GLViewer_MarkerDrawer Class Reference
#include <GLViewer_BaseDrawers.h>
Inheritance diagram for GLViewer_MarkerDrawer:
 GLViewer_MarkerDrawer ()
 ~GLViewer_MarkerDrawer ()
virtual void create (float, float, bool)
 Redefined method. More...
- Public Member Functions inherited from GLViewer_Drawer
 GLViewer_Drawer ()
 A constructor. More...
virtual ~GLViewer_Drawer ()
 A destructor. More...
virtual void create (float xScale, float yScale, bool onlyUpdate)=0
 Main method which drawing object in GLViewer. More...
virtual void addObject (GLViewer_Object *theObject)
 Adds object to drawer display list. More...
virtual void clear ()
 Clears drawer display list. More...
QString getObjectType () const
 Returns object type (needs for dynamic search of right drawer ) More...
int getPriority () const
 Returns object priority. More...
void setAntialiasing (const bool on)
 The function enables and disables antialiasing in Open GL (for points, lines and polygons). More...
virtual bool translateToHPGL (QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aHPGLCS)
 A function translate object in to HPGL file on disk. More...
virtual bool translateToPS (QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aPSCS)
 A function translate object in to PostScript file on disk. More...
void drawTexture (GLuint texture, GLint size, GLfloat x, GLfloat y)
 Draw square texture. More...
void drawTexture (GLuint texture, GLint x_size, GLint y_size, GLfloat x, GLfloat y)
 Draw texture. More...
void drawTexturePart (GLuint texture, GLfloat x_ratio, GLfloat y_ratio, GLfloat x_size, GLfloat y_size, GLfloat x, GLfloat y, GLfloat scale=0)
 Draw texture part. More...
void drawText (const QString &text, GLfloat xPos, GLfloat yPos, const QColor &color, QFont *aFont, int theSeparator, DisplayTextFormat=DTF_BITMAP)
 Draw text string. More...
void drawGLText (QString text, float x, float y, int hPosition=GLText_Center, int vPosition=GLText_Center, QColor color=Qt::black, bool smallFont=false)
void setFont (const QFont &font)
 Sets a default font to be used by drawGLText method. More...
QFont font () const
 Returns a default font used by drawGLText method. More...
void setTextFormat (const DisplayTextFormat format)
 Sets a default text displaying format to be used by drawGLText method. More...
DisplayTextFormat textFormat () const
 Returns a default text displaying format used by drawGLText method. More...
void setTextScale (const GLfloat factor)
 Sets a text string displaying scale factor (used only with text format DTF_TEXTURE_SCALABLE) More...
GLfloat textScale () const
 Returns a text string displaying scale factor. More...
GLViewer_Rect textRect (const QString &) const
 Returns a rectangle of text (without viewer scale) More...
void drawMarker (float &x, float &y, float &radius, QColor &color, GLViewer_AspectLine *aspect)
 Draws marker in point (x,y) of. More...
- Public Types inherited from GLViewer_Drawer
enum  {
  GLText_Center = 0 , GLText_Left , GLText_Right , GLText_Top ,
  GLText_Bottom
 Text position relatively object. More...
- Static Public Member Functions inherited from GLViewer_Drawer
static void destroyAllTextures ()
 Clears all generated textures. More...
static GLuint loadTexture (const QString &fileName, GLint *x_size=0, GLint *y_size=0, GLint *t_size=0)
 Loads texture from file. More...
static void drawRectangle (GLViewer_Rect *theRect, QColor=Qt::black)
 Draw rectangle with predefined color. More...
- Protected Member Functions inherited from GLViewer_Drawer
virtual void drawText (GLViewer_Object *theObject)
 Draw object text. More...
- Static Protected Member Functions inherited from GLViewer_Drawer
static void drawRectangle (GLViewer_Rect *, GLfloat, GLfloat=0, QColor=Qt::black, bool=false, QColor=Qt::white)
 Draw basic primitives: rectangle, contour, polygon, vertex, cross, arrow. More...
static void drawContour (GLViewer_Rect *, QColor, GLfloat, GLushort, bool)
static void drawContour (const GLViewer_PntList &, QColor, GLfloat)
static void drawPolygon (GLViewer_Rect *, QColor, GLushort, bool)
static void drawPolygon (const GLViewer_PntList &, QColor)
static void drawVertex (GLfloat, GLfloat, QColor)
static void drawCross (GLfloat, GLfloat, QColor)
static void drawArrow (const GLfloat red, const GLfloat green, const GLfloat blue, GLfloat, GLfloat, GLfloat, GLfloat, GLfloat, GLfloat, GLfloat, GLboolean=GL_FALSE)
- Protected Attributes inherited from GLViewer_Drawer
float myXScale
 X Scale factor. More...
float myYScale
 Y scale factor. More...
QList< GLViewer_Object * > myObjects
 List of objects. More...
GLuint myTextList
 List generated textures. More...
QString myObjectType
 Type of supporting object. More...
int myPriority
 Dislay priority. More...
QFont myFont
 Default font for drawGLText() method. More...
DisplayTextFormat myTextFormat
 Default text displaying format for drawGLText() method. More...
GLfloat myTextScale
 Scale factor for text string draw, by default 0.125 (used only with text format DTF_TEXTURE_SCALABLE) More...
Drawer for GLViewer_MarkerSet
◆ GLViewer_MarkerDrawer()
GLViewer_MarkerDrawer::GLViewer_MarkerDrawer ( )
Default constructor
References cos_table, GLViewer_Drawer::myObjectType, SEGMENTS, sin_table, and STEP.
◆ ~GLViewer_MarkerDrawer()
GLViewer_MarkerDrawer::~GLViewer_MarkerDrawer ( )
Destructor
◆ create()
void GLViewer_MarkerDrawer::create ( float  xScale,
float  yScale,
bool  onlyUpdate
◆ drawMarker()
void GLViewer_MarkerDrawer::drawMarker ( float &  theXCoord,
float &  theYCoord,
float &  theRadius,
QColor &  theColor,
GLViewer_AspectLine *  theAspectLine
radiuswith
colorand
aspect
Draws marker
theXCoord- X position
theYCoord- Y position
theRadius- radius
theColor- color
theAspectLine- line aspect
References cos_table, GLViewer_AspectLine::getLineType(), GLViewer_AspectLine::getLineWidth(), GLViewer_Drawer::myXScale, GLViewer_Drawer::myYScale, SEGMENTS, and sin_table.
