LightApp_PreferencesDlg Class Reference
#include <LightApp_PreferencesDlg.h>
Inheritance diagram for LightApp_PreferencesDlg:
Signals
void defaultPressed ()
- Signals inherited from QtxDialog
void dlgButton (int)
 Emitted when the user button is clicked. More...
void dlgParamChanged ()
 This signal can be used in successor classes to signalize about some dialog parameter changing. More...
void dlgHelp ()
 Emitted when the "Help" button is clicked. More...
void dlgApply ()
 Emitted when the "Apply" button is clicked. More...
void dlgOk ()
 Emitted when the "OK" button is clicked. More...
void dlgNo ()
 Emitted when the "No" button is clicked. More...
void dlgYes ()
 Emitted when the "Yes" button is clicked. More...
void dlgClose ()
 Emitted when the "Close" button is clicked. More...
void dlgCancel ()
 Emitted when the "Cancel" button is clicked. More...
 LightApp_PreferencesDlg (LightApp_Preferences *, QWidget *=0)
virtual ~LightApp_PreferencesDlg ()
virtual void setVisible (bool visible)
virtual void accept ()
virtual void reject ()
bool isSaved ()
void setSaved (bool saved)
- Public Member Functions inherited from QtxDialog
 QtxDialog (QWidget *=0, bool=false, bool=false, const int=Standard, Qt::WindowFlags=0)
virtual ~QtxDialog ()
void setDialogFlags (const int)
 Set specified dialog box flags. More...
void clearDialogFlags (const int)
 Clear specified the dialog flags. More...
bool testDialogFlags (const int) const
 Test specified dialog flags. More...
void setButtonFlags (const int)
 Add specified control button(s) to the dialog box. More...
void clearButtonFlags (const int)
 Remove specified control button(s) from the dialog box. More...
bool testButtonFlags (const int) const
 Test specified buttons. More...
int buttonPosition (const int) const
 Get specified control button position. More...
void setButtonPosition (const int, const int=-1)
 Set the specified control button(s) position. More...
void setPlacePosition (const int, const int)
 Set button position for all buttons in specified area. More...
int placePolicy (const int) const
 Get buttons layouting policy for the specified area. More...
void setPlacePolicy (const int, const int)
 set buttons layouting policy for the specified area. More...
void setButtonPlace (const int, const int)
 Move specified button(s) into specified area. More...
QString buttonText (const int)
 Get specified button's text. More...
void setButtonText (const int, const QString &text)
 Set specified button's text. More...
void setButtonFocus (const int)
 Sets the keyboard focus to the specified button. More...
bool hasButtonFocus (const int) const
 Check if specified button has keyboard focus. More...
bool isButtonEnabled (const int) const
 Get "enabled" status of the specified button(s). More...
void setButtonEnabled (const bool, const int)
 Enable/disable specified button(s). More...
bool isBorderEnabled (const int) const
 Check if border is enabled. More...
void setBorderEnabled (const bool, const int)
 Show/hide border for the specified button area. More...
void removeButton (const int)
 Remove user button. More...
int insertButton (const QString &, const int=BottomArea)
 Add user button to the dialog box. More...
QIntList userButtonIds () const
 Get all user button IDs. More...
QAbstractButton * userButton (const int) const
 Get user button by the specified id. More...
uint setAlignment (uint align)
 Sets alignment policy. More...
Private Slots
void onHelp ()
void onApply ()
void onDefault ()
void onImportPref ()
void onRestartRequired ()
LightApp_Preferences * myPrefs
bool mySaved
- Public Types inherited from QtxDialog
enum  PlacePolicy { Position , Expand , Uniform }
 Buttons alignment type. More...
enum  ButtonArea { TopArea , BottomArea , LeftArea , RightArea }
 Buttons area. More...
enum  ButtonPosition {
  Left , Right , Center , Top = Left ,
  Bottom = Right
 Button position. More...
enum  ButtonFlags {
  None = 0x00000000 , OK = 0x00000001 , Apply = 0x00000002 , Cancel = 0x00000004 ,
  Yes = 0x00000008 , No = 0x00000010 , Close = 0x00000020 , Help = 0x00000040 ,
  OKCancel = OK | Cancel , YesNo = Yes | No , Standard = OK | Cancel | Help , All = Standard | YesNo | Apply | Close
 Button ID flags. More...
enum  DialogFlags { Accept = 0x000001 , Reject = 0x000002 , AlignOnce = 0x000004 , SetFocus = 0x000008 }
 Dialog box flags. More...
- Public Slots inherited from QtxDialog
void update ()
 Update dialog box. More...
virtual void setVisible (bool)
 Show/hide dialog box, set keyboard focus to the dialog. More...
- Static Public Member Functions inherited from QtxDialog
static void setUnits (QLabel *, const QString &)
 Set measure units to the specified label. More...
- Protected Types inherited from QtxDialog
typedef QMap< int, QAbstractButton * > ButtonMap
 button map More...
- Protected Slots inherited from QtxDialog
 Accept the dialog box. More...
 Reject the dialog box. More...
- Protected Member Functions inherited from QtxDialog
QFrame * mainFrame () const
 Get dialog box main frame widget. More...
virtual bool acceptData () const
 Check if data entered by the user is valid. More...
virtual bool rejectData () const
 Check if dialog box can be cancelled. More...
virtual QAbstractButton * createButton (QWidget *)
 Create new user button. More...
QAbstractButton * button (const int) const
 Get button by the specified ID. More...
ButtonMap buttons (const int=All) const
 Get buttons by the specified IDs. More...
int buttonId (const QAbstractButton *) const
 Get specified button's identifier. More...
int buttonPosition (QAbstractButton *) const
 Get position of specified button. More...
virtual void showEvent (QShowEvent *)
 Align this dialog according to the parent widget and alignment policy before the dialog box is shown. More...
virtual void hideEvent (QHideEvent *)
 Process all existing events when dialog box is hidden. More...
virtual void closeEvent (QCloseEvent *)
 Called when user closes dialog box. More...
virtual void childEvent (QChildEvent *)
 Update dialog box layout when the size grip is added. More...
virtual void keyPressEvent (QKeyEvent *)
 Process key pressing event. More...
Dialog for preferences edition
◆ LightApp_PreferencesDlg()
◆ ~LightApp_PreferencesDlg()
LightApp_PreferencesDlg::~LightApp_PreferencesDlg ( )
References QtxDialog::mainFrame(), and myPrefs.
◆ accept()
void LightApp_PreferencesDlg::accept ( )
Store preferences on accept.
Reimplemented from QtxDialog.
References QtxDialog::accept(), myPrefs, mySaved, and QtxPreferenceMgr::store().
◆ defaultPressed
void LightApp_PreferencesDlg::defaultPressed ( )
signal
◆ isSaved()
bool LightApp_PreferencesDlg::isSaved ( )
◆ onApply
void LightApp_PreferencesDlg::onApply ( )
privateslot
◆ onDefault
◆ onHelp
void LightApp_PreferencesDlg::onHelp ( )
privateslot
◆ onImportPref
void LightApp_PreferencesDlg::onImportPref ( )
privateslot
◆ onRestartRequired
void LightApp_PreferencesDlg::onRestartRequired ( )
privateslot
Called if some preferences that will come in force only after application restart are changed
References SUIT_MessageBox::information().
◆ reject()
void LightApp_PreferencesDlg::reject ( )
Reject. Restore preferences from backup.
References QtxPreferenceMgr::fromBackup(), myPrefs, and QtxDialog::reject().
◆ setSaved()
void LightApp_PreferencesDlg::setSaved ( bool  saved)
◆ setVisible()
void LightApp_PreferencesDlg::setVisible ( bool  visible)
◆ myPrefs
LightApp_Preferences* LightApp_PreferencesDlg::myPrefs
◆ mySaved
bool LightApp_PreferencesDlg::mySaved
