GLViewer_Drawer Class Referenceabstract
#include <GLViewer_Drawer.h>
Inheritance diagram for GLViewer_Drawer:
enum  {
  GLText_Center = 0 , GLText_Left , GLText_Right , GLText_Top ,
  GLText_Bottom
 Text position relatively object. More...
 GLViewer_Drawer ()
 A constructor. More...
virtual ~GLViewer_Drawer ()
 A destructor. More...
virtual void create (float xScale, float yScale, bool onlyUpdate)=0
 Main method which drawing object in GLViewer. More...
virtual void addObject (GLViewer_Object *theObject)
 Adds object to drawer display list. More...
virtual void clear ()
 Clears drawer display list. More...
QString getObjectType () const
 Returns object type (needs for dynamic search of right drawer ) More...
int getPriority () const
 Returns object priority. More...
void setAntialiasing (const bool on)
 The function enables and disables antialiasing in Open GL (for points, lines and polygons). More...
virtual bool translateToHPGL (QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aHPGLCS)
 A function translate object in to HPGL file on disk. More...
virtual bool translateToPS (QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aPSCS)
 A function translate object in to PostScript file on disk. More...
void drawTexture (GLuint texture, GLint size, GLfloat x, GLfloat y)
 Draw square texture. More...
void drawTexture (GLuint texture, GLint x_size, GLint y_size, GLfloat x, GLfloat y)
 Draw texture. More...
void drawTexturePart (GLuint texture, GLfloat x_ratio, GLfloat y_ratio, GLfloat x_size, GLfloat y_size, GLfloat x, GLfloat y, GLfloat scale=0)
 Draw texture part. More...
void drawText (const QString &text, GLfloat xPos, GLfloat yPos, const QColor &color, QFont *aFont, int theSeparator, DisplayTextFormat=DTF_BITMAP)
 Draw text string. More...
void drawGLText (QString text, float x, float y, int hPosition=GLText_Center, int vPosition=GLText_Center, QColor color=Qt::black, bool smallFont=false)
void setFont (const QFont &font)
 Sets a default font to be used by drawGLText method. More...
QFont font () const
 Returns a default font used by drawGLText method. More...
void setTextFormat (const DisplayTextFormat format)
 Sets a default text displaying format to be used by drawGLText method. More...
DisplayTextFormat textFormat () const
 Returns a default text displaying format used by drawGLText method. More...
void setTextScale (const GLfloat factor)
 Sets a text string displaying scale factor (used only with text format DTF_TEXTURE_SCALABLE) More...
GLfloat textScale () const
 Returns a text string displaying scale factor. More...
GLViewer_Rect textRect (const QString &) const
 Returns a rectangle of text (without viewer scale) More...
static void destroyAllTextures ()
 Clears all generated textures. More...
static GLuint loadTexture (const QString &fileName, GLint *x_size=0, GLint *y_size=0, GLint *t_size=0)
 Loads texture from file. More...
static void drawRectangle (GLViewer_Rect *theRect, QColor=Qt::black)
 Draw rectangle with predefined color. More...
virtual void drawText (GLViewer_Object *theObject)
 Draw object text. More...
static void drawRectangle (GLViewer_Rect *, GLfloat, GLfloat=0, QColor=Qt::black, bool=false, QColor=Qt::white)
 Draw basic primitives: rectangle, contour, polygon, vertex, cross, arrow. More...
static void drawContour (GLViewer_Rect *, QColor, GLfloat, GLushort, bool)
static void drawContour (const GLViewer_PntList &, QColor, GLfloat)
static void drawPolygon (GLViewer_Rect *, QColor, GLushort, bool)
static void drawPolygon (const GLViewer_PntList &, QColor)
static void drawVertex (GLfloat, GLfloat, QColor)
static void drawCross (GLfloat, GLfloat, QColor)
static void drawArrow (const GLfloat red, const GLfloat green, const GLfloat blue, GLfloat, GLfloat, GLfloat, GLfloat, GLfloat, GLfloat, GLfloat, GLboolean=GL_FALSE)
float myXScale
 X Scale factor. More...
float myYScale
 Y scale factor. More...
QList< GLViewer_Object * > myObjects
 List of objects. More...
GLuint myTextList
 List generated textures. More...
QString myObjectType
 Type of supporting object. More...
int myPriority
 Dislay priority. More...
QFont myFont
 Default font for drawGLText() method. More...
DisplayTextFormat myTextFormat
 Default text displaying format for drawGLText() method. More...
GLfloat myTextScale
 Scale factor for text string draw, by default 0.125 (used only with text format DTF_TEXTURE_SCALABLE) More...
Drawer for GLViewer_Objects. Drawer creates only one times per one type of object
◆ anonymous enum
anonymous enum
GLText_Center
GLText_Left
GLText_Right
GLText_Top
GLText_Bottom
◆ GLViewer_Drawer()
GLViewer_Drawer::GLViewer_Drawer ( )
A constructor.
Default constructor
References DTF_BITMAP, myObjects, myObjectType, myPriority, myTextFormat, myTextList, myTextScale, myXScale, and myYScale.
◆ ~GLViewer_Drawer()
GLViewer_Drawer::~GLViewer_Drawer ( )
A destructor.
Destructor
References myObjects, and myTextList.
◆ addObject()
virtual void GLViewer_Drawer::addObject ( GLViewer_Object *  theObject)
◆ clear()
virtual void GLViewer_Drawer::clear ( )
◆ create()
virtual void GLViewer_Drawer::create ( float  xScale,
float  yScale,
bool  onlyUpdate
pure virtual
Implemented in GLViewer_MarkerDrawer, GLViewer_PolylineDrawer, and GLViewer_TextDrawer.
◆ destroyAllTextures()
void GLViewer_Drawer::destroyAllTextures ( )
References GLViewer_TexFont::TexFontBase.
◆ drawArrow()
void GLViewer_Drawer::drawArrow ( const GLfloat  red,
const GLfloat  blue,
GLfloat  lineWidth,
GLfloat  staff,
GLfloat  length,
GLfloat  width,
GLfloat  x,
GLfloat  y,
GLfloat  angle,
GLboolean  filled = GL_FALSE
staticprotected
Draws arrow
red,green,blue- components of color
lineWidth- width of line
staff-
length- length of arrow
width- width of arrow
x- x position
y- y position
angle- angle of arrow
filled- drawn as filled
◆ drawContour() [1/2]
void GLViewer_Drawer::drawContour ( const GLViewer_PntList &  pntList,
QColor  color,
GLfloat  lineWidth
staticprotected
Draws contour
pntList- list of points
color- color of contour
References OCCViewer::color().
◆ drawContour() [2/2]
void GLViewer_Drawer::drawContour ( GLViewer_Rect *  rect,
QColor  color,
GLfloat  lineWidth,
GLushort  pattern,
bool  isStripe
staticprotected
Draws rectangular contour
rect- instance of rectangle
color- color of primitive
pattern- pattern of line
isStripe- enables line stipple
References GLViewer_Rect::bottom(), OCCViewer::color(), GLViewer_Rect::left(), GLViewer_Rect::right(), and GLViewer_Rect::top().
◆ drawCross()
void GLViewer_Drawer::drawCross ( GLfloat  x,
GLfloat  y,
QColor  color
staticprotected
Draws cross
x- x position
y- y position
color- color of cross
References OCCViewer::color(), and rasterCross.
◆ drawGLText()
void GLViewer_Drawer::drawGLText ( QString  text,
float  x,
float  y,
int  hPosition = GLText_Center,
int  vPosition = GLText_Center,
QColor  color = Qt::black,
bool  smallFont = false
Draw text string.
text- the text string
x- x coord
y- y coord
hPosition- horizontal alignment
vPosition- vertical alignment
color- text color
smallFont- font format
Draw text
x- x coord
y- y coord
color- text color
References OCCViewer::color(), drawText(), DTF_TEXTURE_SCALABLE, GLText_Bottom, GLText_Center, GLText_Left, GLText_Right, GLText_Top, myFont, myTextFormat, myXScale, myYScale, and textScale().
◆ drawPolygon() [1/2]
void GLViewer_Drawer::drawPolygon ( const GLViewer_PntList &  pntList,
QColor  color
staticprotected
Draws polygon
color- color of polygon
◆ drawPolygon() [2/2]
void GLViewer_Drawer::drawPolygon ( GLViewer_Rect *  rect,
QColor  color,
GLushort  pattern,
bool  isStripe
staticprotected
Draws rectangle
◆ drawRectangle() [1/2]
void GLViewer_Drawer::drawRectangle ( GLViewer_Rect *  rect,
GLfloat  lineWidth,
GLfloat  gap = 0,
bool  filled = false,
QColor  fillingColor = Qt::white
staticprotected
Draws rectangle
rect- instance of primitive
gap- gap of rectangle
filled- if it is true, then rectangle will be drawn filled with color "fillingColor"
fillingColor- color of filling
◆ drawRectangle() [2/2]
Draws rectangle
◆ drawText() [1/2]
void GLViewer_Drawer::drawText ( const QString &  text,
GLfloat  xPos,
GLfloat  yPos,
const QColor &  color,
QFont *  theFont,
int  theSeparator,
DisplayTextFormat  theFormat = DTF_BITMAP
Draw text string.
xPos- x coord
yPos- y coord
color- text color
aFont- base font of text
theSeparator- letter separator
DisplayTextFormat- text format
Draw text
text- text to be drawn
xPos- x position
yPos- y position
color- color of text
theFont- font of text
theFormat- text format (by default DTF_BITMAP)
References OCCViewer::color(), displayListBase(), GLViewer_TexFont::drawString(), DTF_BITMAP, DTF_TEXTURE_SCALABLE, GLViewer_TexFont::generateTexture(), and textScale().
◆ drawText() [2/2]
◆ drawTexture() [1/2]
void GLViewer_Drawer::drawTexture ( GLuint  texture,
GLint  size,
GLfloat  x,
GLfloat  y
texture- the texture ID
size- the size of square texture
x- x coord
y- y coord
Draw square texture
x- x coord
y- y coord
References drawTexture().
◆ drawTexture() [2/2]
GLint  x_size,
GLint  y_size,
GLfloat  x,
GLfloat  y
Draw texture.
x_size- the horizontal size of texture
y_size- the vertical size of texture
x- x coord
y- y coord
Draw texture
x- x coord
y- y coord
References drawTexturePart().
◆ drawTexturePart()
void GLViewer_Drawer::drawTexturePart ( GLuint  texture,
GLfloat  x_ratio,
GLfloat  y_ratio,
GLfloat  x_size,
GLfloat  y_size,
GLfloat  x,
GLfloat  y,
GLfloat  scale = 0
Draw texture part.
x_ratio- the horizontal ratio of texture part
y_ratio- the vertical ratio of texture part
x- x coord
y- y coord
scale- common scale factor ( if = 0, use drawer scales )
Draw texture part
x- x coord
y- y coord
References myXScale, and myYScale.
◆ drawVertex()
void GLViewer_Drawer::drawVertex ( GLfloat  x,
GLfloat  y,
QColor  color
staticprotected
Draws vertex
x- x position
y- y position
color- color of vertex
References OCCViewer::color(), and rasterVertex.
◆ font()
QFont GLViewer_Drawer::font ( ) const
◆ getObjectType()
QString GLViewer_Drawer::getObjectType ( ) const
◆ getPriority()
int GLViewer_Drawer::getPriority ( ) const
◆ loadTexture()
GLuint GLViewer_Drawer::loadTexture ( const QString &  fileName,
GLint *  x_size = 0,
GLint *  y_size = 0,
GLint *  t_size = 0
fileName- the name of texture file
x_size- the horizontal size of picture ( less or equal texture horizontal size )
y_size- the vertical size of picture ( less or equal texture vertical size )
t_size- the size of texture ( texture vertical size equals texture horizontal size )
◆ setAntialiasing()
void GLViewer_Drawer::setAntialiasing ( const bool  on)
Enables and disables antialiasing in Open GL (for points, lines and polygons).
on- if it is true, antialiasing is enabled
◆ setFont()
void GLViewer_Drawer::setFont ( const QFont &  font)
font- the default font
◆ setTextFormat()
void GLViewer_Drawer::setTextFormat ( const DisplayTextFormat  format)
format- the default text displaying format
◆ setTextScale()
void GLViewer_Drawer::setTextScale ( const GLfloat  factor)
factor- scale factor
◆ textFormat()
DisplayTextFormat GLViewer_Drawer::textFormat ( ) const
◆ textRect()
GLViewer_Rect GLViewer_Drawer::textRect ( const QString &  text) const
References DTF_TEXTURE_SCALABLE, myFont, myTextFormat, and textScale().
◆ textScale()
GLfloat GLViewer_Drawer::textScale ( ) const
◆ translateToHPGL()
bool GLViewer_Drawer::translateToHPGL ( QFile &  hFile,
GLViewer_CoordSystem *  aViewerCS,
GLViewer_CoordSystem *  aHPGLCS
hFilethe name of PostScript file chosen by user
aViewerCSthe GLViewer_CoordSystem of window
aHPGLCSthe GLViewer_CoordSystem of PostScript page
Saves object to file with format of HPGL
hFile- file
aViewerCS- viewer co-ordinate system
aHPGLCS- paper co-ordinate system
References myObjects.
◆ translateToPS()
bool GLViewer_Drawer::translateToPS ( QFile &  hFile,
GLViewer_CoordSystem *  aPSCS
aPSCSthe GLViewer_CoordSystem of PostScript page
Saves object to file with format of PostScript
hFile- file
aPSCS- paper co-ordinate system
◆ myFont
QFont GLViewer_Drawer::myFont
◆ myObjects
QList<GLViewer_Object*> GLViewer_Drawer::myObjects
List of objects.
◆ myObjectType
QString GLViewer_Drawer::myObjectType
◆ myPriority
int GLViewer_Drawer::myPriority
Dislay priority.
◆ myTextFormat
DisplayTextFormat GLViewer_Drawer::myTextFormat
◆ myTextList
GLuint GLViewer_Drawer::myTextList
◆ myTextScale
GLfloat GLViewer_Drawer::myTextScale
◆ myXScale
float GLViewer_Drawer::myXScale
X Scale factor.
◆ myYScale
float GLViewer_Drawer::myYScale
Y scale factor.
