LightApp_SwitchOp Class Reference
This class is intended for controling switching between operation. More...
#include <LightApp_SwitchOp.h>
Inheritance diagram for LightApp_SwitchOp:
 LightApp_SwitchOp (LightApp_Module *)
virtual ~LightApp_SwitchOp ()
bool eventFilter (QObject *, QEvent *)
 Event filter. More...
LightApp_Module * module () const
 Get module. More...
LightApp_Operation * operation (QWidget *) const
 Get operation by widget. More...
SUIT_Study * study () const
 Get study. More...
LightApp_Module * myModule
Several operation may be launched simultaneously. This class is intended for controlling switching between such operations. This class works with operations having dialogs (activation of other operations is performed by SUIT_Study). When several operations is launched simultaneously corresponding dialogs are shown on the screen. Only one operation from the launched ones can be active (active operation). Other operations are suspended. As result only one dialog from shown ones can be active too. Other dialogs are disabled. This class installs event filter on application. When mouse cursor is moved above disabled dialog corresponding event is catched by this class. It finds corresponding operation and verify whether operation can be resumed (see SUIT_Study::isDenied( SUIT_Operation* ) method). If yes then current active operation is suspended and new operation activated. Module contains this class as a field. Then module is created instance of this class created too.
◆ LightApp_SwitchOp()
LightApp_SwitchOp::LightApp_SwitchOp ( LightApp_Module *  theModule)
theParent- parent of object
Creates instance of the object. Connects signals and slots. Install eveny filter on application
◆ ~LightApp_SwitchOp()
LightApp_SwitchOp::~LightApp_SwitchOp ( )
◆ eventFilter()
bool LightApp_SwitchOp::eventFilter ( QObject *  theObj,
QEvent *  theEv
Event filter.
theObj- object
theEv- event
Event filter. Catched signals off application. If event concerns to dialog then corresponding operation is found and activated.
References SUIT_Operation::isActive(), LightApp_Operation::isAutoResumed(), operation(), SUIT_Study::resume(), and study().
◆ module()
LightApp_Module * LightApp_SwitchOp::module ( ) const
Get module.
Get module. Module is a parent of this class
References myModule.
◆ operation()
LightApp_Operation * LightApp_SwitchOp::operation ( QWidget *  theWg) const
theWg- key widget to find operation
Pointer to the operations if it is found or zero
Find operation containing dialog with given widget
References study().
◆ study()
SUIT_Study * LightApp_SwitchOp::study ( ) const
Get study.
Active study of application (in current realisation)
Get study
References SUIT_Application::activeStudy(), CAM_Module::application(), and module().
◆ myModule
LightApp_Module* LightApp_SwitchOp::myModule
