GEOMImpl_ITransformOperations Class Reference
#include <GEOMImpl_ITransformOperations.hxx>
Inheritance diagram for GEOMImpl_ITransformOperations:
Standard_EXPORT GEOMImpl_ITransformOperations (GEOM_Engine *theEngine)
Standard_EXPORT ~GEOMImpl_ITransformOperations ()
Standard_EXPORT Handle (GEOM_Object) TranslateTwoPoints(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) thePoint1
Standard_EXPORT Handle (GEOM_Object) thePoint2)
Standard_EXPORT Handle (GEOM_Object) TranslateTwoPointsCopy(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) TranslateDXDYDZ(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) TranslateDXDYDZCopy(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) TranslateVector(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) theVector)
Standard_EXPORT Handle (GEOM_Object) TranslateVectorCopy(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) TranslateVectorDistance(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) Translate1D(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) Translate2D(Handle(GEOM_Object) theObject
Standard_EXPORT double Standard_Integer Handle (GEOM_Object) theVector2
Standard_EXPORT Handle (GEOM_Object) MirrorPlane(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) thePlane)
Standard_EXPORT Handle (GEOM_Object) MirrorPlaneCopy(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) MirrorAxis(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) theAxis)
Standard_EXPORT Handle (GEOM_Object) MirrorAxisCopy(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) MirrorPoint(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) thePoint)
Standard_EXPORT Handle (GEOM_Object) MirrorPointCopy(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) OffsetShape(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) OffsetShapeCopy(Handle(GEOM_Object) theObject
Standard_EXPORT double bool const Handle (TColStd_HArray1OfInteger) &theFacesIDs
Standard_EXPORT Handle (GEOM_Object) ProjectShapeCopy(Handle(GEOM_Object) theSource
Standard_EXPORT Handle (GEOM_Object) theTarget)
Standard_EXPORT Standard_Real ProjectPointOnWire (Handle(GEOM_Object) thePoint, Handle(GEOM_Object) theWire, Handle(GEOM_Object) &thePointOnEdge, Standard_Integer &theEdgeInWireIndex)
Standard_EXPORT Handle (GEOM_Object) ScaleShape(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) ScaleShapeCopy(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) ScaleShapeAlongAxes(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) PositionShape(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) theStartLCS
Standard_EXPORT Handle (GEOM_Object) theEndLCS)
Standard_EXPORT Handle (GEOM_Object) PositionShapeCopy(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) PositionAlongPath(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) thePath
Standard_EXPORT Handle (GEOM_Object) Rotate(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) RotateCopy(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) Rotate1D(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) Rotate2D(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) RotateThreePoints(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) theCentPoint
Standard_EXPORT Handle (GEOM_Object) RotateThreePointsCopy(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) TransformLikeOtherCopy(Handle(GEOM_Object) theObject
Standard_EXPORT Handle (GEOM_Object) theSample)
Standard_EXPORT Handle (GEOM_Object) MakeProjectionOnCylinder(const Handle(GEOM_Object) &theObject
- Public Member Functions inherited from GEOM_IOperations
Standard_EXPORT GEOM_IOperations (GEOM_Engine *theEngine)
Standard_EXPORT ~GEOM_IOperations ()
Standard_EXPORT void StartOperation ()
Standard_EXPORT void FinishOperation ()
Standard_EXPORT void AbortOperation ()
Standard_EXPORT bool IsDone ()
Standard_EXPORT void SetNotDone ()
Standard_EXPORT void SetErrorCode (const TCollection_AsciiString &theErrorCode)
Standard_EXPORT char * GetErrorCode ()
Standard_EXPORT GEOM_Engine * GetEngine ()
Standard_EXPORT GEOM_Solver * GetSolver ()
Public Attributes
Standard_EXPORT double theX
Standard_EXPORT double double theY
Standard_EXPORT double double double theZ
Standard_EXPORT double theDistance
Standard_EXPORT double bool theCopy
Standard_EXPORT double theStep
Standard_EXPORT double Standard_Integer theNbTimes
Standard_EXPORT double theStep1
Standard_EXPORT double Standard_Integer theNbTimes1
Standard_EXPORT double Standard_Integer double theStep2
Standard_EXPORT double Standard_Integer double Standard_Integer theNbTimes2
Standard_EXPORT double theOffset
Standard_EXPORT double bool theJoinByPipes
Standard_EXPORT double theFactor
Standard_EXPORT double theFactorX
Standard_EXPORT double double theFactorY
Standard_EXPORT double double double theFactorZ
Standard_EXPORT double double double bool doCopy
Standard_EXPORT double bool bool theReverse
Standard_EXPORT double theAngle
Standard_EXPORT Standard_Integer theNbTimes
Standard_EXPORT double theAngleStep
Standard_EXPORT double Standard_Integer theNbSteps
Standard_EXPORT Standard_Integer theNbObjects
Standard_EXPORT Standard_Integer double theRadialStep
Standard_EXPORT Standard_Integer double Standard_Integer theNbSteps
Standard_EXPORT const Standard_Real theRadius
Standard_EXPORT const Standard_Real const Standard_Real theStartAngle
Standard_EXPORT const Standard_Real const Standard_Real const Standard_Real theAngleLength
Standard_EXPORT const Standard_Real const Standard_Real const Standard_Real const Standard_Real theAngleRotation
◆ GEOMImpl_ITransformOperations()
GEOMImpl_ITransformOperations::GEOMImpl_ITransformOperations ( GEOM_Engine *  theEngine)
constructor:
◆ ~GEOMImpl_ITransformOperations()
GEOMImpl_ITransformOperations::~GEOMImpl_ITransformOperations ( )
destructor
◆ Handle() [1/73]
Standard_EXPORT GEOMImpl_ITransformOperations::Handle ( GEOM_Object  ) const &
◆ Handle() [2/73]
◆ Handle() [3/73]
◆ Handle() [4/73]
◆ Handle() [5/73]
◆ Handle() [6/73]
◆ Handle() [7/73]
◆ Handle() [8/73]
◆ Handle() [9/73]
◆ Handle() [10/73]
◆ Handle() [11/73]
◆ Handle() [12/73]
◆ Handle() [13/73]
◆ Handle() [14/73]
◆ Handle() [15/73]
◆ Handle() [16/73]
◆ Handle() [17/73]
◆ Handle() [18/73]
◆ Handle() [19/73]
◆ Handle() [20/73]
◆ Handle() [21/73]
◆ Handle() [22/73]
◆ Handle() [23/73]
◆ Handle() [24/73]
◆ Handle() [25/73]
◆ Handle() [26/73]
◆ Handle() [27/73]
◆ Handle() [28/73]
◆ Handle() [29/73]
◆ Handle() [30/73]
◆ Handle() [31/73]
◆ Handle() [32/73]
◆ Handle() [33/73]
◆ Handle() [34/73]
◆ Handle() [35/73]
◆ Handle() [36/73]
◆ Handle() [37/73]
◆ Handle() [38/73]
◆ Handle() [39/73]
◆ Handle() [40/73]
◆ Handle() [41/73]
◆ Handle() [42/73]
◆ Handle() [43/73]
◆ Handle() [44/73]
◆ Handle() [45/73]
◆ Handle() [46/73]
◆ Handle() [47/73]
◆ Handle() [48/73]
◆ Handle() [49/73]
◆ Handle() [50/73]
◆ Handle() [51/73]
◆ Handle() [52/73]
◆ Handle() [53/73]
◆ Handle() [54/73]
◆ Handle() [55/73]
◆ Handle() [56/73]
◆ Handle() [57/73]
◆ Handle() [58/73]
◆ Handle() [59/73]
◆ Handle() [60/73]
◆ Handle() [61/73]
◆ Handle() [62/73]
Standard_EXPORT double Standard_Integer GEOMImpl_ITransformOperations::Handle ( GEOM_Object  )
◆ Handle() [63/73]
◆ Handle() [64/73]
◆ Handle() [65/73]
◆ Handle() [66/73]
◆ Handle() [67/73]
◆ Handle() [68/73]
◆ Handle() [69/73]
◆ Handle() [70/73]
◆ Handle() [71/73]
◆ Handle() [72/73]
◆ Handle() [73/73]
Standard_EXPORT double bool const GEOMImpl_ITransformOperations::Handle ( TColStd_HArray1OfInteger  ) &
◆ ProjectPointOnWire()
Standard_Real GEOMImpl_ITransformOperations::ProjectPointOnWire ( Handle(GEOM_Object)  thePoint,
Handle(GEOM_Object) &  thePointOnEdge,
Standard_Integer &  theEdgeInWireIndex
◆ doCopy
Standard_EXPORT double double double bool GEOMImpl_ITransformOperations::doCopy
◆ theAngle
Standard_EXPORT double GEOMImpl_ITransformOperations::theAngle
◆ theAngleLength
Standard_EXPORT const Standard_Real const Standard_Real const Standard_Real GEOMImpl_ITransformOperations::theAngleLength
◆ theAngleRotation
Standard_EXPORT const Standard_Real const Standard_Real const Standard_Real const Standard_Real GEOMImpl_ITransformOperations::theAngleRotation
◆ theAngleStep
Standard_EXPORT double GEOMImpl_ITransformOperations::theAngleStep
◆ theCopy
Standard_EXPORT double bool GEOMImpl_ITransformOperations::theCopy
◆ theDistance
Standard_EXPORT double GEOMImpl_ITransformOperations::theDistance
◆ theFactor
Standard_EXPORT double GEOMImpl_ITransformOperations::theFactor
◆ theFactorX
Standard_EXPORT double GEOMImpl_ITransformOperations::theFactorX
◆ theFactorY
Standard_EXPORT double double GEOMImpl_ITransformOperations::theFactorY
◆ theFactorZ
Standard_EXPORT double double double GEOMImpl_ITransformOperations::theFactorZ
◆ theJoinByPipes
Standard_EXPORT double bool GEOMImpl_ITransformOperations::theJoinByPipes
◆ theNbObjects
Standard_EXPORT Standard_Integer GEOMImpl_ITransformOperations::theNbObjects
◆ theNbSteps [1/2]
Standard_EXPORT double Standard_Integer GEOMImpl_ITransformOperations::theNbSteps
◆ theNbSteps [2/2]
Standard_EXPORT Standard_Integer double Standard_Integer GEOMImpl_ITransformOperations::theNbSteps
◆ theNbTimes [1/2]
Standard_EXPORT double Standard_Integer GEOMImpl_ITransformOperations::theNbTimes
◆ theNbTimes [2/2]
Standard_EXPORT Standard_Integer GEOMImpl_ITransformOperations::theNbTimes
◆ theNbTimes1
Standard_EXPORT double Standard_Integer GEOMImpl_ITransformOperations::theNbTimes1
◆ theNbTimes2
Standard_EXPORT double Standard_Integer double Standard_Integer GEOMImpl_ITransformOperations::theNbTimes2
◆ theOffset
Standard_EXPORT double GEOMImpl_ITransformOperations::theOffset
◆ theRadialStep
Standard_EXPORT Standard_Integer double GEOMImpl_ITransformOperations::theRadialStep
◆ theRadius
Standard_EXPORT const Standard_Real GEOMImpl_ITransformOperations::theRadius
◆ theReverse
Standard_EXPORT double bool bool GEOMImpl_ITransformOperations::theReverse
◆ theStartAngle
Standard_EXPORT const Standard_Real const Standard_Real GEOMImpl_ITransformOperations::theStartAngle
◆ theStep [1/2]
Standard_EXPORT double GEOMImpl_ITransformOperations::theStep
◆ theStep [2/2]
Standard_EXPORT double Standard_Integer double GEOMImpl_ITransformOperations::theStep
◆ theStep1
Standard_EXPORT double GEOMImpl_ITransformOperations::theStep1
◆ theStep2
Standard_EXPORT double Standard_Integer double GEOMImpl_ITransformOperations::theStep2
◆ theX
Standard_EXPORT double GEOMImpl_ITransformOperations::theX
◆ theY
Standard_EXPORT double double GEOMImpl_ITransformOperations::theY
◆ theZ
Standard_EXPORT double double double GEOMImpl_ITransformOperations::theZ
