GLViewer_Context Class Reference
#include <GLViewer_Context.h>
 GLViewer_Context (GLViewer_Viewer2d *)
 A constructor. More...
 ~GLViewer_Context ()
 A desructor. More...
void setUpdateAll (bool on)
 A function installing update flag in highlighting technology. More...
bool isUpdateAll () const
 Returns update flag in highlighting technology. More...
int MoveTo (int x, int y, bool byCircle=false)
 Main interactive method. Trace mouse in viewer window. More...
int Select (bool Append=false, bool byCircle=false)
int SelectByRect (const QRect &theRect, bool Append=false)
void SetHighlightColor (Quantity_NameOfColor aCol)
 A function installing highlight color for all presentation (does not work) More...
void SetSelectionColor (Quantity_NameOfColor aCol)
 A function installing select color for all presentation (does not work) More...
Quantity_NameOfColor HighlightColor ()
 Returns highlight color. More...
Quantity_NameOfColor SelectionColor ()
 Returns select color. More...
int NbSelected ()
 Returns number of objects in current selection. More...
void InitSelected ()
 A function set iterator of selected objects on first object. More...
bool MoreSelected ()
 Retuns true if iterator of selected objects is not set on last object. More...
bool NextSelected ()
 Increment of iterator of selected objects. More...
GLViewer_Object * SelectedObject ()
 Returns object corresponding the current iterator of selected objects. More...
bool isSelected (GLViewer_Object *theObject)
 Returns true if theObject is selected. More...
int insertObject (GLViewer_Object *theObject, bool display=false, bool isActive=true)
 Insert new object in context. More...
bool replaceObject (GLViewer_Object *oldObject, GLViewer_Object *newObject)
 Replacing objects in context. More...
void updateScales (GLfloat theX, GLfloat theY)
 A function updating scales of all objects in context. More...
void setTolerance (int tol)
 A function installing tolerance in window pixels for highlghting and selection methods. More...
const ObjList & getObjects (bool isActive=true)
 Returns list of context objects. More...
GLViewer_Object * getFirstObject ()
 Returns first active object. More...
void clearHighlighted (bool updateViewer)
 A function clear highlighted object information. More...
void clearSelected (bool updateViewer)
 A function clear selection object information. More...
void setSelected (GLViewer_Object *theObject, bool updateViewer)
 A function make theObject as selected object and update viewer if updateViewer = true. More...
void remSelected (GLViewer_Object *theObject, bool updateViewer)
 A function make theObject as unselected object and update viewer if updateViewer = true. More...
GLViewer_Object * getCurrentObject ()
 Returns highlighted object. More...
bool currentObjectIsChanged ()
 Returns true if after last MoveTo method calling highlight object is changed. More...
void eraseObject (GLViewer_Object *theObject, bool updateViewer=true)
 A function installing to theObject invisible status and update viewer if updateViewer = true. More...
void deleteObject (GLViewer_Object *theObject, bool updateViewer=true)
 A function remove theObject from context and update viewer if updateViewer = true. More...
bool setActive (GLViewer_Object *theObject)
 A function installing to theObject active status. More...
bool setInactive (GLViewer_Object *theObject)
 A function installing to theObject inactive status. More...
bool myUpdateAll
 Flag of updating viewer after highlight. More...
GLViewer_Viewer2d * myGLViewer2d
GLViewer_Object * myLastPicked
 Highlighted object. More...
bool myLastPickedChanged
 = true if after last MoveTo method calling highlight object is changed More...
ObjList myActiveObjects
 List of active object. More...
ObjList myInactiveObjects
 List of inactive object. More...
ObjList mySelectedObjects
 List of selected objects. More...
int mySelCurIndex
 Selected object iterator. More...
GLfloat myXhigh
 X coordinate of mouse cursor. More...
GLfloat myYhigh
 Y coordinate of mouse cursor. More...
Quantity_NameOfColor myHighlightColor
 Color for highlight. More...
Quantity_NameOfColor mySelectionColor
 Color for selection. More...
GLboolean myHFlag
 If = false - moveTo method is not any highlighting. More...
GLboolean mySFlag
 If = false - select method is not any select. More...
int myTolerance
 Tolerance in window pixels for highlghting and selection methods. More...
Class for manage of presentations in GLViewer
◆ GLViewer_Context()
GLViewer_Context::GLViewer_Context ( GLViewer_Viewer2d *  v)
A constructor.
Constructor
References myHFlag, myLastPicked, myLastPickedChanged, mySelCurIndex, mySFlag, and myUpdateAll.
◆ ~GLViewer_Context()
GLViewer_Context::~GLViewer_Context ( )
A desructor.
Destructor
References myActiveObjects, myInactiveObjects, and mySelectedObjects.
◆ clearHighlighted()
void GLViewer_Context::clearHighlighted ( bool  updateViewer)
Clears hilighting of objects
updateViewer- if it is true, viewer must be updated
References myGLViewer2d, myHFlag, myLastPicked, GLViewer_Object::unhighlight(), and GLViewer_Viewer2d::updateAll().
◆ clearSelected()
void GLViewer_Context::clearSelected ( bool  updateViewer)
Clears selection of objects
References GLViewer_Viewer2d::activateDrawers(), myGLViewer2d, mySelectedObjects, and mySFlag.
◆ currentObjectIsChanged()
bool GLViewer_Context::currentObjectIsChanged ( )
◆ deleteObject()
void GLViewer_Context::deleteObject ( GLViewer_Object *  theObject,
bool  updateViewer = true
Deletes object in
References GLViewer_Object::getGroup(), myActiveObjects, myGLViewer2d, myInactiveObjects, myLastPicked, mySelectedObjects, GLViewer_Group::removeObject(), and GLViewer_Viewer2d::updateAll().
◆ eraseObject()
void GLViewer_Context::eraseObject ( GLViewer_Object *  theObject,
bool  theUpdateViewer = true
Erases object in viewer
theUpdateViewer- if it is true, viewer must be updated
References myActiveObjects, myGLViewer2d, GLViewer_Object::setVisible(), GLViewer_Object::unhighlight(), GLViewer_Object::unselect(), and GLViewer_Viewer2d::updateAll().
◆ getCurrentObject()
GLViewer_Object * GLViewer_Context::getCurrentObject ( )
◆ getFirstObject()
GLViewer_Object * GLViewer_Context::getFirstObject ( )
◆ getObjects()
const ObjList & GLViewer_Context::getObjects ( bool  isActive = true)
active objects if isActive = true, else inactive objects
◆ HighlightColor()
Quantity_NameOfColor GLViewer_Context::HighlightColor ( )
◆ InitSelected()
void GLViewer_Context::InitSelected ( )
Inits iteration through selected objects
References mySelCurIndex.
◆ insertObject()
int GLViewer_Context::insertObject ( GLViewer_Object *  object,
bool  display = false,
theObject- inserting object
display- true if needs display object immediatly after inserting, else false
isActive- true if needs inserting object in active list
Inserts new object in context
theObject- object to be inserted
References GLViewer_Viewer2d::activateDrawer(), myActiveObjects, myGLViewer2d, and myInactiveObjects.
◆ isSelected()
bool GLViewer_Context::isSelected ( GLViewer_Object *  theObj)
true if object is selected
theObj- object to be checked
References mySelectedObjects.
◆ isUpdateAll()
bool GLViewer_Context::isUpdateAll ( ) const
◆ MoreSelected()
bool GLViewer_Context::MoreSelected ( )
Checks if iteration through selected objects may be continued
References mySelCurIndex, and NbSelected().
◆ MoveTo()
int GLViewer_Context::MoveTo ( int  xi,
int  yi,
bool  byCircle = false
x- X coord of mouse cursor
y- Y coord of mouse cursor \paran byCircle - true if needs round sensitive area around mouse cursor, else rectangle function search object rectangle which intersect with sensitive area and call object highlight method
Hiilights objects under cursor
byCircle- true if needs round sensitive area around mouse cursor, else rectangle function search object rectangle which intersect with sensitive area and call object highlight method
References GLViewer_Viewer2d::activateDrawers(), GLViewer_Rect::contains(), GLViewer_Object::highlight(), GLViewer_Object::isSelectable(), myActiveObjects, myGLViewer2d, myHFlag, myLastPicked, myLastPickedChanged, myTolerance, myUpdateAll, myXhigh, myYhigh, GLViewer_Viewer2d::transPoint(), GLViewer_Object::unhighlight(), and GLViewer_Viewer2d::updateAll().
◆ NbSelected()
int GLViewer_Context::NbSelected ( )
number of selected objects
◆ NextSelected()
bool GLViewer_Context::NextSelected ( )
Iterates to next selected object
◆ remSelected()
void GLViewer_Context::remSelected ( GLViewer_Object *  object,
bool  updateViewer
Unselects object, other selected objects are left as selected
References GLViewer_Viewer2d::activateDrawer(), myGLViewer2d, and mySelectedObjects.
◆ replaceObject()
bool GLViewer_Context::replaceObject ( GLViewer_Object *  oldObject,
GLViewer_Object *  newObject
Function search active and incative objects
Replaces object in context
oldObject- object to be replaced
newObject- object for replacing
References myActiveObjects, and myInactiveObjects.
◆ Select()
int GLViewer_Context::Select ( bool  Append = false,
A function selecting already highlighting object by calling object method select
Append- true if new selection will be append to existing selection, false - another
byCircle- true if needs round selection area in complex object
Selects already highlighting object by calling object method select
References GLViewer_Viewer2d::activateDrawer(), GLViewer_Viewer2d::activateDrawers(), GLViewer_Rect::contains(), GLViewer_Viewer::getActiveView(), GLViewer_ViewPort2d::getScale(), GLViewer_ViewFrame::getViewPort(), GLViewer_Object::isSelected(), myActiveObjects, myGLViewer2d, myHFlag, myLastPicked, mySelectedObjects, mySFlag, myTolerance, myUpdateAll, myXhigh, myYhigh, GLViewer_Object::select(), SS_GlobalChanged, SS_Invalid, SS_LocalChanged, SS_NoChanged, GLViewer_Object::unselect(), and GLViewer_Viewer2d::updateAll().
◆ SelectByRect()
int GLViewer_Context::SelectByRect ( const QRect &  theRect,
bool  Append = false
A function selecting objects on scene by rectangle
theRect- rectangle of selection
Append- true if new selection will be append to existing selection, false - another function search object rectangle which intersect with theRect and call object select method
Selects objects on scene by rectangle
References GLViewer_Viewer2d::activateDrawers(), GLViewer_Viewer::getActiveView(), GLViewer_Viewer2d::getGLVRect(), GLViewer_Viewer2d::getQRect(), GLViewer_ViewPort2d::getScale(), GLViewer_ViewFrame::getViewPort(), myActiveObjects, myGLViewer2d, mySelectedObjects, mySFlag, myTolerance, myUpdateAll, myXhigh, myYhigh, SS_GlobalChanged, SS_Invalid, SS_NoChanged, and GLViewer_Viewer2d::updateAll().
◆ SelectedObject()
GLViewer_Object * GLViewer_Context::SelectedObject ( )
current selected object (must be used only in cycle as "for( InitSelected(); MoreSelected(); NextSelected() ) {...}" )
References mySelCurIndex, and mySelectedObjects.
◆ SelectionColor()
Quantity_NameOfColor GLViewer_Context::SelectionColor ( )
◆ setActive()
bool GLViewer_Context::setActive ( GLViewer_Object *  theObject)
Installs active status to object
theObject
◆ SetHighlightColor()
void GLViewer_Context::SetHighlightColor ( Quantity_NameOfColor  aCol)
Sets color of hilighting
aCol- new color of highlighting
References myGLViewer2d, myHighlightColor, mySelectionColor, and GLViewer_Viewer2d::updateColors().
◆ setInactive()
bool GLViewer_Context::setInactive ( GLViewer_Object *  theObject)
Installs inactive status to object
theObject
◆ setSelected()
void GLViewer_Context::setSelected ( GLViewer_Object *  object,
bool  updateViewer
Selects object, other selected objects are left as selected
References GLViewer_Viewer2d::activateDrawer(), myActiveObjects, myGLViewer2d, and mySelectedObjects.
◆ SetSelectionColor()
void GLViewer_Context::SetSelectionColor ( Quantity_NameOfColor  aCol)
Sets color of selection
aCol- new color of selection
◆ setTolerance()
void GLViewer_Context::setTolerance ( int  tol)
◆ setUpdateAll()
void GLViewer_Context::setUpdateAll ( bool  on)
◆ updateScales()
void GLViewer_Context::updateScales ( GLfloat  scX,
GLfloat  scY
Updates scales of all objects in context
◆ myActiveObjects
ObjList GLViewer_Context::myActiveObjects
Active objects if consider in highlight and select methods
◆ myGLViewer2d
GLViewer_Viewer2d* GLViewer_Context::myGLViewer2d
◆ myHFlag
GLboolean GLViewer_Context::myHFlag
◆ myHighlightColor
Quantity_NameOfColor GLViewer_Context::myHighlightColor
◆ myInactiveObjects
ObjList GLViewer_Context::myInactiveObjects
Active objects isn't consider in highlight and select methods
◆ myLastPicked
GLViewer_Object* GLViewer_Context::myLastPicked
Highlighted object.
◆ myLastPickedChanged
bool GLViewer_Context::myLastPickedChanged
◆ mySelCurIndex
int GLViewer_Context::mySelCurIndex
◆ mySelectedObjects
ObjList GLViewer_Context::mySelectedObjects
◆ mySelectionColor
Quantity_NameOfColor GLViewer_Context::mySelectionColor
◆ mySFlag
GLboolean GLViewer_Context::mySFlag
◆ myTolerance
int GLViewer_Context::myTolerance
◆ myUpdateAll
bool GLViewer_Context::myUpdateAll
if = true, the viewer update all objects after change of highlight object, else - only highlight object
◆ myXhigh
GLfloat GLViewer_Context::myXhigh
◆ myYhigh
GLfloat GLViewer_Context::myYhigh
