27#ifndef GLVIEWER_OBJECT_H
28#define GLVIEWER_OBJECT_H
48#pragma warning( disable:4251 )
92 GLboolean isCircle = GL_FALSE ) = 0;
110 GLboolean isFull = GL_FALSE,
111 GLboolean isCircle = GL_FALSE,
112 GLboolean isShift = GL_FALSE ) = 0;
131 myRect->left(), myRect->right(), myRect->top(), myRect->bottom() ); }
142 virtual void setScale( GLfloat xScale, GLfloat yScale ) { myXScale = xScale; myYScale = yScale; }
144 virtual void getScale( GLfloat& xScale, GLfloat& yScale )
const { xScale = myXScale; yScale = myYScale;}
147 virtual GLboolean setZoom( GLfloat zoom,
bool recompute,
bool fromGroup =
false );
149 virtual GLfloat
getZoom()
const {
return myZoom; }
151 virtual GLboolean updateZoom(
bool zoomIn );
175 void setName( QString name ) { myName = name; }
180 virtual int getPriority()
const;
188 virtual void moveObject(
float dx,
float dy,
bool fromGroup =
false ) = 0;
195 virtual void setVisible(
bool theStatus ) { myIsVisible = theStatus; }
209 virtual QByteArray getByteCopy();
212 virtual bool initializeFromByteCopy( QByteArray );
312#pragma warning ( default:4251 )
#define GLVIEWER_API
Macro for exports.
Definition: GLViewer.h:37
Class for manage of presentations in GLViewer.
Definition: GLViewer_AspectLine.h:44
Class implementing mathematical model of 2D coordinate system.
Definition: GLViewer_CoordSystem.h:45
Definition: GLViewer_Drawer.h:193
Definition: GLViewer_Group.h:49
Definition: GLViewer_Object.h:65
SUIT_DataOwner * myOwner
Definition: GLViewer_Object.h:305
GLfloat myYGap
Gap for Y direction of rect.
Definition: GLViewer_Object.h:278
virtual bool translateToHPGL(QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aHPGLCS)=0
A function translate object in to HPGL file on disk.
GLfloat myZoom
Definition: GLViewer_Object.h:281
QString getObjectType() const
Returns object type.
Definition: GLViewer_Object.h:172
GLboolean myIsHigh
Highlight status.
Definition: GLViewer_Object.h:285
GLViewer_Drawer * myDrawer
Object drawer.
Definition: GLViewer_Object.h:291
virtual GLViewer_Object * getOwner()
Definition: GLViewer_Object.h:251
virtual QString getToolTipText()
Returns onject tool tip text.
Definition: GLViewer_Object.h:200
virtual GLViewer_Rect getPullingRect() const
Definition: GLViewer_Object.h:130
bool myIsVisible
Object visibke status.
Definition: GLViewer_Object.h:302
QString myToolTipText
Objet tool tip text.
Definition: GLViewer_Object.h:296
virtual void setSelected(GLboolean state)
Installs select status to object.
Definition: GLViewer_Object.h:158
GLboolean myIsSel
Selectt status.
Definition: GLViewer_Object.h:288
GLViewer_Group * myGroup
Object Group.
Definition: GLViewer_Object.h:308
virtual bool getVisible() const
Returns visible object status.
Definition: GLViewer_Object.h:193
virtual void setVisible(bool theStatus)
Installs visible object status.
Definition: GLViewer_Object.h:195
virtual void finishPulling()
Definition: GLViewer_Object.h:126
virtual bool isPulling()
Definition: GLViewer_Object.h:128
QString getName() const
Returns object name.
Definition: GLViewer_Object.h:177
virtual GLboolean unselect()=0
Clears all select information.
virtual bool translateToPS(QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aPSCS)=0
A function translate object in to PostScript file on disk.
virtual GLboolean unhighlight()=0
Clears all highlight information.
virtual GLboolean select(GLfloat x, GLfloat y, GLfloat tol, GLViewer_Rect rect, GLboolean isFull=GL_FALSE, GLboolean isCircle=GL_FALSE, GLboolean isShift=GL_FALSE)=0
Computes select presentation.
virtual GLboolean isHighlighted() const
Returns true if object is highlighted.
Definition: GLViewer_Object.h:154
virtual GLViewer_AspectLine * getAspectLine() const
Returns acpect line of object presentation.
Definition: GLViewer_Object.h:168
GLViewer_Drawer * getDrawer() const
Returns current drawer.
Definition: GLViewer_Object.h:80
QString myName
Object name.
Definition: GLViewer_Object.h:260
virtual GLboolean highlight(GLfloat x, GLfloat y, GLfloat tol, GLboolean isCircle=GL_FALSE)=0
Computes highlight presentation.
GLfloat myXScale
X scale factor.
Definition: GLViewer_Object.h:272
virtual GLfloat getZoom() const
Definition: GLViewer_Object.h:149
GLViewer_Text * myGLText
Object GLText.
Definition: GLViewer_Object.h:269
void setGLText(GLViewer_Text *glText)
Installs GLText to object.
Definition: GLViewer_Object.h:161
void setOwner(SUIT_DataOwner *owner)
Definition: GLViewer_Object.h:243
virtual bool startPulling(GLViewer_Pnt)
Definition: GLViewer_Object.h:122
virtual void pull(GLViewer_Pnt, GLViewer_Object *)
Definition: GLViewer_Object.h:124
void setToolTipText(QString str)
Installs onject tool tip text.
Definition: GLViewer_Object.h:198
bool isTooTipHTML() const
Returns true if tool tip contains HTML tags.
Definition: GLViewer_Object.h:203
virtual void setRect(GLViewer_Rect *rect)
Installs object rectangle.
Definition: GLViewer_Object.h:134
bool isToolTipHTML
HTML object tool tip status.
Definition: GLViewer_Object.h:299
virtual void setAspectLine(GLViewer_AspectLine *aspect)
Installs acpect line for object presentation.
Definition: GLViewer_Object.h:166
void setToolTipFormat(bool isHTML)
Installs tool tip supporting of HTML tags.
Definition: GLViewer_Object.h:205
virtual void setDrawer(GLViewer_Drawer *theDrawer)
Installing already exist drawer with same type.
Definition: GLViewer_Object.h:78
virtual bool isScalable()
Definition: GLViewer_Object.h:256
virtual GLViewer_Rect * getUpdateRect()=0
Returns update object rectangle.
GLfloat myYScale
Y scale factor.
Definition: GLViewer_Object.h:274
virtual GLViewer_Drawer * createDrawer()=0
Creates correspond drawer.
virtual bool portContains(GLViewer_Pnt)
Definition: GLViewer_Object.h:120
virtual bool finishMove()
Finaly recomputing object after moving.
Definition: GLViewer_Object.h:190
GLfloat myXGap
Gap for X direction of rect.
Definition: GLViewer_Object.h:276
virtual GLViewer_Rect * getRect() const
Returns object rectungle.
Definition: GLViewer_Object.h:136
virtual void getScale(GLfloat &xScale, GLfloat &yScale) const
Returns scale factors.
Definition: GLViewer_Object.h:144
void setName(QString name)
Installs object name.
Definition: GLViewer_Object.h:175
GLViewer_Text * getGLText() const
Returns object GLText.
Definition: GLViewer_Object.h:163
GLViewer_AspectLine * myAspectLine
Line aspect for object presentation.
Definition: GLViewer_Object.h:293
QString myType
Object type.
Definition: GLViewer_Object.h:262
virtual GLboolean isSelected() const
Returns true if object is selected.
Definition: GLViewer_Object.h:156
SUIT_DataOwner * owner() const
Definition: GLViewer_Object.h:241
virtual void setScale(GLfloat xScale, GLfloat yScale)
Installs scale factors.
Definition: GLViewer_Object.h:142
virtual void moveObject(float dx, float dy, bool fromGroup=false)=0
Moves object per by recomputing.
virtual void compute()=0
Main method. Computes all needed information about object for presentation in drawer.
virtual bool isSelectable()
Returns true if object can be selected.
Definition: GLViewer_Object.h:254
GLViewer_Rect * myUpdateRect
Update object rect (after some viewer transformations)
Definition: GLViewer_Object.h:267
GLViewer_Rect * myRect
Object base rect.
Definition: GLViewer_Object.h:265
Definition: GLViewer_Geom.h:69
Definition: GLViewer_Text.h:56
Definition: SUIT_DataOwner.h:44
Definition: GLViewer_Geom.h:45
