STLPlugin_IOperations Class Reference
#include <STLPlugin_IOperations.hxx>
Inheritance diagram for STLPlugin_IOperations:
 STLPlugin_IOperations (GEOM_Engine *)
 ~STLPlugin_IOperations ()
void ExportSTL (const Handle(GEOM_Object), const TCollection_AsciiString &, const bool, const double, const bool)
 Handle (TColStd_HSequenceOfTransient) ImportSTL(const TCollection_AsciiString &)
- Public Member Functions inherited from GEOMImpl_IBaseIEOperations
Standard_EXPORT GEOMImpl_IBaseIEOperations (GEOM_Engine *theEngine)
Standard_EXPORT ~GEOMImpl_IBaseIEOperations ()
- Public Member Functions inherited from GEOM_IOperations
Standard_EXPORT GEOM_IOperations (GEOM_Engine *theEngine)
Standard_EXPORT ~GEOM_IOperations ()
Standard_EXPORT void StartOperation ()
Standard_EXPORT void FinishOperation ()
Standard_EXPORT void AbortOperation ()
Standard_EXPORT bool IsDone ()
Standard_EXPORT void SetNotDone ()
Standard_EXPORT void SetErrorCode (const TCollection_AsciiString &theErrorCode)
Standard_EXPORT char * GetErrorCode ()
Standard_EXPORT GEOM_Engine * GetEngine ()
Standard_EXPORT GEOM_Solver * GetSolver ()
- Protected Member Functions inherited from GEOMImpl_IBaseIEOperations
Standard_EXPORT void MakeMaterialGroups (const Handle(GEOM_Object) &theObject, const Handle(TColStd_HSequenceOfTransient) &theSeq)
 Handle (GEOM_Object) MakeGroup(const Handle(GEOM_Object) &theObject
- Protected Attributes inherited from GEOMImpl_IBaseIEOperations
const TCollection_ExtendedString & theName
const TCollection_ExtendedString const NCollection_List< TopoDS_Shape > & theShapes
GEOMImpl_IGroupOperations * myGroupOperations
GEOMImpl_IFieldOperations * myFieldOperations
GEOMImpl_IShapesOperations * myShapesOperations
◆ STLPlugin_IOperations()
STLPlugin_IOperations::STLPlugin_IOperations ( GEOM_Engine *  theEngine)
Constructor
◆ ~STLPlugin_IOperations()
STLPlugin_IOperations::~STLPlugin_IOperations ( )
Destructor
◆ ExportSTL()
void STLPlugin_IOperations::ExportSTL ( const   HandleGEOM_Object,
const TCollection_AsciiString &  ,
const bool  ,
const double  ,
const bool
ExportSTL Export a shape to STL format
theOriginalThe shape to export
theFileNameThe name of the file to exported
theIsASCIIThe format of the exported file (ASCII or Binary)
theDeflectionThe deflection of the shape to exported
theIsRelativeThe mode for writing the file. If True (default value), the deflection is calculated relatively to the size of the shape; if False, the user defined deflection is used.
References EXPORT_SHAPE, GEOM_IMPORT, GEOM_IOperations::GetEngine(), GEOM_IOperations::GetSolver(), Handle(), KO, OK, STLPlugin_IExport::SetDeflection(), GEOM_IOperations::SetErrorCode(), STLPlugin_IExport::SetFileName(), STLPlugin_IExport::SetIsASCII(), STLPlugin_IExport::SetIsRelative(), and STLPlugin_IExport::SetOriginal().
◆ Handle()
STLPlugin_IOperations::Handle ( TColStd_HSequenceOfTransient  ) const &
