GLViewer_Object Class Referenceabstract
#include <GLViewer_Object.h>
Inheritance diagram for GLViewer_Object:
 GLViewer_Object ()
 A constructor. More...
virtual ~GLViewer_Object ()
 A destructor. More...
virtual void compute ()=0
 Main method. Computes all needed information about object for presentation in drawer. More...
virtual GLViewer_Drawer * createDrawer ()=0
 Creates correspond drawer. More...
virtual void setDrawer (GLViewer_Drawer *theDrawer)
 Installing already exist drawer with same type. More...
GLViewer_Drawer * getDrawer () const
 Returns current drawer. More...
virtual GLboolean highlight (GLfloat x, GLfloat y, GLfloat tol, GLboolean isCircle=GL_FALSE)=0
 Computes highlight presentation. More...
virtual GLboolean unhighlight ()=0
 Clears all highlight information. More...
virtual GLboolean select (GLfloat x, GLfloat y, GLfloat tol, GLViewer_Rect rect, GLboolean isFull=GL_FALSE, GLboolean isCircle=GL_FALSE, GLboolean isShift=GL_FALSE)=0
 Computes select presentation. More...
virtual GLboolean unselect ()=0
 Clears all select information. More...
virtual GLboolean isInside (GLViewer_Rect theRect)
 Returns if theRect inside object. More...
virtual bool portContains (GLViewer_Pnt)
virtual bool startPulling (GLViewer_Pnt)
virtual void pull (GLViewer_Pnt, GLViewer_Object *)
virtual void finishPulling ()
virtual bool isPulling ()
virtual GLViewer_Rect getPullingRect () const
virtual void setRect (GLViewer_Rect *rect)
 Installs object rectangle. More...
virtual GLViewer_Rect * getRect () const
 Returns object rectungle. More...
virtual GLViewer_Rect * getUpdateRect ()=0
 Returns update object rectangle. More...
virtual void setScale (GLfloat xScale, GLfloat yScale)
 Installs scale factors. More...
virtual void getScale (GLfloat &xScale, GLfloat &yScale) const
 Returns scale factors. More...
virtual GLboolean setZoom (GLfloat zoom, bool recompute, bool fromGroup=false)
virtual GLfloat getZoom () const
virtual GLboolean updateZoom (bool zoomIn)
virtual GLboolean isHighlighted () const
 Returns true if object is highlighted. More...
virtual GLboolean isSelected () const
 Returns true if object is selected. More...
virtual void setSelected (GLboolean state)
 Installs select status to object. More...
void setGLText (GLViewer_Text *glText)
 Installs GLText to object. More...
GLViewer_Text * getGLText () const
 Returns object GLText. More...
virtual void setAspectLine (GLViewer_AspectLine *aspect)
 Installs acpect line for object presentation. More...
virtual GLViewer_AspectLine * getAspectLine () const
 Returns acpect line of object presentation. More...
QString getObjectType () const
 Returns object type. More...
void setName (QString name)
 Installs object name. More...
QString getName () const
 Returns object name. More...
virtual int getPriority () const
 Returns object priority. More...
virtual void moveObject (float dx, float dy, bool fromGroup=false)=0
 Moves object per by recomputing. More...
virtual bool finishMove ()
 Finaly recomputing object after moving. More...
virtual bool getVisible () const
 Returns visible object status. More...
virtual void setVisible (bool theStatus)
 Installs visible object status. More...
void setToolTipText (QString str)
 Installs onject tool tip text. More...
virtual QString getToolTipText ()
 Returns onject tool tip text. More...
bool isTooTipHTML () const
 Returns true if tool tip contains HTML tags. More...
void setToolTipFormat (bool isHTML)
 Installs tool tip supporting of HTML tags. More...
virtual QByteArray getByteCopy ()
 A function for coding object to the byte copy. More...
virtual bool initializeFromByteCopy (QByteArray)
 A function for decoding object from the byte copy. More...
virtual bool translateToPS (QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aPSCS)=0
 A function translate object in to PostScript file on disk. More...
virtual bool translateToHPGL (QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aHPGLCS)=0
 A function translate object in to HPGL file on disk. More...
SUIT_DataOwner * owner () const
void setOwner (SUIT_DataOwner *owner)
void setGroup (GLViewer_Group *theGroup)
 Adds object to group theGroup. More...
GLViewer_Group * getGroup () const
 Returns object group. More...
virtual GLViewer_Object * getOwner ()
virtual bool isSelectable ()
 Returns true if object can be selected. More...
virtual bool isScalable ()
QString myName
 Object name. More...
QString myType
 Object type. More...
GLViewer_Rect * myRect
 Object base rect. More...
GLViewer_Rect * myUpdateRect
 Update object rect (after some viewer transformations) More...
GLViewer_Text * myGLText
 Object GLText. More...
GLfloat myXScale
 X scale factor. More...
GLfloat myYScale
 Y scale factor. More...
GLfloat myXGap
 Gap for X direction of rect. More...
GLfloat myYGap
 Gap for Y direction of rect. More...
GLfloat myZoom
GLboolean myIsHigh
 Highlight status. More...
GLboolean myIsSel
 Selectt status. More...
GLViewer_Drawer * myDrawer
 Object drawer. More...
GLViewer_AspectLine * myAspectLine
 Line aspect for object presentation. More...
QString myToolTipText
 Objet tool tip text. More...
bool isToolTipHTML
 HTML object tool tip status. More...
bool myIsVisible
 Object visibke status. More...
SUIT_DataOwner * myOwner
GLViewer_Group * myGroup
 Object Group. More...
Class GLViewer_Object Base Object for all GLViewer objects
Base Viewer for GLViewer
◆ GLViewer_Object()
GLViewer_Object::GLViewer_Object ( )
◆ ~GLViewer_Object()
GLViewer_Object::~GLViewer_Object ( )
A destructor.
Destructor
References myAspectLine, myGLText, myOwner, myRect, and myUpdateRect.
◆ compute()
virtual void GLViewer_Object::compute ( )
pure virtual
Implemented in GLViewer_MarkerSet, GLViewer_Polyline, and GLViewer_TextObject.
◆ createDrawer()
virtual GLViewer_Drawer * GLViewer_Object::createDrawer ( )
pure virtual
◆ finishMove()
virtual bool GLViewer_Object::finishMove ( )
◆ finishPulling()
virtual void GLViewer_Object::finishPulling ( )
Warning
It is for ouv
◆ getAspectLine()
virtual GLViewer_AspectLine * GLViewer_Object::getAspectLine ( ) const
◆ getByteCopy()
QByteArray GLViewer_Object::getByteCopy ( )
A function is used for copy-past technollogy in copy method
Codes object as byte copy
byte array
Reimplemented in GLViewer_MarkerSet, GLViewer_Polyline, and GLViewer_TextObject.
References GLViewer_Rect::bottom(), GLViewer_AspectLine::getByteCopy(), GLViewer_Text::getByteCopy(), GLViewer_Rect::left(), myAspectLine, myGLText, myOwner, myRect, myToolTipText, myType, myXGap, myXScale, myYGap, myYScale, GLViewer_Rect::right(), and GLViewer_Rect::top().
◆ getDrawer()
GLViewer_Drawer * GLViewer_Object::getDrawer ( ) const
◆ getGLText()
GLViewer_Text * GLViewer_Object::getGLText ( ) const
◆ getGroup()
GLViewer_Group * GLViewer_Object::getGroup ( ) const
object's group
References myGroup.
◆ getName()
QString GLViewer_Object::getName ( ) const
◆ getObjectType()
QString GLViewer_Object::getObjectType ( ) const
Needs for GLViewer_Drawer
◆ getOwner()
virtual GLViewer_Object * GLViewer_Object::getOwner ( )
Warning
It is for ouv
◆ getPriority()
int GLViewer_Object::getPriority ( ) const
priority of object
References GLViewer_Drawer::getPriority(), and myDrawer.
◆ getPullingRect()
virtual GLViewer_Rect GLViewer_Object::getPullingRect ( ) const
Warning
It is for ouv
◆ getRect()
virtual GLViewer_Rect * GLViewer_Object::getRect ( ) const
◆ getScale()
virtual void GLViewer_Object::getScale ( GLfloat &  xScale,
GLfloat &  yScale
◆ getToolTipText()
virtual QString GLViewer_Object::getToolTipText ( )
◆ getUpdateRect()
virtual GLViewer_Rect * GLViewer_Object::getUpdateRect ( )
pure virtual
Does not equal getRect() if object have a persistence to some viewer transformations
◆ getVisible()
virtual bool GLViewer_Object::getVisible ( ) const
◆ getZoom()
virtual GLfloat GLViewer_Object::getZoom ( ) const
Warning
It is for ouv
◆ highlight()
virtual GLboolean GLViewer_Object::highlight ( GLfloat  x,
GLfloat  y,
GLfloat  tol,
GLboolean  isCircle = GL_FALSE
pure virtual
x- x coord
y- y coord
tol- tolerance of detecting
isCircle- = true if sensitive area of detection is round
Implemented in GLViewer_TextObject, GLViewer_MarkerSet, and GLViewer_Polyline.
◆ initializeFromByteCopy()
bool GLViewer_Object::initializeFromByteCopy ( QByteArray  theArray)
A function is used for copy-past technollogy in past method
Initialize object by byte array
theArray- byte array
References GLViewer_AspectLine::fromByteCopy(), GLViewer_Text::fromByteCopy(), GLViewer_AspectLine::getByteCopy(), GLViewer_Text::getByteCopy(), myAspectLine, myGLText, myIsHigh, myIsSel, myIsVisible, myRect, myToolTipText, myType, myXGap, myXScale, myYGap, and myYScale.
◆ isHighlighted()
virtual GLboolean GLViewer_Object::isHighlighted ( ) const
◆ isInside()
GLboolean GLViewer_Object::isInside ( GLViewer_Rect  theRect)
true if object is inside rectangle
theRect- rectangle
References myRect, and GLViewer_Rect::toQRect().
◆ isPulling()
virtual bool GLViewer_Object::isPulling ( )
Warning
It is for ouv
◆ isScalable()
virtual bool GLViewer_Object::isScalable ( )
Warning
It is for ouv
◆ isSelectable()
virtual bool GLViewer_Object::isSelectable ( )
◆ isSelected()
virtual GLboolean GLViewer_Object::isSelected ( ) const
◆ isTooTipHTML()
bool GLViewer_Object::isTooTipHTML ( ) const
◆ moveObject()
virtual void GLViewer_Object::moveObject ( float  dx,
float  dy,
bool  fromGroup = false
pure virtual
dx- moving along X coord
dy- moving along Y coord
fromGroup- = true if this method called from group
◆ owner()
SUIT_DataOwner * GLViewer_Object::owner ( ) const
Warning
It is for ouv
◆ portContains()
virtual bool GLViewer_Object::portContains ( GLViewer_Pnt  )
Warning
It is for ouv
◆ pull()
virtual void GLViewer_Object::pull ( GLViewer_Pnt  ,
GLViewer_Object *
Warning
It is for ouv
◆ select()
virtual GLboolean GLViewer_Object::select ( GLfloat  x,
GLfloat  y,
GLfloat  tol,
GLViewer_Rect  rect,
GLboolean  isFull = GL_FALSE,
GLboolean  isCircle = GL_FALSE,
GLboolean  isShift = GL_FALSE
pure virtual
x- x coord
y- y coord
rect- Non empty for rectangle selection
isFull- = true if
isShift- = true if selection exec with append option
◆ setAspectLine()
virtual void GLViewer_Object::setAspectLine ( GLViewer_AspectLine *  aspect)
◆ setDrawer()
virtual void GLViewer_Object::setDrawer ( GLViewer_Drawer *  theDrawer)
Reimplemented in GLViewer_TextObject.
◆ setGLText()
void GLViewer_Object::setGLText ( GLViewer_Text *  glText)
◆ setGroup()
void GLViewer_Object::setGroup ( GLViewer_Group *  theGroup)
Sets object's group
theGroup- group
References GLViewer_Group::addObject(), myGroup, and GLViewer_Group::removeObject().
◆ setName()
void GLViewer_Object::setName ( QString  name)
◆ setOwner()
void GLViewer_Object::setOwner ( SUIT_DataOwner *  owner)
Warning
It is for ouv
◆ setRect()
virtual void GLViewer_Object::setRect ( GLViewer_Rect *  rect)
◆ setScale()
virtual void GLViewer_Object::setScale ( GLfloat  xScale,
GLfloat  yScale
◆ setSelected()
virtual void GLViewer_Object::setSelected ( GLboolean  state)
◆ setToolTipFormat()
void GLViewer_Object::setToolTipFormat ( bool  isHTML)
◆ setToolTipText()
void GLViewer_Object::setToolTipText ( QString  str)
◆ setVisible()
virtual void GLViewer_Object::setVisible ( bool  theStatus)
◆ setZoom()
GLboolean GLViewer_Object::setZoom ( GLfloat  zoom,
bool  recompute,
Warning
It is for ouv
Sets zoom factor
zoom- zoom factor
References myZoom.
◆ startPulling()
virtual bool GLViewer_Object::startPulling ( GLViewer_Pnt  )
Warning
It is for ouv
◆ translateToHPGL()
virtual bool GLViewer_Object::translateToHPGL ( QFile &  hFile,
GLViewer_CoordSystem *  aViewerCS,
GLViewer_CoordSystem *  aHPGLCS
pure virtual
hFilethe name of PostScript file chosen by user
aViewerCSthe GLViewer_CoordSystem of window
aHPGLCSthe GLViewer_CoordSystem of PostScript page
◆ translateToPS()
virtual bool GLViewer_Object::translateToPS ( QFile &  hFile,
GLViewer_CoordSystem *  aPSCS
pure virtual
aPSCSthe GLViewer_CoordSystem of PostScript page
◆ unhighlight()
virtual GLboolean GLViewer_Object::unhighlight ( )
pure virtual
◆ unselect()
virtual GLboolean GLViewer_Object::unselect ( )
pure virtual
◆ updateZoom()
GLboolean GLViewer_Object::updateZoom ( bool  zoomIn)
Warning
It is for ouv
Performs zoom change by step
zoomIn- to increase to decrease zoom
References myZoom, and setZoom().
◆ isToolTipHTML
bool GLViewer_Object::isToolTipHTML
= true if tool tip text contains HTML tags
◆ myAspectLine
GLViewer_AspectLine* GLViewer_Object::myAspectLine
◆ myDrawer
GLViewer_Drawer* GLViewer_Object::myDrawer
Object drawer.
◆ myGLText
GLViewer_Text* GLViewer_Object::myGLText
Object GLText.
◆ myGroup
GLViewer_Group* GLViewer_Object::myGroup
Object Group.
◆ myIsHigh
GLboolean GLViewer_Object::myIsHigh
Highlight status.
= true after right highlighting
◆ myIsSel
GLboolean GLViewer_Object::myIsSel
Selectt status.
= true after right selection
◆ myIsVisible
bool GLViewer_Object::myIsVisible
◆ myName
QString GLViewer_Object::myName
Object name.
◆ myOwner
SUIT_DataOwner* GLViewer_Object::myOwner
Warning
It is for ouv
◆ myRect
GLViewer_Rect* GLViewer_Object::myRect
Object base rect.
◆ myToolTipText
QString GLViewer_Object::myToolTipText
◆ myType
QString GLViewer_Object::myType
Object type.
◆ myUpdateRect
GLViewer_Rect* GLViewer_Object::myUpdateRect
◆ myXGap
GLfloat GLViewer_Object::myXGap
◆ myXScale
GLfloat GLViewer_Object::myXScale
X scale factor.
◆ myYGap
GLfloat GLViewer_Object::myYGap
◆ myYScale
GLfloat GLViewer_Object::myYScale
Y scale factor.
◆ myZoom
GLfloat GLViewer_Object::myZoom
Warning
It is for ouv
