GEOMImpl_IShapesOperations.cxx File Reference
#include "GEOMImpl_IShapesOperations.hxx"
#include "GEOMImpl_Types.hxx"
#include "GEOMImpl_VectorDriver.hxx"
#include "GEOMImpl_ShapeDriver.hxx"
#include "GEOMImpl_GlueDriver.hxx"
#include "GEOMImpl_FillingDriver.hxx"
#include "GEOMImpl_WrappingDriver.hxx"
#include "GEOMImpl_IExtract.hxx"
#include "GEOMImpl_IVector.hxx"
#include "GEOMImpl_IShapes.hxx"
#include "GEOMImpl_IShapeExtend.hxx"
#include "GEOMImpl_IGlue.hxx"
#include "GEOMImpl_IFilling.hxx"
#include "GEOMImpl_IWrap.hxx"
#include "GEOMImpl_Block6Explorer.hxx"
#include "GEOMImpl_IHealingOperations.hxx"
#include "GEOMImpl_Gen.hxx"
#include "GEOM_Function.hxx"
#include "GEOM_ISubShape.hxx"
#include "GEOM_PythonDump.hxx"
#include "GEOMUtils.hxx"
#include "GEOMUtils_GetInPlace.hxx"
#include "GEOMAlgo_ClsfBox.hxx"
#include "GEOMAlgo_ClsfQuad.hxx"
#include "GEOMAlgo_ClsfSolid.hxx"
#include "GEOMAlgo_ClsfSurf.hxx"
#include "GEOMAlgo_FinderShapeOn2.hxx"
#include "GEOMAlgo_GlueDetector.hxx"
#include <utilities.h>
#include <GEOMAlgo_GetInPlace.hxx>
#include <BRepAdaptor_Curve.hxx>
#include <BRepAdaptor_Surface.hxx>
#include <BRepTools.hxx>
#include <BRep_Builder.hxx>
#include <BRep_Tool.hxx>
#include <GeomLib_Tool.hxx>
#include <Geom_CylindricalSurface.hxx>
#include <Geom_Plane.hxx>
#include <Geom_SphericalSurface.hxx>
#include <Geom_Surface.hxx>
#include <Geom_TrimmedCurve.hxx>
#include <Precision.hxx>
#include <TDF_Tool.hxx>
#include <TDataStd_Integer.hxx>
#include <TDataStd_ListIteratorOfListOfExtendedString.hxx>
#include <TopExp.hxx>
#include <TopTools_DataMapIteratorOfDataMapOfShapeListOfShape.hxx>
#include <TopTools_ListIteratorOfListOfShape.hxx>
#include <TopTools_MapOfOrientedShape.hxx>
#include <TopTools_SequenceOfShape.hxx>
#include <TopoDS.hxx>
#include <TopoDS_TShape.hxx>
#include <TopoDS_Compound.hxx>
#include <TopoDS_Edge.hxx>
#include <TopoDS_Face.hxx>
#include <TopoDS_Iterator.hxx>
#include <TopoDS_Shape.hxx>
#include <TopoDS_Solid.hxx>
#include <TopoDS_Vertex.hxx>
#include <gp_Cylinder.hxx>
#include <gp_Pnt.hxx>
#include <Standard_Failure.hxx>
 Handle (GEOM_Object) GEOMImpl_IShapesOperations
 Handle (TColStd_HSequenceOfTransient) GEOMImpl_IShapesOperations
 Find sub-shapes complying with given status about surface. More...
 Handle (TColStd_HSequenceOfInteger) GEOMImpl_IShapesOperations
 Find IDs of sub-shapes complying with given status about surface. More...
static GEOM::TPythonDump & operator<< (GEOM::TPythonDump &theDump, const GEOMAlgo_State theState)
 Handle (Geom_Surface) GEOMImpl_IShapesOperations
 Creates Geom_Plane. More...
static bool isSameEdge (const TopoDS_Edge &theEdge1, const TopoDS_Edge &theEdge2)
static bool isSameFace (const TopoDS_Face &theFace1, const TopoDS_Face &theFace2)
bool isSameSolid (const TopoDS_Solid &theSolid1, const TopoDS_Solid &theSolid2)
◆ Handle() [1/4]
Handle ( GEOM_Object  )
MakeEdge
MakeEdgeOnCurveByLength
MakeEdgeWire
MakeWire
MakeFace
MakeFaceWires
MakeFaceFromSurface
MakeWrappedFace
MakeFaceWithConstraints
MakeShell
MakeSolidShells
MakeCompound
MakeShape
MakeSolidFromConnectedFaces
MakeGlueFaces
GetGlueFaces
MakeGlueFacesByList
MakeGlueEdges
MakeGlueEdgesByList
GetSubShape
ReverseShape
MakeExtraction
case GetInPlace: default:
case GetInPlaceOld: default:
References GEOM_EDGE, GEOM_IOperations::GetEngine(), GEOM_IOperations::GetSolver(), GEOMImpl_IShapesOperations::Handle(), KO, OK, GEOM_IOperations::SetErrorCode(), GEOMImpl_IVector::SetPoint1(), GEOMImpl_IVector::SetPoint2(), and VECTOR_TWO_PNT.
◆ Handle() [2/4]
Handle ( Geom_Surface  )
Creates Geom_CylindricalSurface.
theAx1- shape object defining plane parameters
Handle(Geom_Surface)- resulting surface
theAx1- edge defining cylinder axis
theRadius- cylinder radius
References GEOM_IOperations::SetErrorCode(), and GEOM::Vertices.
◆ Handle() [3/4]
Handle ( TColStd_HSequenceOfInteger  )
Find IDs of sub-shapes complying with given status about quadrangle.
SubShapeAllIDs
GetSubShapeIndices
GetFreeFacesIDs
theBox- the box to check state of sub-shapes against
theShape- the shape to explore
theShapeType- type of sub-shape of theShape
theState- required state
Handle(TColStd_HSequenceOfInteger)- IDs of found sub-shapes
theCheckShape- the shape to check state of sub-shapes against
theSurface- the surface to check state of sub-shapes against
getSubShapeEdgeSortedIDs
GetShapesOnPlaneIDs
GetShapesOnPlaneWithLocationIDs
GetShapesOnCylinderIDs
GetShapesOnCylinderWithLocationIDs
GetShapesOnSphereIDs
theTopLeftPoint- top left quadrangle corner
theTopRightPoint- top right quadrangle corner
theBottomLeftPoint- bottom left quadrangle corner
theBottomRightPoint- bottom right quadrangle corner
References GEOMImpl_IShapesOperations::EXPLODE_NEW_EXCLUDE_MAIN, GEOMImpl_IShapesOperations::EXPLODE_NEW_INCLUDE_MAIN, GEOMImpl_IShapesOperations::EXPLODE_OLD_INCLUDE_MAIN, GEOMImpl_IShapesOperations::Handle(), GEOMImpl_IShapesOperations::isSorted, KO, NOT_FOUND_ANY, OK, GEOM_IOperations::SetErrorCode(), GEOMUtils::SortShapes(), GEOMImpl_IShapesOperations::theExplodeType, GEOMImpl_IShapesOperations::theShape, GEOMImpl_IShapesOperations::theShapeType, and TopAbs_FLAT.
◆ Handle() [4/4]
Handle ( TColStd_HSequenceOfTransient  )
Find sub-shapes complying with given status about quadrangle.
Find shape objects and their entries by their ids.
GetGlueShapes
GetExistingSubObjects
MakeExplode
MakeSubShapes
Handle(TColStd_HSequenceOfTransient)- found sub-shapes
GetSubShapeEdgeSorted
GetSubShapesWithTolerance
theShapeIDs- incoming shape ids
theShapeEntries- outgoing entries like "entry1, entry2, ..."
Handle(TColStd_HSequenceOfTransient)- found shape objects
GetShapesOnPlane
GetShapesOnCylinder
GetShapesOnSphere
References GEOM_IOperations::GetEngine(), GEOMImpl_IShapesOperations::Handle(), KO, OK, GEOM_IOperations::SetErrorCode(), GEOMUtils::SortShapes(), and GEOMImpl_IShapesOperations::theTolerance.
◆ isSameEdge()
static bool isSameEdge ( const TopoDS_Edge &  theEdge1,
const TopoDS_Edge &  theEdge2
References Handle(), and GEOM::Vertices.
◆ isSameFace()
static bool isSameFace ( const TopoDS_Face &  theFace1,
const TopoDS_Face &  theFace2
References Handle(), and isSameEdge().
◆ isSameSolid()
bool isSameSolid ( const TopoDS_Solid &  theSolid1,
const TopoDS_Solid &  theSolid2
References isSameFace().
◆ operator<<()
static GEOM::TPythonDump & operator<< ( GEOM::TPythonDump &  theDump,
