GEOMGUI_DimensionProperty Class Reference
Utility class to unpack/pack dimension presentations as object property of study. More...
#include <GEOMGUI_DimensionProperty.h>
struct  Angle
 Declaration of properties for angle dimensions. More...
struct  Diameter
 Declaration of properties for diameter dimensions. More...
struct  Length
 Declaration of properties for length dimensions. More...
struct  Record
enum  DimensionType { DimensionType_Length , DimensionType_Diameter , DimensionType_Angle }
 Type of packed presentation. More...
typedef QSharedPointer< Record > RecordPtr
 GEOMGUI_DimensionProperty ()
 Constructor. Inits empty property. More...
 GEOMGUI_DimensionProperty (const GEOMGUI_DimensionProperty &theOther)
 Copy constructor. More...
 GEOMGUI_DimensionProperty (const std::string &theEntry)
 Constructor. Inits property from attribute. More...
 GEOMGUI_DimensionProperty (const QString &theProperty)
 Constructor. Inits property from formatted QString. More...
 ~GEOMGUI_DimensionProperty ()
 operator QVariant () const
 Overload QVariant cast operator. More...
 operator QString () const
 Overload QString cast operator. More...
bool operator== (const GEOMGUI_DimensionProperty &theOther) const
 Overload comparison. More...
bool operator!= (const GEOMGUI_DimensionProperty &theOther) const
int GetNumber () const
 Returns number of dimension records. More...
void AddRecord (const Handle(AIS_Dimension)&theIO, const gp_Ax3 &theLCS)
 Adds new record for the passed interactive object. Convenience method. More...
void AddRecord (const RecordPtr &theRecord)
 Adds new dimension record. More...
void SetRecord (const int theIndex, const Handle(AIS_Dimension)&theIO, const gp_Ax3 &theLCS)
 Update dimension record data. More...
void SetRecord (const int theIndex, const RecordPtr &theRecord)
const RecordPtr & GetRecord (const int theIndex) const
 Access record by index. More...
void RemoveRecord (const int theIndex)
 Removes record by its index. More...
void Clear ()
 Clears property data. More...
bool IsVisible (const int theIndex) const
 Returns visibility state of dimension record by its index. More...
void SetVisible (const int theIndex, const bool theIsVisible)
 Changes visibility state of the dimension record. More...
QString GetName (const int theIndex) const
 Returns name of dimension record by its index. More...
void SetName (const int theIndex, const QString &theName)
 Changes name of dimension record. More...
int GetType (const int theIndex) const
 Returns dimension type. More...
void LoadFromAttribute (const std::string &theEntry)
 Loads properties data from attribute "AttributeTableOfReal". More...
void SaveToAttribute (const std::string &theEntry)
 Saves properties data to attribute "AttributeTableOfReal". More...
Private Types
typedef QVector< bool > VectorOfVisibility
typedef QVector< QString > VectorOfNames
typedef QVector< RecordPtr > VectorOfRecords
int TypeFromIO (const Handle(AIS_Dimension)&theIO) const
 Determines dimension type code. More...
VectorOfVisibility myVisibility
VectorOfNames myNames
VectorOfRecords myRecords
Dimension presentations are store in relative coordinate system (LCS). To ensure that dimension is bound to the equal shape irrespectively of its location transformation.
The record is a list of qvariant, containing packed dimension properties and its attributes: (name);(is_visible);(dimension type);(dimension property list);
The following packing scheme is used to store dimension data: Length: (plane)[0-3] (flyout)[4] (text flags)[5-6] (arrow flag)[7] (p1)[8-10] (pnt2)[11-13] Diam: (plane)[0-3] (flyout)[4] (text flags)[5-6] (arrow flag)[7] (circle loc, xdir, ydir, rad)[8-17] Angle: (flyout)[0] (text flags)[1-2] (arrow flag)[3] (p1)[4-6] (p2)[7-9] (center)[10-12]
◆ RecordPtr
◆ VectorOfNames
typedef QVector<QString> GEOMGUI_DimensionProperty::VectorOfNames
◆ VectorOfRecords
◆ VectorOfVisibility
typedef QVector<bool> GEOMGUI_DimensionProperty::VectorOfVisibility
◆ DimensionType
DimensionType_Angle
◆ GEOMGUI_DimensionProperty() [1/4]
GEOMGUI_DimensionProperty::GEOMGUI_DimensionProperty ( )
◆ GEOMGUI_DimensionProperty() [2/4]
GEOMGUI_DimensionProperty::GEOMGUI_DimensionProperty ( const GEOMGUI_DimensionProperty &  theOther)
◆ GEOMGUI_DimensionProperty() [3/4]
GEOMGUI_DimensionProperty::GEOMGUI_DimensionProperty ( const std::string &  theEntry)
References LoadFromAttribute().
◆ GEOMGUI_DimensionProperty() [4/4]
GEOMGUI_DimensionProperty::GEOMGUI_DimensionProperty ( const QString &  theProperty)
◆ ~GEOMGUI_DimensionProperty()
GEOMGUI_DimensionProperty::~GEOMGUI_DimensionProperty ( )
◆ AddRecord() [1/2]
void GEOMGUI_DimensionProperty::AddRecord ( const Handle(AIS_Dimension)&  theIO,
const gp_Ax3 &  theLCS
theIO[in] the interactive dimension to append as new record.
theLCS[in] the local coordinate system of parent object.
References DimensionType_Angle, DimensionType_Diameter, DimensionType_Length, Handle(), myNames, myRecords, myVisibility, and TypeFromIO().
◆ AddRecord() [2/2]
void GEOMGUI_DimensionProperty::AddRecord ( const RecordPtr &  theRecord)
theRecord[in] the record to add.
References myNames, myRecords, and myVisibility.
◆ Clear()
void GEOMGUI_DimensionProperty::Clear ( )
◆ GetName()
QString GEOMGUI_DimensionProperty::GetName ( const int  theIndex) const
theIndex[in] the index of the dimension record.
References myNames.
◆ GetNumber()
int GEOMGUI_DimensionProperty::GetNumber ( ) const
References myRecords.
◆ GetRecord()
const GEOMGUI_DimensionProperty::RecordPtr & GEOMGUI_DimensionProperty::GetRecord ( const int  theIndex) const
◆ GetType()
int GEOMGUI_DimensionProperty::GetType ( const int  theIndex) const
◆ IsVisible()
bool GEOMGUI_DimensionProperty::IsVisible ( const int  theIndex) const
References myVisibility.
◆ LoadFromAttribute()
void GEOMGUI_DimensionProperty::LoadFromAttribute ( const std::string &  theEntry)
theEntry[in] the entry of GEOM object to operate with.
References Clear(), DimensionType_Angle, DimensionType_Diameter, DimensionType_Length, myNames, myRecords, and myVisibility.
◆ operator QString()
GEOMGUI_DimensionProperty::operator QString ( ) const
◆ operator QVariant()
GEOMGUI_DimensionProperty::operator QVariant ( ) const
◆ operator!=()
bool GEOMGUI_DimensionProperty::operator!= ( const GEOMGUI_DimensionProperty &  theOther) const
◆ operator==()
bool GEOMGUI_DimensionProperty::operator== ( const GEOMGUI_DimensionProperty &  theOther) const
◆ RemoveRecord()
void GEOMGUI_DimensionProperty::RemoveRecord ( const int  theIndex)
theIndex[in] the index of dimension record.
◆ SaveToAttribute()
void GEOMGUI_DimensionProperty::SaveToAttribute ( const std::string &  theEntry)
◆ SetName()
void GEOMGUI_DimensionProperty::SetName ( const int  theIndex,
const QString &  theName
theName[in] the new name.
References myNames.
◆ SetRecord() [1/2]
void GEOMGUI_DimensionProperty::SetRecord ( const int  theIndex,
theIndex[in] the index of the record.
theIO[in] the interactive dimension to update properties.
References DimensionType_Angle, DimensionType_Diameter, DimensionType_Length, Handle(), myRecords, and TypeFromIO().
◆ SetRecord() [2/2]
theRecord[in] the record to replace with.
◆ SetVisible()
void GEOMGUI_DimensionProperty::SetVisible ( const int  theIndex,
theIsVisible[in] the new visibility state.
◆ TypeFromIO()
int GEOMGUI_DimensionProperty::TypeFromIO ( const Handle(AIS_Dimension)&  theIO) const
◆ myNames
VectorOfNames GEOMGUI_DimensionProperty::myNames
◆ myRecords
VectorOfRecords GEOMGUI_DimensionProperty::myRecords
◆ myVisibility
VectorOfVisibility GEOMGUI_DimensionProperty::myVisibility
