CurveCreator_Widget Class Reference
#include <CurveCreator_Widget.h>
Inheritance diagram for CurveCreator_Widget:
enum  ActionFlags {
  NoFlags = 0x00000000 , DisableDetectionMode = 0x00000001 , DisableNewSection = 0x00000002 , DisableClosedSection = 0x00000004 ,
  DisableSetColor = 0x00000008
enum  ActionMode { NoneMode , AdditionMode , ModificationMode , DetectionMode }
Public Slots
void onAdditionMode (bool checked)
void onModificationMode (bool checked)
void onDetectionMode (bool checked)
void onModeChanged (bool checked)
void onNewSection ()
void onSelectionChanged ()
void onAddNewSection ()
void onEditSection (int theSection)
void onModifySection ()
void onCancelSection ()
void onJoin ()
void onBringTogether ()
 Set the same coordinates on two section extremities. More...
void onRemove ()
void onSetColor ()
void onClearAll ()
void onJoinAll ()
void onSetSpline ()
void onSetPolyline ()
void onCloseSections ()
void onUncloseSections ()
void onUndo ()
void onRedo ()
void onUndoSettings ()
void onContextMenu (QPoint thePoint)
void onMousePress (SUIT_ViewWindow *, QMouseEvent *theEvent)
 Manage mouse press events. More...
void onMouseRelease (SUIT_ViewWindow *, QMouseEvent *theEvent)
 Manage mouse release events in Modification mode. More...
void onMouseMove (SUIT_ViewWindow *, QMouseEvent *theEvent)
 Manage mouse move events in Modification mode. More...
void onLastViewClosed (SUIT_ViewManager *theManager)
 Set zero viewer by the last view closed in. More...
void onMousePress (QMouseEvent *theEvent)
void onMouseRelease (QMouseEvent *theEvent)
void onMouseMove (QMouseEvent *theEvent)
void onCellChanged (int theRow, int theColumn)
Signals
void selectionChanged ()
void subOperationStarted (QWidget *, bool)
void subOperationFinished (QWidget *)
 CurveCreator_Widget (QWidget *parent, CurveCreator_ICurve *theCurve, const int theActionFlags=NoFlags, const QStringList &theCoordTitles=QStringList(), Qt::WindowFlags fl=0)
void setOCCViewer (OCCViewer_Viewer *theViewer)
 Set an OCC viewer. More...
 Handle (AIS_InteractiveContext) getAISContext()
OCCViewer_ViewPort3d * getViewPort ()
 Returns OCC viewer view port. More...
int changeInteractionStyle (int theStyle)
 Set interaction style in the OCC viewer. More...
void reset ()
void setCurve (CurveCreator_ICurve *theCurve)
QList< int > getSelectedSections ()
void setSelectedSections (const QList< int > &theSections)
void removeSelected ()
 According to the widget state, performs the remove action. More...
bool removeEnabled ()
 Checks whether there are some selection to be removed. More...
void setActionMode (const ActionMode &theMode)
ActionMode getActionMode () const
void SetViewer2DMode (const bool To2D)
void setSelectedPoints (const CurveCreator_ICurve::SectionToPointList &=CurveCreator_ICurve::SectionToPointList())
void updateLocalPointView ()
void setLocalPointContext (const bool theOpen, const bool isUpdateTable=false)
QAction * getAction (ActionId theId)
QAction * getAction (ActionMode theMode)
Protected Types
enum  ActionId {
  NONE_ID , UNDO_ID , REDO_ID , NEW_SECTION_ID ,
  ADDITION_MODE_ID , REMOVE_ID , REMOVE_ALL_ID , JOIN_ID ,
  JOIN_ALL_ID , CLOSE_SECTIONS_ID , UNCLOSE_SECTIONS_ID , SET_SECTIONS_POLYLINE_ID ,
  SET_SECTIONS_SPLINE_ID , CLEAR_ALL_ID , SEPARATOR_ID , MODIFICATION_MODE_ID ,
  DETECTION_MODE_ID , BRING_TOGETHER_ID , SETCOLOR_ID
void addCoordsByClick (QMouseEvent *)
QPoint myStartPoint
QPoint myEndPoint
OCCViewer_Viewer * getOCCViewer ()
 Returns current OCC viewer. More...
QAction * createAction (ActionId theId, const QString &theName, const QPixmap &theImage, const QString &theToolTip, const QKeySequence &theShortcut)
void updateActionsStates ()
void updateUndoRedo ()
void removeSection ()
 Removes a selected section from the curve. More...
void removePoint ()
 Removes a selected points from the curve. More...
void addNewPoint (const CurveCreator::Coordinates &theCoords)
void insertPointToSelectedSegment (const int theXPosition, const int theYPosition)
void moveSelectedPoints (const int theXPosition, const int theYPosition)
void setDragStarted (const bool theState, const QPoint &thePoint=QPoint())
 Set drag operation started. More...
void getSelectedPoints (CurveCreator_ICurve::SectionToPointList &thePoints)
void stopActionMode ()
void startCurveModification (CurveCreator_ICurve::SectionToPointList &thePoints, const bool theFillPoints=true)
 Get viewer information before perform the curve modification. More...
void finishCurveModification (const CurveCreator_ICurve::SectionToPointList &thePoints=CurveCreator_ICurve::SectionToPointList())
 Restore the viewer state after the curve modification is done. More...
int findLocalPointIndex (int theSectionId, double theX, double theY)
 Returns a point index in the model curve by the point coordinates in the viewer. More...
void findSectionsToPoints (const double theX, const double theY, CurveCreator_ICurve::SectionToPointList &thePoints)
void convert (const CurveCreator_ICurve::SectionToPointList &thePoints, QMap< int, QList< int > > &theConvPoints)
bool contains (const CurveCreator_ICurve::SectionToPointList &theList, const CurveCreator_ICurve::SectionToPoint &theValue) const
 Returns whether the container has the value. More...
QMap< ActionId, QAction * > myActionMap
CurveCreator_ICurve * myCurve
CurveCreator_TreeView * mySectionView
CurveCreator_TableView * myLocalPointView
CurveCreator_ICurve::SectionToPointList myLocalPoints
CurveCreator_NewSectionDlg * myNewSectionEditor
OCCViewer_Viewer * myOCCViewer
int myLocalPointRowLimit
int mySection
int myPointNum
bool myDragStarted
QPoint myDragStartPosition
int myDragInteractionStyle
CurveCreator_ICurve::SectionToPointList myDragPoints
QMap< CurveCreator_ICurve::SectionToPoint, CurveCreator::Coordinates > myInitialDragPointsCoords
bool myDragged
QByteArray myGuiState
OCCViewer_ViewWindow::Mode2dType myOld2DMode
◆ ActionFlags
NoFlags
DisableNewSection
DisableSetColor
◆ ActionId
NONE_ID
UNDO_ID
REDO_ID
NEW_SECTION_ID
ADDITION_MODE_ID
REMOVE_ID
REMOVE_ALL_ID
JOIN_ID
JOIN_ALL_ID
CLOSE_SECTIONS_ID
UNCLOSE_SECTIONS_ID
CLEAR_ALL_ID
SEPARATOR_ID
DETECTION_MODE_ID
BRING_TOGETHER_ID
SETCOLOR_ID
◆ ActionMode
NoneMode
AdditionMode
ModificationMode
DetectionMode
◆ CurveCreator_Widget()
◆ addCoordsByClick()
void CurveCreator_Widget::addCoordsByClick ( QMouseEvent *  pe)
◆ addNewPoint()
◆ changeInteractionStyle()
int CurveCreator_Widget::changeInteractionStyle ( int  theStyle)
theStylea new style
the previous style
References getOCCViewer().
◆ contains()
bool CurveCreator_Widget::contains ( const CurveCreator_ICurve::SectionToPointList &  theList,
const CurveCreator_ICurve::SectionToPoint &  theValue
theLista container of values
theValuea value
References CurveCreator_UtilsICurve::contains().
◆ convert()
void CurveCreator_Widget::convert ( const CurveCreator_ICurve::SectionToPointList &  thePoints,
QMap< int, QList< int > > &  theConvPoints
◆ createAction()
QAction * CurveCreator_Widget::createAction ( ActionId  theId,
const QString &  theName,
const QPixmap &  theImage,
const QString &  theToolTip,
const QKeySequence &  theShortcut
References myActionMap.
◆ findLocalPointIndex()
int CurveCreator_Widget::findLocalPointIndex ( int  theSectionId,
double  theX,
double  theY
theXthe X coordinate of the point
theYthe Y coordinate of the point
References CurveCreator_UtilsICurve::findLocalPointIndex(), and myCurve.
◆ findSectionsToPoints()
void CurveCreator_Widget::findSectionsToPoints ( const double  theX,
const double  theY,
◆ finishCurveModification()
void CurveCreator_Widget::finishCurveModification ( const CurveCreator_ICurve::SectionToPointList &  thePoints = CurveCreator_ICurve::SectionToPointList())
Open local context and select given points inside it.
thePointsa list of curve selected points
References getActionMode(), ModificationMode, setLocalPointContext(), setSelectedPoints(), and updateUndoRedo().
◆ getAction() [1/2]
QAction * CurveCreator_Widget::getAction ( ActionId  theId)
◆ getAction() [2/2]
QAction * CurveCreator_Widget::getAction ( ActionMode  theMode)
◆ getActionMode()
◆ getOCCViewer()
OCCViewer_Viewer * CurveCreator_Widget::getOCCViewer ( )
References myOCCViewer.
◆ getSelectedPoints()
void CurveCreator_Widget::getSelectedPoints ( CurveCreator_ICurve::SectionToPointList &  thePoints)
References myLocalPoints.
◆ getSelectedSections()
QList< int > CurveCreator_Widget::getSelectedSections ( )
◆ getViewPort()
OCCViewer_ViewPort3d * CurveCreator_Widget::getViewPort ( )
References getOCCViewer(), and getViewPort().
◆ Handle()
CurveCreator_Widget::Handle ( AIS_InteractiveContext  )
◆ insertPointToSelectedSegment()
◆ moveSelectedPoints()
◆ onAdditionMode
void CurveCreator_Widget::onAdditionMode ( bool  checked)
slot
◆ onAddNewSection
◆ onBringTogether
void CurveCreator_Widget::onBringTogether ( )
slot
Usage: build a closed contour with several sections. Works with two points selected, at the extremities of different sections. The second point gets the coordinates of the first.
References finishCurveModification(), getActionMode(), CurveCreator_ICurve::getNbPoints(), CurveCreator_UtilsICurve::getPoint(), ModificationMode, myCurve, myLocalPoints, CurveCreator_ICurve::setPoint(), and startCurveModification().
◆ onCancelSection
void CurveCreator_Widget::onCancelSection ( )
slot
◆ onCellChanged
◆ onClearAll
◆ onCloseSections
◆ onContextMenu
void CurveCreator_Widget::onContextMenu ( QPoint  thePoint)
slot
◆ onDetectionMode
void CurveCreator_Widget::onDetectionMode ( bool  checked)
slot
◆ onEditSection
◆ onJoin
◆ onJoinAll
◆ onLastViewClosed
void CurveCreator_Widget::onLastViewClosed ( SUIT_ViewManager *  theManager)
slot
theManagera viewer manager
◆ onModeChanged
◆ onModificationMode
void CurveCreator_Widget::onModificationMode ( bool  checked)
slot
References myLocalPointView.
◆ onModifySection
◆ onMouseMove [1/2]
void CurveCreator_Widget::onMouseMove ( QMouseEvent *  theEvent)
slot
References onMouseMove().
◆ onMouseMove [2/2]
void CurveCreator_Widget::onMouseMove ( SUIT_ViewWindow *  ,
slot
theWindowan owner of the signal
theEventa mouse event
References END_MEASURE_TIME, getActionMode(), ModificationMode, moveSelectedPoints(), myDragStarted, myDragStartPosition, and START_MEASURE_TIME.
◆ onMousePress [1/2]
void CurveCreator_Widget::onMousePress ( QMouseEvent *  theEvent)
slot
References onMousePress().
◆ onMousePress [2/2]
void CurveCreator_Widget::onMousePress ( SUIT_ViewWindow *  ,
slot
References addCoordsByClick(), AdditionMode, getActionMode(), ModificationMode, myStartPoint, and setDragStarted().
◆ onMouseRelease [1/2]
void CurveCreator_Widget::onMouseRelease ( QMouseEvent *  theEvent)
slot
References onMouseRelease().
◆ onMouseRelease [2/2]
◆ onNewSection
◆ onRedo
◆ onRemove
void CurveCreator_Widget::onRemove ( )
slot
◆ onSelectionChanged
◆ onSetColor
◆ onSetPolyline
◆ onSetSpline
◆ onUncloseSections
◆ onUndo
◆ onUndoSettings
void CurveCreator_Widget::onUndoSettings ( )
slot
◆ removeEnabled()
◆ removePoint()
◆ removeSection()
◆ removeSelected()
void CurveCreator_Widget::removeSelected ( )
References onRemove().
◆ reset()
void CurveCreator_Widget::reset ( )
References stopActionMode().
◆ selectionChanged
void CurveCreator_Widget::selectionChanged ( )
signal
◆ setActionMode()
void CurveCreator_Widget::setActionMode ( const ActionMode &  theMode)
◆ setCurve()
◆ setDragStarted()
void CurveCreator_Widget::setDragStarted ( const bool  theState,
const QPoint &  thePoint = QPoint()
Save the position and a list of dragged points
theStatethe drag operation state: started/finished
thePointthe start drag position
References changeInteractionStyle(), getSelectedPoints(), myCurve, myDragged, myDragInteractionStyle, myDragPoints, myDragStarted, myDragStartPosition, myInitialDragPointsCoords, and CurveCreator_ICurve::setSkipSorting().
◆ setLocalPointContext()
void CurveCreator_Widget::setLocalPointContext ( const bool  theOpen,
const bool  isUpdateTable = false
◆ setOCCViewer()
void CurveCreator_Widget::setOCCViewer ( OCCViewer_Viewer *  theViewer)
◆ setSelectedPoints()
◆ setSelectedSections()
void CurveCreator_Widget::setSelectedSections ( const QList< int > &  theSections)
◆ SetViewer2DMode()
void CurveCreator_Widget::SetViewer2DMode ( const bool  To2D)
References myOCCViewer, and myOld2DMode.
◆ startCurveModification()
void CurveCreator_Widget::startCurveModification ( CurveCreator_ICurve::SectionToPointList &  thePoints,
const bool  theFillPoints = true
Take a list of selected cuve points an close local context. The context should be closed because the curve presentation is redisplayed and if it is not closed, when we close the local context later, the presentation shown in the local context is disappeared.
thePointsan output list of curve selected points
theFillPointsa flag whether the selection list should be filled
References getSelectedPoints(), and setLocalPointContext().
◆ stopActionMode()
void CurveCreator_Widget::stopActionMode ( )
References NoneMode, and setActionMode().
◆ subOperationFinished
void CurveCreator_Widget::subOperationFinished ( QWidget *  )
signal
◆ subOperationStarted
void CurveCreator_Widget::subOperationStarted ( QWidget *  ,
bool
signal
◆ updateActionsStates()
◆ updateLocalPointView()
◆ updateUndoRedo()
void CurveCreator_Widget::updateUndoRedo ( )
◆ myActionMap
QMap<ActionId, QAction*> CurveCreator_Widget::myActionMap
◆ myCurve
CurveCreator_ICurve* CurveCreator_Widget::myCurve
◆ myDragged
bool CurveCreator_Widget::myDragged
◆ myDragInteractionStyle
int CurveCreator_Widget::myDragInteractionStyle
◆ myDragPoints
CurveCreator_ICurve::SectionToPointList CurveCreator_Widget::myDragPoints
◆ myDragStarted
bool CurveCreator_Widget::myDragStarted
◆ myDragStartPosition
QPoint CurveCreator_Widget::myDragStartPosition
◆ myEndPoint
QPoint CurveCreator_Widget::myEndPoint
◆ myGuiState
QByteArray CurveCreator_Widget::myGuiState
◆ myInitialDragPointsCoords
QMap<CurveCreator_ICurve::SectionToPoint, CurveCreator::Coordinates> CurveCreator_Widget::myInitialDragPointsCoords
◆ myLocalPointRowLimit
int CurveCreator_Widget::myLocalPointRowLimit
◆ myLocalPoints
CurveCreator_ICurve::SectionToPointList CurveCreator_Widget::myLocalPoints
◆ myLocalPointView
CurveCreator_TableView* CurveCreator_Widget::myLocalPointView
◆ myNewSectionEditor
CurveCreator_NewSectionDlg* CurveCreator_Widget::myNewSectionEditor
◆ myOCCViewer
OCCViewer_Viewer* CurveCreator_Widget::myOCCViewer
◆ myOld2DMode
OCCViewer_ViewWindow::Mode2dType CurveCreator_Widget::myOld2DMode
◆ myPointNum
int CurveCreator_Widget::myPointNum
◆ mySection
int CurveCreator_Widget::mySection
◆ mySectionView
CurveCreator_TreeView* CurveCreator_Widget::mySectionView
◆ myStartPoint
QPoint CurveCreator_Widget::myStartPoint
