GLViewer_TextObject Class Reference
#include <GLViewer_BaseObjects.h>
Inheritance diagram for GLViewer_TextObject:
 GLViewer_TextObject (const QString &, float xPos=0, float yPos=0, const QColor &color=QColor(0, 255, 0), const QString &toolTip="GLText")
 ~GLViewer_TextObject ()
virtual void compute ()
virtual GLViewer_Drawer * createDrawer ()
virtual void setDrawer (GLViewer_Drawer *theDrawer)
virtual GLboolean highlight (GLfloat x, GLfloat y, GLfloat tol, GLboolean isCircle=GL_FALSE)
virtual GLboolean unhighlight ()
virtual GLboolean select (GLfloat x, GLfloat y, GLfloat tol, GLViewer_Rect rect, GLboolean isFull=GL_FALSE, GLboolean isCircle=GL_FALSE, GLboolean isShift=GL_FALSE)
virtual GLboolean unselect ()
virtual GLViewer_Rect * getUpdateRect ()
virtual void moveObject (float, float, bool fromGroup=false)
virtual QByteArray getByteCopy ()
virtual bool initializeFromByteCopy (QByteArray)
virtual bool translateToPS (QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aPSCS)
virtual bool translateToHPGL (QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aHPGLCS)
int getWidth ()
int getHeight ()
void setWidth (int w)
void setHeight (int h)
- Public Member Functions inherited from GLViewer_Object
 GLViewer_Object ()
 A constructor. More...
virtual ~GLViewer_Object ()
 A destructor. More...
virtual void compute ()=0
 Main method. Computes all needed information about object for presentation in drawer. More...
virtual GLViewer_Drawer * createDrawer ()=0
 Creates correspond drawer. More...
 Installing already exist drawer with same type. More...
GLViewer_Drawer * getDrawer () const
 Returns current drawer. More...
virtual GLboolean highlight (GLfloat x, GLfloat y, GLfloat tol, GLboolean isCircle=GL_FALSE)=0
 Computes highlight presentation. More...
virtual GLboolean unhighlight ()=0
 Clears all highlight information. More...
virtual GLboolean select (GLfloat x, GLfloat y, GLfloat tol, GLViewer_Rect rect, GLboolean isFull=GL_FALSE, GLboolean isCircle=GL_FALSE, GLboolean isShift=GL_FALSE)=0
 Computes select presentation. More...
virtual GLboolean unselect ()=0
 Clears all select information. More...
virtual GLboolean isInside (GLViewer_Rect theRect)
 Returns if theRect inside object. More...
virtual bool portContains (GLViewer_Pnt)
virtual bool startPulling (GLViewer_Pnt)
virtual void pull (GLViewer_Pnt, GLViewer_Object *)
virtual void finishPulling ()
virtual bool isPulling ()
virtual GLViewer_Rect getPullingRect () const
virtual void setRect (GLViewer_Rect *rect)
 Installs object rectangle. More...
virtual GLViewer_Rect * getRect () const
 Returns object rectungle. More...
virtual GLViewer_Rect * getUpdateRect ()=0
 Returns update object rectangle. More...
virtual void setScale (GLfloat xScale, GLfloat yScale)
 Installs scale factors. More...
virtual void getScale (GLfloat &xScale, GLfloat &yScale) const
 Returns scale factors. More...
virtual GLboolean setZoom (GLfloat zoom, bool recompute, bool fromGroup=false)
virtual GLfloat getZoom () const
virtual GLboolean updateZoom (bool zoomIn)
virtual GLboolean isHighlighted () const
 Returns true if object is highlighted. More...
virtual GLboolean isSelected () const
 Returns true if object is selected. More...
virtual void setSelected (GLboolean state)
 Installs select status to object. More...
void setGLText (GLViewer_Text *glText)
 Installs GLText to object. More...
GLViewer_Text * getGLText () const
 Returns object GLText. More...
virtual void setAspectLine (GLViewer_AspectLine *aspect)
 Installs acpect line for object presentation. More...
virtual GLViewer_AspectLine * getAspectLine () const
 Returns acpect line of object presentation. More...
QString getObjectType () const
 Returns object type. More...
void setName (QString name)
 Installs object name. More...
QString getName () const
 Returns object name. More...
virtual int getPriority () const
 Returns object priority. More...
virtual void moveObject (float dx, float dy, bool fromGroup=false)=0
 Moves object per by recomputing. More...
virtual bool finishMove ()
 Finaly recomputing object after moving. More...
virtual bool getVisible () const
 Returns visible object status. More...
virtual void setVisible (bool theStatus)
 Installs visible object status. More...
void setToolTipText (QString str)
 Installs onject tool tip text. More...
virtual QString getToolTipText ()
 Returns onject tool tip text. More...
bool isTooTipHTML () const
 Returns true if tool tip contains HTML tags. More...
void setToolTipFormat (bool isHTML)
 Installs tool tip supporting of HTML tags. More...
 A function for coding object to the byte copy. More...
 A function for decoding object from the byte copy. More...
virtual bool translateToPS (QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aPSCS)=0
 A function translate object in to PostScript file on disk. More...
virtual bool translateToHPGL (QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aHPGLCS)=0
 A function translate object in to HPGL file on disk. More...
SUIT_DataOwner * owner () const
void setOwner (SUIT_DataOwner *owner)
void setGroup (GLViewer_Group *theGroup)
 Adds object to group theGroup. More...
GLViewer_Group * getGroup () const
 Returns object group. More...
virtual GLViewer_Object * getOwner ()
virtual bool isSelectable ()
 Returns true if object can be selected. More...
virtual bool isScalable ()
bool myHighFlag
int myWidth
int myHeight
- Protected Attributes inherited from GLViewer_Object
QString myName
 Object name. More...
QString myType
 Object type. More...
GLViewer_Rect * myRect
 Object base rect. More...
GLViewer_Rect * myUpdateRect
 Update object rect (after some viewer transformations) More...
GLViewer_Text * myGLText
 Object GLText. More...
GLfloat myXScale
 X scale factor. More...
GLfloat myYScale
 Y scale factor. More...
GLfloat myXGap
 Gap for X direction of rect. More...
GLfloat myYGap
 Gap for Y direction of rect. More...
GLfloat myZoom
GLboolean myIsHigh
 Highlight status. More...
GLboolean myIsSel
 Selectt status. More...
GLViewer_Drawer * myDrawer
 Object drawer. More...
GLViewer_AspectLine * myAspectLine
 Line aspect for object presentation. More...
QString myToolTipText
 Objet tool tip text. More...
bool isToolTipHTML
 HTML object tool tip status. More...
bool myIsVisible
 Object visibke status. More...
SUIT_DataOwner * myOwner
GLViewer_Group * myGroup
 Object Group. More...
Text as Object for OpenGL
◆ GLViewer_TextObject()
GLViewer_TextObject::GLViewer_TextObject ( const QString &  theStr,
float  xPos = 0,
float  yPos = 0,
const QColor &  color = QColor( 0, 255, 0 ),
const QString &  toolTip = "GLText"
Constructor
theStr- text string
xPos- x position
yPos- y position
color- color of text
toolTip- tooltip of text object
References OCCViewer::color(), GLViewer_Object::myGLText, myHeight, myHighFlag, GLViewer_Object::myToolTipText, and myWidth.
◆ ~GLViewer_TextObject()
GLViewer_TextObject::~GLViewer_TextObject ( )
Destructor
References GLViewer_Object::myGLText.
◆ compute()
◆ createDrawer()
GLViewer_Drawer * GLViewer_TextObject::createDrawer ( )
Creates corresponding drawer
Implements GLViewer_Object.
References compute(), and GLViewer_Object::myDrawer.
◆ getByteCopy()
QByteArray GLViewer_TextObject::getByteCopy ( )
Codes text object as byte copy
byte array
Reimplemented from GLViewer_Object.
References GLViewer_Object::getByteCopy().
◆ getHeight()
int GLViewer_TextObject::getHeight ( )
◆ getUpdateRect()
◆ getWidth()
int GLViewer_TextObject::getWidth ( )
◆ highlight()
GLboolean GLViewer_TextObject::highlight ( GLfloat  theX,
GLfloat  theY,
GLfloat  theTol,
GLboolean  isCircle = GL_FALSE
x- x coord
y- y coord
tol- tolerance of detecting
isCircle- true if sensitive area of detection is round
true if highlight status is changed
References GLViewer_Text::getPosition(), GLViewer_Object::myGLText, myHeight, myHighFlag, GLViewer_Object::myIsHigh, GLViewer_Object::myIsVisible, myWidth, GLViewer_Object::myXScale, and GLViewer_Object::myYScale.
◆ initializeFromByteCopy()
bool GLViewer_TextObject::initializeFromByteCopy ( QByteArray  theArray)
Initialize text object by byte array
theArray- byte array
References GLViewer_Object::initializeFromByteCopy(), myHighFlag, and GLViewer_Object::myType.
◆ moveObject()
void GLViewer_TextObject::moveObject ( float  theX,
float  theY,
bool  fromGroup = false
Moves object by recomputing
dx- moving along X coord
dy- moving along Y coord
fromGroup- is true if this method called from group
References compute(), GLViewer_Group::dragingObjects(), GLViewer_Text::getPosition(), GLViewer_Object::myGLText, GLViewer_Object::myGroup, and GLViewer_Text::setPosition().
◆ select()
GLboolean GLViewer_TextObject::select ( GLfloat  theX,
GLfloat  theY,
GLfloat  theTol,
GLViewer_Rect  rect,
GLboolean  isFull = GL_FALSE,
GLboolean  isCircle = GL_FALSE,
GLboolean  isShift = GL_FALSE
Selects text object /param x, y - co-ordinates of mouse /param tol - tolerance /param rect - rectangle (in case of rectangular selection) /param isFull - if it is true, then object may selected only if it lays whole in selection zone
isShift- true if selection exec with append option
References myHighFlag, GLViewer_Object::myIsHigh, GLViewer_Object::myIsSel, GLViewer_Object::myIsVisible, GLViewer_Object::myRect, and GLViewer_Rect::toQRect().
◆ setDrawer()
void GLViewer_TextObject::setDrawer ( GLViewer_Drawer *  theDrawer)
theDrawer- new drawer
References GLViewer_Object::myDrawer.
◆ setHeight()
void GLViewer_TextObject::setHeight ( int  h)
◆ setWidth()
void GLViewer_TextObject::setWidth ( int  w)
◆ translateToHPGL()
bool GLViewer_TextObject::translateToHPGL ( QFile &  hFile,
GLViewer_CoordSystem *  aViewerCS,
GLViewer_CoordSystem *  aHPGLCS
Saves text object to file HPGL
hFile- file instance
aViewerCS- viewer co-ordinates system
aHPGLCS- paper co-ordinates system
References AddCoordsToHPGL(), GLViewer_Text::getPosition(), GLViewer_Text::getText(), and GLViewer_Object::myGLText.
◆ translateToPS()
bool GLViewer_TextObject::translateToPS ( QFile &  hFile,
GLViewer_CoordSystem *  aPSCS
Saves text object to file PostScript
aPSCS- paper co-ordinates system
References AddCoordsToPS(), GLViewer_Text::getPosition(), GLViewer_Text::getText(), and GLViewer_Object::myGLText.
◆ unhighlight()
GLboolean GLViewer_TextObject::unhighlight ( )
Unhilights object
References GLViewer_Object::myIsHigh.
◆ unselect()
GLboolean GLViewer_TextObject::unselect ( )
Unselects text object
References GLViewer_Object::myIsSel.
◆ myHeight
int GLViewer_TextObject::myHeight
◆ myHighFlag
bool GLViewer_TextObject::myHighFlag
◆ myWidth
int GLViewer_TextObject::myWidth
