GLViewer_Polyline Class Reference
#include <GLViewer_BaseObjects.h>
Inheritance diagram for GLViewer_Polyline:
 GLViewer_Polyline (int number=1, float size=5.0, const QString &toolTip="GLPolyline")
virtual ~GLViewer_Polyline ()
virtual void compute ()
virtual GLViewer_Drawer * createDrawer ()
virtual GLboolean highlight (GLfloat x, GLfloat y, GLfloat tol=15.0, GLboolean isCircle=GL_FALSE)
virtual GLboolean unhighlight ()
virtual GLboolean select (GLfloat x, GLfloat y, GLfloat tol, GLViewer_Rect rect, GLboolean isFull=GL_FALSE, GLboolean isCircle=GL_FALSE, GLboolean isShift=GL_FALSE)
virtual GLboolean unselect ()
virtual GLViewer_Rect * getUpdateRect ()
virtual void moveObject (float, float, bool fromGroup=false)
virtual QByteArray getByteCopy ()
virtual bool initializeFromByteCopy (QByteArray)
virtual bool translateToPS (QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aPSCS)
virtual bool translateToHPGL (QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aHPGLCS)
void setXCoord (GLfloat *xCoord, int size)
 Sets array of x coords of points. More...
void setYCoord (GLfloat *yCoord, int size)
 Sets array of y coords of points. More...
GLfloat * getXCoord () const
 Returns x coords. More...
GLfloat * getYCoord () const
 Returns y coords. More...
void setNumber (GLint)
 SetS number of points. More...
GLint getNumber () const
 Returns number of points. More...
void setClosed (GLboolean closed)
 On/off closed status of polyline. More...
GLboolean isClosed () const
 Checks closed status of polyline. More...
void setHighSelAll (GLboolean highSelAll)
 On/off highlight as whole object status. More...
GLboolean isHighSelAll () const
 Checks highlight as whole object status. More...
void exportNumbers (QList< int > &high, QList< int > &unhigh, QList< int > &sel, QList< int > &unsel)
 Export numbers of highlighted/selected lines. More...
QList< int > getSelectedElements ()
 Returns numbers of selected lines. More...
- Public Member Functions inherited from GLViewer_Object
 GLViewer_Object ()
 A constructor. More...
virtual ~GLViewer_Object ()
 A destructor. More...
virtual void compute ()=0
 Main method. Computes all needed information about object for presentation in drawer. More...
virtual GLViewer_Drawer * createDrawer ()=0
 Creates correspond drawer. More...
virtual void setDrawer (GLViewer_Drawer *theDrawer)
 Installing already exist drawer with same type. More...
GLViewer_Drawer * getDrawer () const
 Returns current drawer. More...
virtual GLboolean highlight (GLfloat x, GLfloat y, GLfloat tol, GLboolean isCircle=GL_FALSE)=0
 Computes highlight presentation. More...
virtual GLboolean unhighlight ()=0
 Clears all highlight information. More...
virtual GLboolean select (GLfloat x, GLfloat y, GLfloat tol, GLViewer_Rect rect, GLboolean isFull=GL_FALSE, GLboolean isCircle=GL_FALSE, GLboolean isShift=GL_FALSE)=0
 Computes select presentation. More...
virtual GLboolean unselect ()=0
 Clears all select information. More...
virtual GLboolean isInside (GLViewer_Rect theRect)
 Returns if theRect inside object. More...
virtual bool portContains (GLViewer_Pnt)
virtual bool startPulling (GLViewer_Pnt)
virtual void pull (GLViewer_Pnt, GLViewer_Object *)
virtual void finishPulling ()
virtual bool isPulling ()
virtual GLViewer_Rect getPullingRect () const
virtual void setRect (GLViewer_Rect *rect)
 Installs object rectangle. More...
virtual GLViewer_Rect * getRect () const
 Returns object rectungle. More...
virtual GLViewer_Rect * getUpdateRect ()=0
 Returns update object rectangle. More...
virtual void setScale (GLfloat xScale, GLfloat yScale)
 Installs scale factors. More...
virtual void getScale (GLfloat &xScale, GLfloat &yScale) const
 Returns scale factors. More...
virtual GLboolean setZoom (GLfloat zoom, bool recompute, bool fromGroup=false)
virtual GLfloat getZoom () const
virtual GLboolean updateZoom (bool zoomIn)
virtual GLboolean isHighlighted () const
 Returns true if object is highlighted. More...
virtual GLboolean isSelected () const
 Returns true if object is selected. More...
virtual void setSelected (GLboolean state)
 Installs select status to object. More...
void setGLText (GLViewer_Text *glText)
 Installs GLText to object. More...
GLViewer_Text * getGLText () const
 Returns object GLText. More...
virtual void setAspectLine (GLViewer_AspectLine *aspect)
 Installs acpect line for object presentation. More...
virtual GLViewer_AspectLine * getAspectLine () const
 Returns acpect line of object presentation. More...
QString getObjectType () const
 Returns object type. More...
void setName (QString name)
 Installs object name. More...
QString getName () const
 Returns object name. More...
virtual int getPriority () const
 Returns object priority. More...
virtual void moveObject (float dx, float dy, bool fromGroup=false)=0
 Moves object per by recomputing. More...
virtual bool finishMove ()
 Finaly recomputing object after moving. More...
virtual bool getVisible () const
 Returns visible object status. More...
virtual void setVisible (bool theStatus)
 Installs visible object status. More...
void setToolTipText (QString str)
 Installs onject tool tip text. More...
virtual QString getToolTipText ()
 Returns onject tool tip text. More...
bool isTooTipHTML () const
 Returns true if tool tip contains HTML tags. More...
void setToolTipFormat (bool isHTML)
 Installs tool tip supporting of HTML tags. More...
 A function for coding object to the byte copy. More...
 A function for decoding object from the byte copy. More...
virtual bool translateToPS (QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aPSCS)=0
 A function translate object in to PostScript file on disk. More...
virtual bool translateToHPGL (QFile &hFile, GLViewer_CoordSystem *aViewerCS, GLViewer_CoordSystem *aHPGLCS)=0
 A function translate object in to HPGL file on disk. More...
SUIT_DataOwner * owner () const
void setOwner (SUIT_DataOwner *owner)
void setGroup (GLViewer_Group *theGroup)
 Adds object to group theGroup. More...
GLViewer_Group * getGroup () const
 Returns object group. More...
virtual GLViewer_Object * getOwner ()
virtual bool isSelectable ()
 Returns true if object can be selected. More...
virtual bool isScalable ()
GLfloat * myXCoord
GLfloat * myYCoord
GLint myNumber
GLboolean myIsClosed
GLboolean myHighSelAll
QList< int > myHNumbers
QList< int > myUHNumbers
QList< int > mySelNumbers
QList< int > myUSelNumbers
QList< int > myCurSelNumbers
QList< int > myPrevHNumbers
TColStd_SequenceOfInteger mySelectedIndexes
GLboolean myHighFlag
- Protected Attributes inherited from GLViewer_Object
QString myName
 Object name. More...
QString myType
 Object type. More...
GLViewer_Rect * myRect
 Object base rect. More...
GLViewer_Rect * myUpdateRect
 Update object rect (after some viewer transformations) More...
GLViewer_Text * myGLText
 Object GLText. More...
GLfloat myXScale
 X scale factor. More...
GLfloat myYScale
 Y scale factor. More...
GLfloat myXGap
 Gap for X direction of rect. More...
GLfloat myYGap
 Gap for Y direction of rect. More...
GLfloat myZoom
GLboolean myIsHigh
 Highlight status. More...
GLboolean myIsSel
 Selectt status. More...
GLViewer_Drawer * myDrawer
 Object drawer. More...
GLViewer_AspectLine * myAspectLine
 Line aspect for object presentation. More...
QString myToolTipText
 Objet tool tip text. More...
bool isToolTipHTML
 HTML object tool tip status. More...
bool myIsVisible
 Object visibke status. More...
SUIT_DataOwner * myOwner
GLViewer_Group * myGroup
 Object Group. More...
OpenGL Polyline
◆ GLViewer_Polyline()
GLViewer_Polyline::GLViewer_Polyline ( int  number = 1,
float  size = 5.0,
const QString &  toolTip = "GLPolyline"
Constructor
number- number of segments
size- size of polyline
toolTip- tool tip of polyline
References myCurSelNumbers, myHighFlag, myHNumbers, myPrevHNumbers, mySelNumbers, GLViewer_Object::myToolTipText, GLViewer_Object::myType, myUHNumbers, myUSelNumbers, and setNumber().
◆ ~GLViewer_Polyline()
GLViewer_Polyline::~GLViewer_Polyline ( )
Destructor, destroys internal arrays of co-ordinates
References myXCoord, and myYCoord.
◆ compute()
void GLViewer_Polyline::compute ( )
Computes all necessary information about object for presentation in drawer
Implements GLViewer_Object.
References myNumber, GLViewer_Object::myRect, myXCoord, myYCoord, GLViewer_Rect::setBottom(), GLViewer_Rect::setLeft(), GLViewer_Rect::setRight(), and GLViewer_Rect::setTop().
◆ createDrawer()
GLViewer_Drawer * GLViewer_Polyline::createDrawer ( )
Creates corresponding drawer
References GLViewer_Object::myDrawer.
◆ exportNumbers()
void GLViewer_Polyline::exportNumbers ( QList< int > &  highlight,
QList< int > &  unhighlight,
QList< int > &  select,
QList< int > &  unselect
References highlight(), myHNumbers, mySelNumbers, myUHNumbers, myUSelNumbers, select(), unhighlight(), and unselect().
◆ getByteCopy()
QByteArray GLViewer_Polyline::getByteCopy ( )
Codes polyline as byte copy
byte array
Reimplemented from GLViewer_Object.
References GLViewer_Object::getByteCopy(), myHighSelAll, myIsClosed, myNumber, myXCoord, and myYCoord.
◆ getNumber()
GLint GLViewer_Polyline::getNumber ( ) const
◆ getSelectedElements()
QList< int > GLViewer_Polyline::getSelectedElements ( )
◆ getUpdateRect()
GLViewer_Rect * GLViewer_Polyline::getUpdateRect ( )
◆ getXCoord()
GLfloat * GLViewer_Polyline::getXCoord ( ) const
Returns x coords.
◆ getYCoord()
GLfloat * GLViewer_Polyline::getYCoord ( ) const
Returns y coords.
◆ highlight()
GLboolean GLViewer_Polyline::highlight ( GLfloat  x,
GLfloat  y,
GLfloat  tol = 15.0,
GLboolean  isCircle = GL_FALSE
x- x coord
y- y coord
tol- tolerance of detecting
isCircle- true if sensitive area of detection is round
true if highlight status is changed
References DISTANTION, myHighFlag, myIsClosed, GLViewer_Object::myIsHigh, GLViewer_Object::myIsVisible, myNumber, myXCoord, GLViewer_Object::myXScale, and myYCoord.
◆ initializeFromByteCopy()
bool GLViewer_Polyline::initializeFromByteCopy ( QByteArray  theArray)
◆ isClosed()
GLboolean GLViewer_Polyline::isClosed ( ) const
◆ isHighSelAll()
GLboolean GLViewer_Polyline::isHighSelAll ( ) const
◆ moveObject()
void GLViewer_Polyline::moveObject ( float  theX,
float  theY,
bool  fromGroup = false
Moves object by recomputing
dx- moving along X coord
dy- moving along Y coord
fromGroup- is true if this method called from group
References compute(), GLViewer_Group::dragingObjects(), GLViewer_Object::myGroup, myNumber, myXCoord, and myYCoord.
◆ select()
GLboolean GLViewer_Polyline::select ( GLfloat  x,
GLfloat  y,
GLfloat  tol,
GLViewer_Rect  rect,
GLboolean  isFull = GL_FALSE,
GLboolean  isCircle = GL_FALSE,
GLboolean  isShift = GL_FALSE
Selects polyline /param x, y - co-ordinates of mouse /param tol - tolerance /param rect - rectangle (in case of rectangular selection) /param isFull - if it is true, then object may selected only if it lays whole in selection zone
isShift- true if selection exec with append option
References DISTANTION, myHighFlag, myIsClosed, GLViewer_Object::myIsHigh, GLViewer_Object::myIsSel, GLViewer_Object::myIsVisible, myNumber, myXCoord, GLViewer_Object::myXScale, and myYCoord.
◆ setClosed()
void GLViewer_Polyline::setClosed ( GLboolean  closed)
◆ setHighSelAll()
void GLViewer_Polyline::setHighSelAll ( GLboolean  highSelAll)
◆ setNumber()
void GLViewer_Polyline::setNumber ( GLint  number)
Sets number of points
number- new number of points
References myNumber, myXCoord, and myYCoord.
◆ setXCoord()
void GLViewer_Polyline::setXCoord ( GLfloat *  xCoord,
int  size
Sets array of abscisses for points of polyline
xCoord- array of of abscisses
size- size of array
References myXCoord.
◆ setYCoord()
void GLViewer_Polyline::setYCoord ( GLfloat *  yCoord,
int  size
Sets array of ordinates for points of polyline
xCoord- array of of ordinates
size- size of array
References myYCoord.
◆ translateToHPGL()
bool GLViewer_Polyline::translateToHPGL ( QFile &  hFile,
GLViewer_CoordSystem *  aViewerCS,
GLViewer_CoordSystem *  aHPGLCS
Saves polyline to file HPGL
hFile- file instance
aViewerCS- viewer co-ordinates system
aHPGLCS- paper co-ordinates system
References AddCoordsToHPGL(), myIsClosed, myNumber, myXCoord, and myYCoord.
◆ translateToPS()
bool GLViewer_Polyline::translateToPS ( QFile &  hFile,
GLViewer_CoordSystem *  aPSCS
Saves polyline to file PostScript
aPSCS- paper co-ordinates system
References AddCoordsToPS(), AddLineAspectToPS(), GLViewer_Object::getAspectLine(), myIsClosed, myNumber, myXCoord, and myYCoord.
◆ unhighlight()
GLboolean GLViewer_Polyline::unhighlight ( )
Unhilights object
References GLViewer_Object::myIsHigh.
◆ unselect()
GLboolean GLViewer_Polyline::unselect ( )
Unselects polyline
References GLViewer_Object::myIsSel.
◆ myCurSelNumbers
QList<int> GLViewer_Polyline::myCurSelNumbers
◆ myHighFlag
GLboolean GLViewer_Polyline::myHighFlag
◆ myHighSelAll
GLboolean GLViewer_Polyline::myHighSelAll
◆ myHNumbers
QList<int> GLViewer_Polyline::myHNumbers
◆ myIsClosed
GLboolean GLViewer_Polyline::myIsClosed
◆ myNumber
GLint GLViewer_Polyline::myNumber
◆ myPrevHNumbers
QList<int> GLViewer_Polyline::myPrevHNumbers
◆ mySelectedIndexes
TColStd_SequenceOfInteger GLViewer_Polyline::mySelectedIndexes
◆ mySelNumbers
QList<int> GLViewer_Polyline::mySelNumbers
◆ myUHNumbers
QList<int> GLViewer_Polyline::myUHNumbers
◆ myUSelNumbers
QList<int> GLViewer_Polyline::myUSelNumbers
◆ myXCoord
GLfloat* GLViewer_Polyline::myXCoord
◆ myYCoord
GLfloat* GLViewer_Polyline::myYCoord
