GLViewer_MarkerSet Class Reference
#include <GLViewer_BaseObjects.h>
Inheritance diagram for GLViewer_MarkerSet:
 GLViewer_MarkerSet (int number=1, float size=5.0, const QString &toolTip="GLMarker")
 A constructor. More...
 ~GLViewer_MarkerSet ()
 A destructor. More...
virtual void compute ()
virtual GLViewer_Drawer * createDrawer ()
virtual GLboolean highlight (GLfloat x, GLfloat y, GLfloat tol=15.0, GLboolean isCircle=GL_FALSE)
virtual GLboolean unhighlight ()
virtual GLboolean select (GLfloat x, GLfloat y, GLfloat tol, GLViewer_Rect rect, GLboolean isFull=GL_FALSE, GLboolean isCircle=GL_FALSE, GLboolean isShift=GL_FALSE)
virtual GLboolean unselect ()
virtual GLViewer_Rect * getUpdateRect ()
virtual void moveObject (float, float, bool fromGroup=false)
virtual QByteArray getByteCopy ()
virtual bool initializeFromByteCopy (QByteArray)
virtual bool translateToPS (QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aPSCS)
virtual bool translateToHPGL (QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aHPGLCS)
void setXCoord (GLfloat *xCoord, int size)
 Sets array of x coords of markers. More...
void setYCoord (GLfloat *yCoord, int size)
 Sets array of y coords of markers. More...
GLfloat * getXCoord () const
 Returns x coords. More...
GLfloat * getYCoord () const
 Returns y coords. More...
void setNumMarkers (GLint)
 Sets markers number. More...
GLint getNumMarkers () const
 returns markers number More...
void setMarkerSize (const float size)
 Sets merker radius. More...
float getMarkerSize () const
 Returns merker radius. More...
void exportNumbers (QList< int > &high, QList< int > &unhigh, QList< int > &sel, QList< int > &unsel)
 Export numbers of heghlighted/selected markers. More...
QList< int > getSelectedElements ()
 Returns selected numbers. More...
bool addOrRemoveSelected (int index)
 Adds or remove selected number. More...
void addSelected (const TColStd_SequenceOfInteger &)
 Adds selected numbers. More...
void setSelected (const TColStd_SequenceOfInteger &)
 Sets selected nembers. More...
- Public Member Functions inherited from GLViewer_Object
 GLViewer_Object ()
virtual ~GLViewer_Object ()
virtual void compute ()=0
 Main method. Computes all needed information about object for presentation in drawer. More...
virtual GLViewer_Drawer * createDrawer ()=0
 Creates correspond drawer. More...
virtual void setDrawer (GLViewer_Drawer *theDrawer)
 Installing already exist drawer with same type. More...
GLViewer_Drawer * getDrawer () const
 Returns current drawer. More...
virtual GLboolean highlight (GLfloat x, GLfloat y, GLfloat tol, GLboolean isCircle=GL_FALSE)=0
 Computes highlight presentation. More...
virtual GLboolean unhighlight ()=0
 Clears all highlight information. More...
virtual GLboolean select (GLfloat x, GLfloat y, GLfloat tol, GLViewer_Rect rect, GLboolean isFull=GL_FALSE, GLboolean isCircle=GL_FALSE, GLboolean isShift=GL_FALSE)=0
 Computes select presentation. More...
virtual GLboolean unselect ()=0
 Clears all select information. More...
virtual GLboolean isInside (GLViewer_Rect theRect)
 Returns if theRect inside object. More...
virtual bool portContains (GLViewer_Pnt)
virtual bool startPulling (GLViewer_Pnt)
virtual void pull (GLViewer_Pnt, GLViewer_Object *)
virtual void finishPulling ()
virtual bool isPulling ()
virtual GLViewer_Rect getPullingRect () const
virtual void setRect (GLViewer_Rect *rect)
 Installs object rectangle. More...
virtual GLViewer_Rect * getRect () const
 Returns object rectungle. More...
virtual GLViewer_Rect * getUpdateRect ()=0
 Returns update object rectangle. More...
virtual void setScale (GLfloat xScale, GLfloat yScale)
 Installs scale factors. More...
virtual void getScale (GLfloat &xScale, GLfloat &yScale) const
 Returns scale factors. More...
virtual GLboolean setZoom (GLfloat zoom, bool recompute, bool fromGroup=false)
virtual GLfloat getZoom () const
virtual GLboolean updateZoom (bool zoomIn)
virtual GLboolean isHighlighted () const
 Returns true if object is highlighted. More...
virtual GLboolean isSelected () const
 Returns true if object is selected. More...
virtual void setSelected (GLboolean state)
 Installs select status to object. More...
void setGLText (GLViewer_Text *glText)
 Installs GLText to object. More...
GLViewer_Text * getGLText () const
 Returns object GLText. More...
virtual void setAspectLine (GLViewer_AspectLine *aspect)
 Installs acpect line for object presentation. More...
virtual GLViewer_AspectLine * getAspectLine () const
 Returns acpect line of object presentation. More...
QString getObjectType () const
 Returns object type. More...
void setName (QString name)
 Installs object name. More...
QString getName () const
 Returns object name. More...
virtual int getPriority () const
 Returns object priority. More...
virtual void moveObject (float dx, float dy, bool fromGroup=false)=0
 Moves object per by recomputing. More...
virtual bool finishMove ()
 Finaly recomputing object after moving. More...
virtual bool getVisible () const
 Returns visible object status. More...
virtual void setVisible (bool theStatus)
 Installs visible object status. More...
void setToolTipText (QString str)
 Installs onject tool tip text. More...
virtual QString getToolTipText ()
 Returns onject tool tip text. More...
bool isTooTipHTML () const
 Returns true if tool tip contains HTML tags. More...
void setToolTipFormat (bool isHTML)
 Installs tool tip supporting of HTML tags. More...
 A function for coding object to the byte copy. More...
 A function for decoding object from the byte copy. More...
virtual bool translateToPS (QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aPSCS)=0
 A function translate object in to PostScript file on disk. More...
virtual bool translateToHPGL (QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aHPGLCS)=0
 A function translate object in to HPGL file on disk. More...
SUIT_DataOwner * owner () const
void setOwner (SUIT_DataOwner *owner)
void setGroup (GLViewer_Group *theGroup)
 Adds object to group theGroup. More...
GLViewer_Group * getGroup () const
 Returns object group. More...
virtual GLViewer_Object * getOwner ()
virtual bool isSelectable ()
 Returns true if object can be selected. More...
virtual bool isScalable ()
GLint myNumber
GLfloat * myXCoord
GLfloat * myYCoord
GLfloat myMarkerSize
QList< int > myHNumbers
QList< int > myUHNumbers
QList< int > mySelNumbers
QList< int > myCurSelNumbers
QList< int > myUSelNumbers
QList< int > myPrevHNumbers
TColStd_SequenceOfInteger mySelectedIndexes
- Protected Attributes inherited from GLViewer_Object
QString myName
 Object name. More...
QString myType
 Object type. More...
GLViewer_Rect * myRect
 Object base rect. More...
GLViewer_Rect * myUpdateRect
 Update object rect (after some viewer transformations) More...
GLViewer_Text * myGLText
 Object GLText. More...
GLfloat myXScale
 X scale factor. More...
GLfloat myYScale
 Y scale factor. More...
GLfloat myXGap
 Gap for X direction of rect. More...
GLfloat myYGap
 Gap for Y direction of rect. More...
GLfloat myZoom
GLboolean myIsHigh
 Highlight status. More...
GLboolean myIsSel
 Selectt status. More...
GLViewer_Drawer * myDrawer
 Object drawer. More...
GLViewer_AspectLine * myAspectLine
 Line aspect for object presentation. More...
QString myToolTipText
 Objet tool tip text. More...
bool isToolTipHTML
 HTML object tool tip status. More...
bool myIsVisible
 Object visibke status. More...
SUIT_DataOwner * myOwner
GLViewer_Group * myGroup
 Object Group. More...
OpenGL MarkerSet
◆ GLViewer_MarkerSet()
GLViewer_MarkerSet::GLViewer_MarkerSet ( int  number = 1,
float  size = 5.0,
const QString &  toolTip = "GLMarker"
◆ ~GLViewer_MarkerSet()
GLViewer_MarkerSet::~GLViewer_MarkerSet ( )
A destructor.
Destructor
References myXCoord, and myYCoord.
◆ addOrRemoveSelected()
bool GLViewer_MarkerSet::addOrRemoveSelected ( int  index)
index- selected index
References myNumber, mySelNumbers, and myUSelNumbers.
◆ addSelected()
void GLViewer_MarkerSet::addSelected ( const TColStd_SequenceOfInteger &  seq)
Adds some selected numbers
seq- sequence of indices
References mySelNumbers.
◆ compute()
void GLViewer_MarkerSet::compute ( )
◆ createDrawer()
GLViewer_Drawer * GLViewer_MarkerSet::createDrawer ( )
Creates corresponding drawer
Implements GLViewer_Object.
References GLViewer_Object::myDrawer.
◆ exportNumbers()
void GLViewer_MarkerSet::exportNumbers ( QList< int > &  highlight,
QList< int > &  unhighlight,
QList< int > &  select,
QList< int > &  unselect
Export numbers of highlighted/selected lines
References highlight(), myHNumbers, mySelNumbers, myUHNumbers, myUSelNumbers, select(), unhighlight(), and unselect().
◆ getByteCopy()
QByteArray GLViewer_MarkerSet::getByteCopy ( )
Codes marker set as byte copy
byte array
Reimplemented from GLViewer_Object.
References GLViewer_Object::getByteCopy(), myMarkerSize, myNumber, myXCoord, and myYCoord.
◆ getMarkerSize()
float GLViewer_MarkerSet::getMarkerSize ( ) const
◆ getNumMarkers()
GLint GLViewer_MarkerSet::getNumMarkers ( ) const
◆ getSelectedElements()
QList< int > GLViewer_MarkerSet::getSelectedElements ( )
◆ getUpdateRect()
◆ getXCoord()
GLfloat * GLViewer_MarkerSet::getXCoord ( ) const
Returns x coords.
◆ getYCoord()
GLfloat * GLViewer_MarkerSet::getYCoord ( ) const
Returns y coords.
◆ highlight()
GLboolean GLViewer_MarkerSet::highlight ( GLfloat  x,
GLfloat  y,
GLfloat  tol = 15.0,
GLboolean  isCircle = GL_FALSE
x- x coord
y- y coord
tol- tolerance of detecting
isCircle- true if sensitive area of detection is round
true if highlight status is changed
References myCurSelNumbers, myHNumbers, GLViewer_Object::myIsHigh, GLViewer_Object::myIsVisible, myMarkerSize, myNumber, myPrevHNumbers, myUHNumbers, myXCoord, GLViewer_Object::myXScale, myYCoord, and GLViewer_Object::myYScale.
◆ initializeFromByteCopy()
bool GLViewer_MarkerSet::initializeFromByteCopy ( QByteArray  theArray)
Initialize marker set by byte array
theArray- byte array
References GLViewer_Object::initializeFromByteCopy(), myCurSelNumbers, myHNumbers, myMarkerSize, myNumber, myPrevHNumbers, mySelNumbers, GLViewer_Object::myType, myUHNumbers, myUSelNumbers, myXCoord, and myYCoord.
◆ moveObject()
void GLViewer_MarkerSet::moveObject ( float  theX,
float  theY,
bool  fromGroup = false
Moves object by recomputing
dx- moving along X coord
dy- moving along Y coord
fromGroup- is true if this method called from group
References compute(), GLViewer_Group::dragingObjects(), GLViewer_Object::myGroup, myNumber, myXCoord, and myYCoord.
◆ select()
GLboolean GLViewer_MarkerSet::select ( GLfloat  x,
GLfloat  y,
GLfloat  tol,
GLViewer_Rect  rect,
GLboolean  isFull = GL_FALSE,
GLboolean  isCircle = GL_FALSE,
GLboolean  isShift = GL_FALSE
Selects marker set /param x, y - co-ordinates of mouse /param tol - tolerance /param rect - rectangle (in case of rectangular selection) /param isFull - if it is true, then object may selected only if it lays whole in selection zone
isShift- true if selection exec with append option
References myCurSelNumbers, myHNumbers, GLViewer_Object::myIsSel, GLViewer_Object::myIsVisible, myMarkerSize, myNumber, mySelNumbers, myUHNumbers, myUSelNumbers, myXCoord, GLViewer_Object::myXScale, myYCoord, and GLViewer_Object::myYScale.
◆ setMarkerSize()
void GLViewer_MarkerSet::setMarkerSize ( const float  size)
Sets merker radius.
◆ setNumMarkers()
void GLViewer_MarkerSet::setNumMarkers ( GLint  number)
Sets number of markers
number- new number of markers
References myNumber, myXCoord, and myYCoord.
◆ setSelected()
void GLViewer_MarkerSet::setSelected ( const TColStd_SequenceOfInteger &  seq)
Sets some numbers as selected
References mySelNumbers, and myUSelNumbers.
◆ setXCoord()
void GLViewer_MarkerSet::setXCoord ( GLfloat *  xCoord,
int  size
Sets array of x coords of points
xCoord- array of co-ordinates
size- array size
References myXCoord.
◆ setYCoord()
void GLViewer_MarkerSet::setYCoord ( GLfloat *  yCoord,
int  size
Sets array of y coords of points
yCoord- array of co-ordinates
size- array size
References myYCoord.
◆ translateToHPGL()
bool GLViewer_MarkerSet::translateToHPGL ( QFile &  hFile,
GLViewer_CoordSystem *  aViewerCS,
GLViewer_CoordSystem *  aHPGLCS
Saves to file HPGL set of markers
hFile- file instance
aViewerCS- viewer co-ordinates system
aHPGLCS- paper co-ordinates system
References AddCoordsToHPGL(), GLViewer_CoordSystem::getStretching(), myMarkerSize, myNumber, myXCoord, myYCoord, and PI.
◆ translateToPS()
bool GLViewer_MarkerSet::translateToPS ( QFile &  hFile,
GLViewer_CoordSystem *  aPSCS
Saves to file PostScript set of markers
aPSCS- paper co-ordinates system
References AddCoordsToPS(), AddLineAspectToPS(), GLViewer_Object::getAspectLine(), GLViewer_CoordSystem::getStretching(), myMarkerSize, myNumber, myXCoord, myYCoord, and PI.
◆ unhighlight()
GLboolean GLViewer_MarkerSet::unhighlight ( )
Unhilights object
References myHNumbers, myPrevHNumbers, and myUHNumbers.
◆ unselect()
GLboolean GLViewer_MarkerSet::unselect ( )
Unselects marker set
References myCurSelNumbers, mySelNumbers, and myUSelNumbers.
◆ myCurSelNumbers
QList<int> GLViewer_MarkerSet::myCurSelNumbers
◆ myHNumbers
QList<int> GLViewer_MarkerSet::myHNumbers
◆ myMarkerSize
GLfloat GLViewer_MarkerSet::myMarkerSize
◆ myNumber
GLint GLViewer_MarkerSet::myNumber
◆ myPrevHNumbers
QList<int> GLViewer_MarkerSet::myPrevHNumbers
◆ mySelectedIndexes
TColStd_SequenceOfInteger GLViewer_MarkerSet::mySelectedIndexes
◆ mySelNumbers
QList<int> GLViewer_MarkerSet::mySelNumbers
◆ myUHNumbers
QList<int> GLViewer_MarkerSet::myUHNumbers
◆ myUSelNumbers
QList<int> GLViewer_MarkerSet::myUSelNumbers
◆ myXCoord
GLfloat* GLViewer_MarkerSet::myXCoord
◆ myYCoord
GLfloat* GLViewer_MarkerSet::myYCoord
