Triangle NETGEN 2D algorithm. More...
| def | __init__ (self, mesh, geom=0) |
| Private constructor. More... | |
| def | MaxElementArea (self, area, UseExisting=0) |
Defines MaxElementArea parameter of hypothesis basing on the definition of the maximum area of each triangle. More... | |
| def | LengthFromEdges (self) |
Defines LengthFromEdges hypothesis to build triangles based on the length of the edges taken from the wire. More... | |
| def | SetUseSurfaceCurvature (self, toUse=True) |
Sets UseSurfaceCurvature flag. More... | |
| def | SetQuadAllowed (self, toAllow=True) |
Sets QuadAllowed flag. More... | |
Static Public Attributes | |
| string | meshMethod = "Triangle" |
| name of the dynamic method in smeshBuilder.Mesh class More... | |
| algoType = NETGEN_2D | |
| type of algorithm used with helper function in smeshBuilder.Mesh class More... | |
| bool | isDefault = True |
| flag pointing whether this algorithm should be used by default in dynamic method of smeshBuilder.Mesh class More... | |
| string | docHelper = "Creates triangle 2D algorithm for faces" |
| doc string of the method More... | |
It can be created by calling smeshBuilder.Mesh.Triangle( smeshBuilder.NETGEN_2D, geom=0 )
This algorithm generates only 2D (faces) elements for given geometrical shape and, in contrast to NETGEN_1D2D_Algorithm class, should be used in conjunction with other 1D meshing algorithm.
| def __init__ | ( | self, | |
| mesh, | |||
geom = 0 |
| mesh | parent mesh object algorithm is assigned to |
| geom | geometry (shape/sub-shape) algorithm is assigned to; if it is 0 (default), the algorithm is assigned to the main shape |
Reimplemented from NETGEN_Algorithm.
Reimplemented in NETGEN_2D_Remote_Algorithm.
| def MaxElementArea | ( | self, | |
| area, | |||
UseExisting = 0 |
| area | maximum area value of each triangle |
| UseExisting | if True - searches for an existing hypothesis created with the same parameters, else (default) - creates a new one |
References Mesh_Algorithm.Hypothesis().
| def LengthFromEdges | ( | self | ) |
References Mesh_Algorithm.CompareEqualHyp(), and Mesh_Algorithm.Hypothesis().
| def SetUseSurfaceCurvature | ( | self, | |
toUse = True |
| toUse | new value of the UseSurfaceCurvature parameter (True by default) |
References NETGEN_Algorithm.Parameters(), NETGEN_Algorithm.params, and NETGEN_2D_Only_Algorithm.SetUseSurfaceCurvature().
| def SetQuadAllowed | ( | self, | |
toAllow = True |
| toAllow | new value of the QuadAllowed parameter (True by default) |
References Mesh_Algorithm.CompareEqualHyp(), Mesh_Algorithm.geom, Mesh_Algorithm.Hypothesis(), Mesh_Algorithm.mesh, NETGEN_Algorithm.Parameters(), NETGEN_Algorithm.params, and NETGEN_2D_Only_Algorithm.SetQuadAllowed().
static |
static |
static |
static |
