EntityGUI_PolylineDlg Class Reference
#include <EntityGUI_PolylineDlg.h>
Inheritance diagram for EntityGUI_PolylineDlg:
 EntityGUI_PolylineDlg (GeometryGUI *, QWidget *=0, bool=false, Qt::WindowFlags=0)
virtual ~EntityGUI_PolylineDlg ()
void deleteSelected ()
bool deleteEnabled ()
void setPreviewZLayer (int theLayer)
int getPreviewZLayer () const
 ~GEOMBase_Skeleton ()
virtual ~GEOMBase_Helper ()
Protected Slots
void ClickOnOk ()
bool ClickOnApply ()
void processStartedSubOperation (QWidget *, bool)
void processFinishedSubOperation (QWidget *)
void SetEditCurrentArgument (bool)
void SelectionIntoArgument (bool isForced=false)
void ActivateThisDialog ()
void ActivateLocalCS ()
virtual void ClickOnCancel ()
void LineEditReturnPressed ()
virtual void ClickOnHelp ()
void setPreviewManager (OCCViewer_ViewManager *theManager)
 This method sets/gets the view manager to control the temporary displayed objects on Z layer. More...
OCCViewer_ViewManager * getPreviewManager ()
bool isCheckToSelect ()
 This method defines a state of selection button. More...
int getConstructorId () const
void unsetConstructorId ()
QWidget * centralWidget ()
void activate (const int)
void updateViewer ()
bool openCommand ()
bool abortCommand ()
bool hasCommand () const
bool checkViewWindow ()
void showError ()
bool IsPreview ()
void Init ()
void Clear ()
void enterEvent (QEvent *)
void GetCurveParams (GEOM::ListOfListOfDouble &theCoords, GEOM::string_array &theNames, GEOM::short_array &theTypes, GEOM::ListOfBool &theCloseds)
 This method converts the curve into curve parameters required to construct an object using the interface GEOM_ICurvesOperations::MakePolyline2DOnPlane. More...
gp_Ax3 GetActiveLocalCS ()
 This method returns the current local coordinate system. More...
GEOM::GeomObjPtr GetActiveWPlane ()
 This method returns the current working plane. More...
void AddLocalCS (GEOM::GeomObjPtr theSelectedObject, const bool IsPlane, const gp_Ax3 &theLCS)
 This method add a local coordinate system of the selected object. More...
gp_Ax3 WPlaneToLCS (GEOM::GeomObjPtr theGeomObj)
 This method converts the working plane object into the local coordinate system of the polyline. More...
void displayPreview ()
 This method displays the AIS_InteractiveObject(s) to preview on the Z layer and sets VIOLET color. More...
void erasePreview ()
 This method erases AIS_InteractiveObject(s) from AIS_InteractiveContext and release memory. More...
CurveCreator_Curve * myCurve
CurveCreator_Widget * myEditorWidget
QGroupBox * myAddElementBox
QComboBox * myPlnComboBox
QPushButton * myPlnButton
QPushButton * myPlnSelButton
QPushButton * myPolylineSelButton
QLineEdit * myWPlaneLineEdit
QLineEdit * myPolylineEdit
QList< gp_Ax3 > myLCSList
QList< GEOM::GeomObjPtr > myWPlaneList
OCCViewer_ViewManager * myPreviewManager
int myPreviewZLayer
 Current LineEdit. More...
GeometryGUI * myGeomGUI
 reference GEOM GUI More...
QString myHelpFileName
QButtonGroup * myRBGroup
 radio button group More...
QString myHelpContext
◆ EntityGUI_PolylineDlg()
◆ ~EntityGUI_PolylineDlg()
EntityGUI_PolylineDlg::~EntityGUI_PolylineDlg ( )
◆ ActivateLocalCS
◆ ActivateThisDialog
void EntityGUI_PolylineDlg::ActivateThisDialog ( )
protectedslot
◆ AddLocalCS()
void EntityGUI_PolylineDlg::AddLocalCS ( GEOM::GeomObjPtr  theSelectedObject,
const bool  IsPlane,
const gp_Ax3 &  theLCS
theSelectedObjectthe selected object. It can be a planar face or an imported polyline.
IsPlanetrue for planar face; false for imported polyline.
theLCSthe local coordinate system.
References ActivateLocalCS(), GEOMBase::GetName(), myLCSList, myPlnComboBox, and myWPlaneList.
◆ Clear()
void EntityGUI_PolylineDlg::Clear ( )
◆ ClickOnApply
bool EntityGUI_PolylineDlg::ClickOnApply ( )
protectedslot
◆ ClickOnOk
void EntityGUI_PolylineDlg::ClickOnOk ( )
protectedslot
◆ createOperation()
GEOM::GEOM_IOperations_ptr EntityGUI_PolylineDlg::createOperation ( )
References GEOMBase_Helper::getGeomEngine().
◆ deleteEnabled()
bool EntityGUI_PolylineDlg::deleteEnabled ( )
◆ deleteSelected()
void EntityGUI_PolylineDlg::deleteSelected ( )
◆ displayPreview()
void EntityGUI_PolylineDlg::displayPreview ( )
◆ enterEvent()
void EntityGUI_PolylineDlg::enterEvent ( QEvent *  )
◆ erasePreview()
void EntityGUI_PolylineDlg::erasePreview ( )
◆ execute()
bool EntityGUI_PolylineDlg::execute ( ObjectList &  objects)
◆ GetActiveLocalCS()
gp_Ax3 EntityGUI_PolylineDlg::GetActiveLocalCS ( )
References GeometryGUI::GetWorkingPlane(), GEOMBase_Skeleton::myGeomGUI, myLCSList, and myPlnComboBox.
◆ GetActiveWPlane()
GEOM::GeomObjPtr EntityGUI_PolylineDlg::GetActiveWPlane ( )
Can be null.
References myPlnComboBox, and myWPlaneList.
◆ GetCurveParams()
void EntityGUI_PolylineDlg::GetCurveParams ( GEOM::ListOfListOfDouble &  theCoords,
GEOM::string_array &  theNames,
GEOM::short_array &  theTypes,
GEOM::ListOfBool &  theCloseds
theCurvea curve object, that contains data.
theCoordsListthe list of coordinates list. theCoordsList[0] is the coordinates list of the first section. theCoordsList[1] is for the second section etc. Output parameter.
theNamesListthe list of names. The order corresponds to theCoordsList. Output parameter.
theTypesListthe list of curve types. The order corresponds to theCoordsList. Output parameter.
theClosedListthe list of Closed flags. The order corresponds to theCoordsList. Output parameter.
References CurveCreator_Curve::getCoords(), CurveCreator_Curve::getNbSections(), CurveCreator_Curve::getSectionName(), CurveCreator_Curve::getSectionType(), GEOM::Interpolation, CurveCreator_Curve::isClosed(), myCurve, GEOM::Polyline, CurveCreator::Polyline, and CurveCreator::Spline.
◆ getPreviewManager()
OCCViewer_ViewManager * EntityGUI_PolylineDlg::getPreviewManager ( )
References myPreviewManager.
◆ getPreviewZLayer()
int EntityGUI_PolylineDlg::getPreviewZLayer ( ) const
References myPreviewZLayer.
◆ getSourceObjects()
QList< GEOM::GeomObjPtr > EntityGUI_PolylineDlg::getSourceObjects ( )
References myWPlaneList.
◆ Init()
◆ isCheckToSelect()
bool EntityGUI_PolylineDlg::isCheckToSelect ( )
true if selection button is checked, otherwise false.
References myPlnSelButton, and myPolylineSelButton.
◆ isValid()
bool EntityGUI_PolylineDlg::isValid ( QString &  )
◆ processFinishedSubOperation
void EntityGUI_PolylineDlg::processFinishedSubOperation ( QWidget *  theWidget)
protectedslot
References myAddElementBox, and myEditorWidget.
◆ processStartedSubOperation
void EntityGUI_PolylineDlg::processStartedSubOperation ( QWidget *  theWidget,
bool  theIsEdit
protectedslot
◆ SelectionIntoArgument
◆ SetEditCurrentArgument
void EntityGUI_PolylineDlg::SetEditCurrentArgument ( bool  )
protectedslot
◆ setPreviewManager()
void EntityGUI_PolylineDlg::setPreviewManager ( OCCViewer_ViewManager *  theManager)
theManagerthe view manager.
References getPreviewManager(), Handle(), myPreviewManager, and setPreviewZLayer().
◆ setPreviewZLayer()
void EntityGUI_PolylineDlg::setPreviewZLayer ( int  theLayer)
◆ WPlaneToLCS()
gp_Ax3 EntityGUI_PolylineDlg::WPlaneToLCS ( GEOM::GeomObjPtr  theGeomObj)
theGeomObjthe working plane
References GEOM_Client::get_client(), GeometryGUI::GetGeomGen(), GEOM_Client::GetShape(), and GEOMBase_Skeleton::myGeomGUI.
◆ myAddElementBox
QGroupBox* EntityGUI_PolylineDlg::myAddElementBox
◆ myCurve
CurveCreator_Curve* EntityGUI_PolylineDlg::myCurve
◆ myEditCurrentArgument
QLineEdit* EntityGUI_PolylineDlg::myEditCurrentArgument
◆ myEditorWidget
CurveCreator_Widget* EntityGUI_PolylineDlg::myEditorWidget
◆ myLCSList
QList<gp_Ax3> EntityGUI_PolylineDlg::myLCSList
◆ myPlnButton
QPushButton* EntityGUI_PolylineDlg::myPlnButton
◆ myPlnComboBox
QComboBox* EntityGUI_PolylineDlg::myPlnComboBox
◆ myPlnSelButton
QPushButton* EntityGUI_PolylineDlg::myPlnSelButton
◆ myPolylineEdit
QLineEdit* EntityGUI_PolylineDlg::myPolylineEdit
◆ myPolylineSelButton
QPushButton* EntityGUI_PolylineDlg::myPolylineSelButton
◆ myPreviewManager
OCCViewer_ViewManager* EntityGUI_PolylineDlg::myPreviewManager
◆ myPreviewZLayer
int EntityGUI_PolylineDlg::myPreviewZLayer
◆ myWPlaneLineEdit
QLineEdit* EntityGUI_PolylineDlg::myWPlaneLineEdit
◆ myWPlaneList
QList<GEOM::GeomObjPtr> EntityGUI_PolylineDlg::myWPlaneList
