GLViewer_Group Class Reference
#include <GLViewer_Group.h>
 GLViewer_Group ()
 ~GLViewer_Group ()
bool isEmpty ()
int count ()
 Returns number ob objects. More...
int contains (GLViewer_Object *)
 Returns index of position, else -1. More...
int addObject (GLViewer_Object *)
int removeObject (GLViewer_Object *)
OGList getObjects () const
void dragingObjects (float x, float y, bool once=false)
 Dragging operation. More...
void updateZoom (GLViewer_Object *sender, float zoom)
OGList myList
 List of objects. More...
int mySelObjNum
 This number needs for synchranization group with viewport drag methods. More...
Class GLViewer_Group Group of GLViewer_Objects for synchronized moving. If you move one or more objects from group, than all objects from group is moved If group is empty, it must be deleted
◆ GLViewer_Group()
GLViewer_Group::GLViewer_Group ( )
constructor
References mySelObjNum.
◆ ~GLViewer_Group()
GLViewer_Group::~GLViewer_Group ( )
destructor
◆ addObject()
int GLViewer_Group::addObject ( GLViewer_Object *  theObject)
adding object to group
References contains(), count(), myList, and GLViewer_Object::setGroup().
◆ contains()
int GLViewer_Group::contains ( GLViewer_Object *  theObject)
the position of object if group contains it, else -1
References myList.
◆ count()
int GLViewer_Group::count ( )
number of elements
< TODO: conversion from size_t to int
References myList.
◆ dragingObjects()
void GLViewer_Group::dragingObjects ( float  x,
float  y,
bool  once = false
Dragging operation.
Once = true, if this operation calls only one time for all object
Dragging operation
Onceis true, if this operation calls only one time for all object
x,y- dragging position
References myList, and mySelObjNum.
◆ getObjects()
OGList GLViewer_Group::getObjects ( ) const
◆ isEmpty()
bool GLViewer_Group::isEmpty ( )
detection of empty group
References myList.
◆ removeObject()
int GLViewer_Group::removeObject ( GLViewer_Object *  theObject)
removing object from group
References count(), isEmpty(), myList, and ~GLViewer_Group().
◆ updateZoom()
void GLViewer_Group::updateZoom ( GLViewer_Object *  sender,
float  zoom
Warning
it is for ouv
Updates zoom of object
sender- object to be updated
zoom- zoom coefficient
References myList, and GLViewer_Object::setZoom().
◆ myList
OGList GLViewer_Group::myList
List of objects.
◆ mySelObjNum
int GLViewer_Group::mySelObjNum
