QDS_ComboBox Class Reference
#include <QDS_ComboBox.h>
Inheritance diagram for QDS_ComboBox:
Signals
void activated (int)
 Emitted when the current item in the combo box is changed. More...
void activated (const QString &)
- Signals inherited from QDS_Datum
void paramChanged ()
 The signal is emitted when the datum value is changed. More...
void paramChanged (QString &)
 QDS_ComboBox (const QString &, QWidget *=0, const int=All, const QString &=QString())
virtual ~QDS_ComboBox ()
bool editable () const
 Check if combo box allows text editing. More...
void setEditable (const bool)
 Enable/disable text editing. More...
int count (bool=false) const
 Get number of items in the combo box. More...
void values (QList< int > &, bool=false) const
 Get items identifiers. More...
virtual int integerValue () const
 Get the current item ID as integer value. More...
virtual double doubleValue () const
 Get the current item ID as double value. More...
virtual void setIntegerValue (const int)
 Set the current item acording to the specified id. More...
virtual void setDoubleValue (const double)
 Set the current item acording to the specified id. This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.Integer part of val is used as new current ID. More...
bool state (const int) const
 Get visibility state of the item specified by id. More...
void setState (const bool, const int, const bool=true)
 Set the visibility state of the item specified by id. More...
void setState (const bool, const QList< int > &, const bool=true)
 Set the visibility state of items specified by ids. More...
void setValues (const QList< int > &, const QStringList &)
 Set the custom user items into the combo box. More...
void setValues (const QStringList &)
 Set the custom user items into the combo box. This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.User items like standard dictionary list items will be added into the combobox. This function allows user to override items. More...
virtual QString getString () const
 Get string from the combo box. More...
virtual void reset ()
 Reset the datum. More...
int stringToValue (const QString &) const
 Convert string to integer value. More...
QString valueToString (const int) const
 Convert integer to string value. More...
- Public Member Functions inherited from QDS_Datum
 QDS_Datum (const QString &, QWidget *=0, const int=All, const QString &=QString())
virtual ~QDS_Datum ()
QString id () const
 Get the datum ID. More...
int type () const
 Get the datum value type. More...
QString label () const
 Get the datum label text. More...
QString units () const
 Get the datum units text. More...
QString filter () const
 Get the datum filter string. More...
QString format () const
 Get the datum format string. More...
QString longDescription () const
 Get the datum long description. More...
QString shortDescription () const
 Get the datum short description. More...
QString defaultValue () const
 Get the datum default value. More...
QString minimumValue () const
 Get the datum minimum value. More...
QString maximumValue () const
 Get the datum maximum value. More...
QStringList options () const
 Get the datum options names. More...
 Get datum option specified by name as QVariant. More...
QString optionString (const QString &) const
 Get datum option specified by name as string. More...
double optionDouble (const QString &) const
 Get datum option specified by name as double. More...
int optionInteger (const QString &) const
 Get datum option specified by name as integer. More...
virtual QVariant value () const
 Get the datum value as QVariant. More...
virtual QString stringValue () const
 Get the datum value as string. More...
 Get the datum value as double. More...
 Get the datum value as integer. More...
QString text () const
 Get the text data from datum. More...
virtual bool isEmpty () const
 Check if the datum is empty. More...
 Reset datum state and set default value as current. More...
virtual void clear ()
 Clear the control. More...
virtual void setValue (const QVariant &)
 Set datum value from QVariant object. More...
virtual void setStringValue (const QString &)
 Set datum value from string data. More...
 Set datum value from double data. More...
 Set datum value from integer data. More...
virtual bool isEnabled (const int=Control) const
 Get 'enabled' state of the specified subwidget. More...
virtual void setEnabled (const bool, const int)
 Enable/disable subwidgets specified by element. More...
void show (const int=All)
 Show subwidgets specified by element. More...
void hide (const int=All)
 Hide subwidgets specified by element. More...
virtual void setShown (const bool, const int=All)
 Show/hide subwidgets specified by flags. More...
QWidget * widget (const int) const
 Get subwidget specified by element. More...
void setFocus ()
 Set the input focus to the control widget. More...
virtual bool isValid (const bool=true, const QString &=QString(), const QString &=QString()) const
 Check if input data is valid. More...
virtual QValidator * validator (const bool=false) const
 Create validator according to the datum type of value. More...
void addTo (QVBoxLayout *)
 Add widgets to the vertical box layout. More...
void addTo (QHBoxLayout *)
 Add widgets to the horizontal box layout. More...
void addTo (QGridLayout *, const int, const int, const bool=false)
 Add widgets to the grid layout. More...
virtual void setAlignment (const int, const int=Label)
 Set the aligment for QDS::Label and/or QDS::Units subwidgets. More...
virtual QString getString () const =0
 Get string value from datum. More...
 Event filter. More...
 operator QWidget * () const
 Overloaded operator used to retrieve main subwidget named QDS::Control. More...
bool isCustomTr () const
 Return state of custom translation. More...
void enableCustomTr (const bool)
 Change state of custom translation. More...
Protected Slots
virtual void onActivated (int)
 Called when combo box item is activated. More...
virtual void onTextChanged (const QString &)
 Called when text in the combo box (editable) is modified by the user. More...
- Protected Slots inherited from QDS_Datum
virtual void onParamChanged ()
 Called when datum value is changed. More...
QtxComboBox * comboBox () const
 Get combo box widget. More...
virtual QWidget * createControl (QWidget *)
 Create internal combo box as control widget. More...
virtual void setString (const QString &)
 Set the string value to the combo box widget. More...
virtual void unitSystemChanged (const QString &)
 Process notification about active units system changing. More...
- Protected Member Functions inherited from QDS_Datum
QLabel * labelWidget () const
 Get QDS::Label widget. More...
QLabel * unitsWidget () const
 Get QDS::Units widget. More...
QWidget * controlWidget () const
 Get QDS::Control widget. More...
 Handle (DDS_DicItem) dicItem() const
void setDicItem (const Handle(DDS_DicItem)&)
int flags () const
 Get datum flags. More...
void invalidateCache ()
 Reset the numeric value cache. More...
virtual QLabel * createLabel (QWidget *)
 Create QDS::Label widget. More...
virtual QLabel * createUnits (QWidget *)
 Create QDS::Units widget. More...
virtual QWidget * createControl (QWidget *)=0
 Create QDS::Control widget. More...
virtual void setString (const QString &)=0
virtual bool validate (const QString &) const
 Validate the specified string. More...
QString prefix () const
 Get prefix string from format. More...
QString suffix () const
 Get suffix string from format. More...
virtual QString minValue () const
 Get minimum value. More...
virtual QString maxValue () const
 Get maximum value. More...
void initDatum () const
 Perform initialization if it needed. More...
Private Types
typedef QMap< int, QPixmap > IdIconsMap
typedef QMap< int, QString > IdValueMap
typedef QMap< int, bool > IdStateMap
typedef QMap< int, int > IdIndexMap
int getId (const int) const
 Get item identifier according to the specified index. More...
int getId (const QString &) const
 Get item identifier. More...
int getIndex (const int) const
 Get index of the combo box item according to its identifier. More...
int getIndex (const QString &) const
 Get index of the combo box item. More...
void updateComboBox ()
 Update combo box. More...
IdValueMap myValue
IdStateMap myState
IdIndexMap myIndex
IdIconsMap myIcons
QIntList myDataIds
QIntList myUserIds
QStringList myUserNames
- Public Types inherited from QDS
enum  DatumFlags {
  None = 0x00 , Label = 0x01 , Control = 0x02 , Units = 0x04 ,
  NotFormat = 0x08 , NotAccel = 0x10 , NotConvert = 0x20 , UnitsWithLabel = 0x40 ,
  All = Label | Control | Units
 Enum describes bit flags of the Qt datum view and behaviour. More...
- Public Slots inherited from QDS_Datum
void setEnabled (bool)
 Enable/disable main control subwidget (QDS::Control). More...
- Static Public Member Functions inherited from QDS_Datum
static QString unitsToText (const QString &)
 Convert units into text presentation. More...
static QString textToUnits (const QString &)
 Convert text presentation into internal units format. More...
static QString format (const QString &, const QString &, const bool=false)
 Format the specified string as dictionary item value. More...
static QString format (const int, const QString &, const bool=false)
 Format the specified integer as dictionary item value. More...
static QString format (const double, const QString &, const bool=false)
 Format the specified double as dictionary item value. More...
static QString units (const QString &)
 Get displayable units string for specified data dictionary item. More...
static bool load (const QString &)
 Load datum definitions from XML file dictPath to the dictionary. More...
static QString unitSystemLabel (const QString &, const QString &=QString())
 Get the label of unit system sys. More...
static QString activeUnitSystem (const QString &=QString())
 Get the name of active unit system from the specified component comp. More...
static void setActiveUnitSystem (const QString &, const QString &=QString())
 Set the active unit system. More...
static QString toQString (const TCollection_AsciiString &)
 Convert the OpenCascade ASCII string to Qt string. More...
static QString toQString (const TCollection_ExtendedString &)
 Convert the OpenCascade Unicode string to Qt string. More...
static QString toQString (const Handle(TCollection_HAsciiString)&)
static QString toQString (const Handle(TCollection_HExtendedString)&)
static TCollection_AsciiString toAsciiString (const QString &)
 Convert the Qt string to OpenCascade ASCII string. More...
static TCollection_AsciiString toAsciiString (const TCollection_ExtendedString &)
 Convert the OpenCascade Unicode string to OpenCascade ASCII string. More...
static TCollection_AsciiString toAsciiString (const Handle(TCollection_HExtendedString)&)
static TCollection_ExtendedString toExtString (const QString &)
 Convert the Qt string to OpenCascade Unicode string. More...
static TCollection_ExtendedString toExtString (const TCollection_AsciiString &)
 Convert the OpenCascade ASCII string to OpenCascade Unicode string. More...
- Static Protected Member Functions inherited from QDS_Datum
static QString format (const QString &, const int, const int)
 Format the given value according to the data dictionary item type. More...
static QString format (const QString &, const int, const double)
static QString format (const QString &, const int, const QString &)
static QString sprintf (const QString &, const int)
 Wrapper around the standard sprintf() function. More...
static QString sprintf (const QString &, const double)
 Wrapper around the standard sprintf() function. This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.Process some non standard flags from format string. More...
static QString sprintf (const QString &, const QString &)
static void insertDatum (QDS_Datum *)
 Register given datum datum in the global list. More...
static void removeDatum (QDS_Datum *)
 Remove given datum datum from the global list. More...
◆ IdIconsMap
typedef QMap<int, QPixmap> QDS_ComboBox::IdIconsMap
◆ IdIndexMap
typedef QMap<int, int> QDS_ComboBox::IdIndexMap
◆ IdStateMap
typedef QMap<int, bool> QDS_ComboBox::IdStateMap
◆ IdValueMap
typedef QMap<int, QString> QDS_ComboBox::IdValueMap
◆ QDS_ComboBox()
QDS_ComboBox::QDS_ComboBox ( const QString &  id,
QWidget *  parent = 0,
const int  flags = All,
const QString &  comp = QString()
Create combobox datum object with datum identifier id and parent widget parent.
Parameter flags defines behaviour of datum and set of created subwidgets. Default value of this parameter is QDS::All.
Parameter comp specifies the component name which will be used when searching the dictionary item.
iddatum identifier
parentparent widget
flagsdatum flags
compcomponent
◆ ~QDS_ComboBox()
QDS_ComboBox::~QDS_ComboBox ( )
◆ activated [1/2]
void QDS_ComboBox::activated ( const QString &  txt)
signal
txtcurrent item text
◆ activated [2/2]
void QDS_ComboBox::activated ( int  id)
signal
idcurrent item ID
◆ comboBox()
QtxComboBox * QDS_ComboBox::comboBox ( ) const
internal combo box widget
References QDS_Datum::controlWidget().
◆ count()
int QDS_ComboBox::count ( bool  total = false) const
totalif false, only visible items are taken into account, otherwise get total number of items
number of items
References comboBox(), and myValue.
◆ createControl()
QWidget * QDS_ComboBox::createControl ( QWidget *  parent)
parentparent widget
created combo box widget
Implements QDS_Datum.
References activated(), onActivated(), and onTextChanged().
◆ doubleValue()
double QDS_ComboBox::doubleValue ( ) const
current item ID converted to double
Reimplemented from QDS_Datum.
References comboBox(), getId(), getString(), and QDS_Datum::initDatum().
◆ editable()
bool QDS_ComboBox::editable ( ) const
true if combo box is editable
References comboBox().
◆ getId() [1/2]
int QDS_ComboBox::getId ( const int  idx) const
idxitem index
item ID or -1 if index is out of range
References QDS_Datum::id(), and myIndex.
◆ getId() [2/2]
int QDS_ComboBox::getId ( const QString &  str) const
strcombo box item
item ID or -1 if not found
References QDS_Datum::id(), myValue, and state().
◆ getIndex() [1/2]
int QDS_ComboBox::getIndex ( const int  id) const
iditem ID
item index or -1 if not found
◆ getIndex() [2/2]
int QDS_ComboBox::getIndex ( const QString &  str) const
strcombo box item
◆ getString()
QString QDS_ComboBox::getString ( ) const
string value
References comboBox(), and QtxComboBox::isCleared().
◆ integerValue()
int QDS_ComboBox::integerValue ( ) const
current item ID converted to integer
References comboBox(), getId(), and getString().
◆ onActivated
void QDS_ComboBox::onActivated ( int  idx)
protectedvirtualslot
idxindex of teh item being activated
References activated(), comboBox(), getId(), getString(), QDS_Datum::onParamChanged(), and QDS_Datum::paramChanged().
◆ onTextChanged
void QDS_ComboBox::onTextChanged ( const QString &  )
txtcurrent text in the combo box editor (not used)
References getString(), QDS_Datum::onParamChanged(), and QDS_Datum::paramChanged().
◆ reset()
void QDS_ComboBox::reset ( )
Reset the datum.
Set the active item as item with default ID. If default ID is not defined then the first item is used.
References QDS_Datum::defaultValue(), getId(), setIntegerValue(), and setString().
◆ setDoubleValue()
void QDS_ComboBox::setDoubleValue ( const double  val)
valitem ID
References QDS_Datum::initDatum(), myValue, and setString().
◆ setEditable()
void QDS_ComboBox::setEditable ( const bool  on)
onif true, combo box is made editable
References comboBox(), and QDS_Datum::validator().
◆ setIntegerValue()
void QDS_ComboBox::setIntegerValue ( const int  id)
iditem ID
◆ setState() [1/2]
void QDS_ComboBox::setState ( const bool  on,
const int  id,
const bool  append = true
If id is -1 then specified state will be set to all items.
If append is set to true, keep current status for other items, otherwise status of other items is cleared.
onnew visibility state
iditem ID
appendif true, keep original status for other items
References myState, and setState().
◆ setState() [2/2]
const QList< int > &  ids,
idsitems IDs list
References QDS_Datum::initDatum(), myState, and updateComboBox().
◆ setString()
void QDS_ComboBox::setString ( const QString &  txt)
txtstring value
References activated(), comboBox(), getString(), integerValue(), QtxComboBox::isCleared(), QDS_Datum::onParamChanged(), QDS_Datum::paramChanged(), and QtxComboBox::setCleared().
◆ setValues() [1/2]
void QDS_ComboBox::setValues ( const QList< int > &  ids,
const QStringList &  names
idsitems IDs
namesitems names
References QDS_Datum::initDatum(), myUserIds, and myUserNames.
◆ setValues() [2/2]
void QDS_ComboBox::setValues ( const QStringList &  names)
Uses (0, 1, 2 ... ) as items IDs.
namesitems names
References QDS_Datum::initDatum(), and setValues().
◆ state()
bool QDS_ComboBox::state ( const int  id) const
iditem ID
item visibility state
References QDS_Datum::id(), myState, and state().
◆ stringToValue()
int QDS_ComboBox::stringToValue ( const QString &  str) const
stritem
References getId().
◆ unitSystemChanged()
void QDS_ComboBox::unitSystemChanged ( const QString &  system)
Update combobox contents.
systemnew active units system
References QDS_Datum::Handle(), QDS_Datum::id(), myDataIds, myIcons, myState, myUserIds, myUserNames, myValue, QDS::toQString(), QDS_Datum::unitSystemChanged(), and updateComboBox().
◆ updateComboBox()
void QDS_ComboBox::updateComboBox ( )
◆ values()
void QDS_ComboBox::values ( QList< int > &  ids,
bool  total = false
idsreturned list of items IDs
References myDataIds, and myState.
◆ valueToString()
QString QDS_ComboBox::valueToString ( const int  val) const
valitem ID
item value or empty string if val is invalid
References myValue.
◆ myDataIds
QIntList QDS_ComboBox::myDataIds
◆ myIcons
IdIconsMap QDS_ComboBox::myIcons
◆ myIndex
IdIndexMap QDS_ComboBox::myIndex
◆ myState
IdStateMap QDS_ComboBox::myState
◆ myUserIds
QIntList QDS_ComboBox::myUserIds
◆ myUserNames
QStringList QDS_ComboBox::myUserNames
◆ myValue
IdValueMap QDS_ComboBox::myValue
