = NETGEN_2D_Remote
 type of algorithm used with helper function in smeshBuilder.Mesh class More...
bool isDefault = False
 flag pointing either this algorithm should be used by default in dynamic method of smeshBuilder.Mesh class More...
string docHelper = "Remotely Creates triangles in face of solids"
 doc string of the method More...
It can be created by calling smeshBuilder.Mesh.Triangle() or smeshBuilder.Mesh.Triangle( smeshBuilder.NETGEN, geom=0 )
◆ __init__()
def __init__ (   self,
  mesh,
  geom = 0
meshparent mesh object algorithm is assigned to
geomgeometry (shape/sub-shape) algorithm is assigned to; if it is 0 (default), the algorithm is assigned to the main shape
Reimplemented from NETGEN_2D_Only_Algorithm.
References NETGEN_Algorithm.algoType, NETGEN_1D2D3D_Algorithm.algoType, NETGEN_1D2D_Algorithm.algoType, NETGEN_2D_Only_Algorithm.algoType, NETGEN_3D_Algorithm.algoType, NETGEN_3D_Remote_Algorithm.algoType, NETGEN_2D_Remote_Algorithm.algoType, and NETGEN_1D2D_Algorithm_2.algoType.
◆ algoType
◆ isDefault
◆ docHelper
